Jacobpockros’s CL-S 6-Speed Thread
#209
Whats up with RDX owners?
And Im sure the dealer got you. 5-6 hours to do a 2.5 hour job would probably be in the $500 range if they charged you normal hourly rates.
#213
Whatever, I didn't want to risk doing it myself, plus the shop that did my springs messed up and the dealership was the only place that could fix their mistakes. So at this point, I just wanted to get the struts done right the first time. I'll hopefully be able to get my headers after the upcoming holidays, and my Icebox is on back order from Comptech, so it might not get here for a couple more weeks.
#214
A couple of weeks, but you need to drive it during that time
I usually do the front suspension in an hour, and each rear takes about 45 minutes. The longest part for me is getting the car on jack stands and pulling the rear seats.
#224
Did you buy the Icebox directly from CT?
#226
Ok. Yea I had to wait over a month for mine because it was on BO.
#228
Did you put on new springs also or new struts with stock springs? The springs are what settle in so if they are old ones they wont settle more really just need to drive back and forth a few times to settle. Are the struts adjustable, I know when i had my koni's they had 5 or 6 different height settings to pick when installing them.
#229
I already had Eibach Springs installed on there from a year ago, but I just got the Eibach Shocks installed a couple of days ago to go along with the springs. I think the shocks will settle in as well, because my oem shocks made the car sit a little bit lower.
#230
The struts themselves do nothing to hold the car up. Theyre only there to control the movement over rough pavement. The springs do most of the work. It may take alittle while for them to settle in. But since the arent new they wont settle as much as you'd think.
#233
Its 1/4" larger.
#238
Wow I loved it when I added that header when I had my CL-S6. The feel of adding 30 more hp is amazing bro. I never had crank pulley but did the other pulleys but im sure the super torque now already will be even deadlier after . Give us a review after you install.
#239
