2G CL Frequently Asked Questions No New Threads Please.
DIY: MDX, Pilot, Odyssey spacer install
Old 10-29-2009, 05:53 PM
  #41
wham bam thank you ma'am
Rajca's Avatar
no one has this besides me. a few 3rd gen guy have done it. but their hood isnt popped as high, they have more clearance.
cheapest place i know. or find someone at a dealer that u know and acura will give the guy that works at the dealer better prices. so u get list pretty much and no shipping
Old 10-29-2009, 05:58 PM
  #42
3.7L Nitrous Breathing CL
richardparker's Avatar
I'll be trying it next,if it dont see more power on the botom end I know it will see more power on the spray.
PM'ing you
Old 10-29-2009, 06:06 PM
  #43
Rajca's Avatar
also. u cant mill the intake manifold where the cover sits. u wouldnt have room for the bolts to screw in bc u can only go so deep. and that 1/8" of clearance that u might get wont help much.
Old 10-30-2009, 08:58 AM
  #44
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,136 Likes on 4,805 Posts
Couldn't get temps last night, got home late and wasnt in a great mood. Tonight though I should be home earlier, so I should be able to get the measurements for you.
Old 10-30-2009, 12:39 PM
  #45
I ordered the parts I need this morning from Bernardi in Boston for like 87 shipped. I needed 2 factory gaskets right ?
Also did you say the spacer was only 1 3/4".
If it is, I don't think they're will be much clearance issues on clp's.Maybe the one center beam in the hood but,maybe not much at all
Old 10-30-2009, 01:14 PM
  #46
I just came in from putting something on the motor 1 3/4" in between the highest on the motor and the lowest part on the hood and it shut fine.
I really won't know when the parts come but ,this might look great for us clp guys.
Old 10-30-2009, 04:16 PM
  #47
Rajca's Avatar
Cool. But u only needed one new gasket. U can reuse ur old one as long as u don't bend it
Old 10-30-2009, 04:39 PM
  #48
oops maybe I can change the order but probally not
Old 10-30-2009, 05:00 PM
  #49
Rajca's Avatar
If its special order, u can't change it
Old 10-30-2009, 05:59 PM
  #50
Rajca's Avatar
i had 1.5" of clearance till i hit the center beam on the hood, and that was with the thremo spacer on, so with out it i would be at 1 3/4".
measure from the front plenum to the hood. thats where i had a bit of a problem and the hood needed to be raised a tad bit more to clear.
Old 10-30-2009, 06:07 PM
  #51
whoa dude,So I might be in the same ball game with you.
I could fit 1 3/4" where I did but 2" would touch the center bar but,I could still close it.
So thats why I opt out for the P2R spacer.
I hope I dont have the issues,I'll have to go remeasure tomorrow when it light out.
Any luck getting you hood down anymore yet?
Old 10-30-2009, 06:14 PM
  #52
Rajca's Avatar
havent messed with it, its not bothering me at all.
Old 11-19-2009, 05:01 PM
  #53
CLsuperhero's Avatar
Has anyone tried http://www.cervinis.net They might could hook us up with some custom hoods...Some look nice, but some look rice.
Old 11-19-2009, 06:19 PM
  #54
Rajca's Avatar
spent too much on my cf hood to get a diff hood now.
Old 11-20-2009, 11:14 PM
  #55
Registered User
silver6speed's Avatar
I wish all the DIY writeups were this good. Great work Rajca.
Old 11-21-2009, 10:36 AM
  #56
Rajca's Avatar
just doing my part to help out the forum.
Old 11-22-2009, 09:01 AM
  #57
I never payed much attention but,it looks as if the tabs on the spacer have to be cut like you did to fit.
Do they ?
Did you use a cut off wheel or grind them?
I want to heat up the piece less as possible.
Old 11-22-2009, 10:10 AM
  #58
Rajca's Avatar
they dont need to be cut. i cut them bc they would get in the way of my direct port nitrous set up. i used a cut off wheel and a 80grit sanding disk
Old 11-22-2009, 10:19 AM
  #59
2003 CL-S 6MT
Total2f's Avatar
It would be nice to get some exact measurements on how much the clearance issue is. I know it would be much likely less power, but since no one makes cowl hoods for our cars machining the spacer down for proper hood fitment could be an option. I assume the piece is aluminum so it would be very easy to do.
Old 11-22-2009, 11:46 AM
  #60
Rajca's Avatar
its aluminum.
i had about 1 3/4" or from from the top intake manifold cover to the bottom of the hood. spacer is 1 3/4". but than u have to calculate for engine movement.
but, where i had a problem was the bottom left hand side of the intake manifold cover hitting the hood. wanst something i was expecting. but to be on the safe side, id cut the spacer down to about half of its size. ppl on the 3rd gen side cut 7mm off of the spacer but they also dont need to raise their hood as much as i did.
