a trick to aligning CL mufflers
this will help to make the mufflers height adjustable. you need a couple hose clamps, size 7/8 - 2 3/4".
remove the rubber mount for the muffler (to make it slide off easy spray it w/ some wd40)
place the hose clamp around the rubber mount, then reinstall the mount in a fashion which allows you to adjust the clamp w/ a screwdriver.
once it's back on you should be able to tighten the clamp a few turns and even out your mufflers. it also helps to cut down on the side sway that our exhaust tends to have.
civicdrivr (07-26-2012)
i have a clamp on both sides and my exhaust doesn't sway.
Blown is Best
Originally Posted by darrinb
hmm, i dont understand
goldmemberererer
Hm. Anyone got pics or a DIY (for dummies) of how to do it? I noticed my exhaust pipes are hangin a little lower than I'd like, and this sounds so great to do.
Thanks in advance
Thanks in advance
Received 1,080 Likes
Matt,
Nice post. I did this several years ago and they ended up snapping. The harsh weather took a toll on those clamps.
The best solution is to get under the car with a piece of pipe and slide the hanger bracket into the opening and bend the sucker into the right spot.
I used to have clamps like that on my car, they kept breaking. Instead I doubled up on the exhaust hangers. I went to Strauss and bought these hangers that look like thin donuts, almost like a vaccuum belt, mounted it behind the stock hanger and it kept the exhaust properly aligned, and they didn't sway much after..
Ed
Ed
MP90 uninstalled
I am in louisiana and there are only Autozone pepboys napa, no strauss. do you know which part you bought? so I can get one at one of the stores around here.
thanks
thanks
IBankMouse
06-13-2020 12:53 PM
emailnatec
29
09-28-2018 04:27 PM
DerrickW
11-15-2015 05:52 PM
johnpancakes014
09-27-2015 12:58 PM