Old 11-22-2009, 12:18 PM
  #61
B A N N E D
friesm2000's Avatar
got a spacer with all bolts (and studs) necessary and gasket for sale in BM
https://acurazine.com/forums/car-parts-sale-361/mdx-intake-spacer-mod-ct-quiet-tip-inserts-753235/
Old 11-22-2009, 12:26 PM
  #62
Pinho's Avatar
what are the gains like?...did u dyno it?i was thinking of doing this for a while now , i have had te parts for some time now but some things got in the way..still consedering on doing it
Old 11-22-2009, 07:05 PM
  #63
2003 CL-S 6MT
Total2f's Avatar
Was thinking threw machining the spacer down a bit, and this would require different bolts and studs I would assume because they would then be taller than needed. Right?
Old 11-22-2009, 08:43 PM
  #64
Rajca's Avatar
u would need diff bolts, i thing u can get away with using 95mm bolts.
been informed that they spacer will not work with the comptech strut bar. sensors and hoses get in the way
havnt dynoed it yet. i got some bent valves. and when i put the spacer on my tires let loose in 1st gear at any mph, never did that before with bent valves. so power was added
Old 11-22-2009, 08:55 PM
  #65
B A N N E D
friesm2000's Avatar
correct, but it also depends on how much you are getting it machined
that's me , you might be able to get away with a half height spacer, but that is about it
Old 11-22-2009, 09:34 PM
  #66
Rajca's Avatar
sell the strut bar, have to make sacrifices for power. OR try the 09tl shawd intake manifold and teh spacer. ud be the first one to do it.
Old 11-22-2009, 09:41 PM
  #67
civicdrivr's Avatar
Pick up the Neuspeed bar for the 98-02 Accord. I got mine on eBay for $50 (used of course). It sits behind the stock stb, so it doesnt get in your way.
Old 11-22-2009, 09:44 PM
  #68
Rajca's Avatar
^yup, i told him that, but he likes teh look of teh comptech bar.
Old 11-22-2009, 10:03 PM
  #69
B A N N E D
friesm2000's Avatar
and the cnc milled aluminum and not too many other people have it either
Old 12-16-2009, 04:04 PM
  #70
Update for clp spacer upgrade.
The recomended bolts are too long for clp/tlp intake.
They need to be 20mm shorter.
Old 12-16-2009, 05:04 PM
  #71
Rajca's Avatar
Hmm. That's strange. Never saw the inside of the manifold of a "P". Thanks for the heads up
Old 12-16-2009, 05:26 PM
  #72
I had to put 6 washes on each bolt and it still put a crack in one of the lower runners but,it seems fine.
Old 12-16-2009, 05:34 PM
  #73
B A N N E D
friesm2000's Avatar
that blows, but at least you do know it is there, and not wounderering why the F*** you engine be surging at idle (if it ever does eventually)
and don't plan on boosting with that there ethier
Old 12-16-2009, 05:43 PM
  #74
Rajca's Avatar
jb weld the crack for now. or take it to a body shop and see if anyone can weld aluminum.
u got a pic of ur intake manifold? with the top cover off. i want to see the difference.
at a hardware store by my house they had 90 or 95mm bolts. i needed 105mm. so the 90mm bolts just might work for the "P" ppl.
Old 12-16-2009, 11:11 PM
  #75
Its not a crack where air could escape. The bolt was going to pop a hole threw but it did not go all the way threw.
Thats why I said a crack.
But, when I first started the car I did get surging with a high idle.
So I checked for leaks . When I restarted the car it idled fine but check engine came on.So then I checked plugs and restarted the car and evrything was all good.
I've been out 3 times with the car and the performance has got beter everytime. ????/ our ecu's must have to learn wtf just happened or something.
Now idles fine,no lights and it go's.
Old 12-17-2009, 01:15 PM
  #76
civicdrivr's Avatar
Yea, they need to "relearn" again.
Old 12-17-2009, 08:18 PM
  #77
B A N N E D
friesm2000's Avatar
why do you think there is an idle relearn procedure in the service manual
Old 12-17-2009, 11:35 PM
  #78
civicdrivr's Avatar
Old 12-21-2009, 01:14 PM
  #79
acura_honda_30cl's Avatar
i have a question i have a 1gen 3.0cl i was wondering if this write up will for the j30 also?
Old 12-21-2009, 03:11 PM
  #80
Rajca's Avatar
Not sure. Look at my pics and compare ur intake manifold to that.
Quick Reply: DIY: MDX, Pilot, Odyssey spacer install
