2G CL Frequently Asked Questions No New Threads Please.
Comptech Icebox Filter Alternative!
Old 10-17-2003, 11:33 AM
  #41
types1967's Avatar
just ordered the k&n filter ru-2590 thanx smitty
Old 10-17-2003, 12:14 PM
  #42
Revving at 9K...
CLS2001_97124's Avatar
I should order one too, I got the same crap in my S2000's supercharger kit. I just clean it recently, and it was a piece of the carp too. However, on the instructions, I did not read anything about using the whole can of oil to recharge the filter, so I did not do that. All I did was make sure that there was enough oil to cover the entire filter. I wonder if I didn't do something right.
But thanks for the research, I might just buy a couple, and swap them out every six month or so.
Old 10-17-2003, 12:46 PM
  #43
scalbert's Avatar
Exactly, keep one on the side as a clean spare.
Old 10-17-2003, 01:03 PM
  #44
ModAddict's Avatar
Originally posted by scalbert
Oh, BTW, that really looks like a K&N foam filter. You guys can't read part numbers.
:P
Old 10-17-2003, 01:14 PM
  #45
scalbert's Avatar
It really looks like this filter was made for the IceBox:
Old 10-17-2003, 01:16 PM
  #46
Cost Drivers!!!!
Zapata's Avatar
One other thing I was looking at is finding a way to route air into the top to even out the how it is getting dirty. Maybe a new hood with a large scoop. :o
I JUST going to post this same issue........
i'm looking into purchasing a velocity stack filter. Not that this will help the dirt collection issue but.....i like the velocity stack filter better than the standard filter.
Old 10-17-2003, 01:18 PM
  #47
Cost Drivers!!!!
Zapata's Avatar
Originally posted by slyraskal
you know, i thought of going to a molding shop and having them custom make a plastic piece that would fit in the same spot as where the fog lights are, but in the 03's there is that black piece and having it flow air into the bottom pipe of the CAI this would be more direct and allow greater airflow.
what do you guys think? others have said to simply cut the black piece that is on the car, but wouldn't a shaped tube that directed air into the pipe be more beneficial? of course i wouldnt' recommend doing this in the winter time.
yea i'm considering this although i dont think there is a need for this as the black housing is removable be unscrewing it like the 01-02 roadlamps.
Old 10-17-2003, 07:00 PM
  #48
flint's Avatar
Good stuff Smitty :thinking:
Old 10-22-2003, 07:48 PM
  #49
Sold 12/29/04 :-(
SFLA_Type-S's Avatar
Just ordered mine from www.ajusa.com
Thanks for the info Smitty, I really hated that foam filter.
Old 10-22-2003, 08:14 PM
  #50
///M POWER
darrinb's Avatar
smitty scalbert
u feel any gains or sound difference??
i think i'll just buy a new filter instead of cleaning it, i have 17k, should i change it soon??
anyone got the k&n part # for the aem cai...
Old 10-22-2003, 08:18 PM
  #51
Smitty's Avatar
You can clean them suckas alot of times.. just keep it clean..
Take the filter off, measure it and then go to K&N's website and do the research... You'll find one for your application..
Smitty
  #52
My Member is Registered
Cruz_msl's Avatar
looks tight
does the top of the air box still close or do you just leave it off?
Old 10-22-2003, 08:25 PM
  #53
ModAddict's Avatar
it closes
Old 10-22-2003, 08:27 PM
  #54
Cruz_msl's Avatar
i'm in
Old 10-22-2003, 08:28 PM
  #55
Cruz_msl's Avatar
what's the HP-torque gain??
Old 10-22-2003, 08:36 PM
  #56
ModAddict's Avatar
don't expect any
Old 10-23-2003, 03:54 AM
  #57
retired
Jens H.'s Avatar
Well alternatives are nice and good .As far as that pin on the foam filter it will work .............as long as you rotate the filter ot the correct position .I used to run UNI foam filters on my bikes (literally for years) never had a problem .I see the foam filters here a lot have not seen any that have experienced any problems .KN is good stuff too but the cotton filter is fragile and must be cleaned very carefully and dried or else holes can develop that negate the worth of the filter .The foamies are a quick cleanup .
I found the comment about having to clean up the filter every 3000 miles interesting .I thought you guys were looking to extract the last iota of performance these cars can offer so it makes sense to keep the filter as clean as possible after all a clean filter works better than a dirty one .
Jens
Old 10-23-2003, 06:31 AM
  #58
Lead Footed
RUF87's Avatar
Originally posted by Jens H.
Jens
I just noticed your line above the avitar.
Ruf
Old 10-23-2003, 06:59 AM
  #59
retired
Jens H.'s Avatar
I love and miss my Alfas .
Jens
Old 10-23-2003, 07:04 AM
  #60
Cost Drivers!!!!
Zapata's Avatar
Jens
INteresting.....why?
Old 10-23-2003, 09:05 AM
  #61
retired
Jens H.'s Avatar
To try to explain an Italian car is virtually impossible ,after all they do indeed leak oil ,contain dubious electrical systems and are possessed by rust gods that are wicked in their abilty to consume poorly protected Italian tin .So what is it you might ask that makes these cars so special ? Well I have worked on many cars and have driven most of what is out there yet nothing is quite as "right" as an Italian car when it's "just so ".
Years ago when the Miata was introduced I remember reading a print ad that told the reader about how Mazda tried 50 different exhausts before they settled on one that had the "right " combination of sound and power .How interesting I thought to myself here these guys in Hiroshima are testing themselves silly all the while over in Italy they just hang whatever they can find that fits under the car and it sounds great .So what does this mean ? well it is simple .You can buy a Lexus LS top of the line sedan ,it will probably be ultra reliable ride great and it is in all respects more or less a blatant copy of a Mercedes .This is what they intended over at Toyota and they are quite good at it .I like the Lexus it is a great car but there is one thing it will never be ,quite siimply put it will never ever be a Mercedes .I grew up on European machinery and frankly no matter how wonderful the Japanese are at creating reliable cars it will not be enough for me .
I have owned Japanese cars ,they are impressive reliable things but there is one quality they lack and that is one that cannot be designed nor is it assembled or a bolt on item available online .You cannot grow it you cannot paint it on .It is called soul and they can copy every other trick but that is one trick they will not master .What is soul well go drive an Alfa Spider or perhaps a Ferrari 250 GT SWB (I have ) or try a Milano or perhaps a Maserati and then you will know .
In Road & Track years ago I read an article about a Ferrari gathering of some sort somewhere .One of the pictures was of a Ferrari 250 GTO ,underneath this photo was a simple caption "Breathes there a soul so dead that it does not drool on the fender of a Ferrari?" .I have never been a big reader but that line has stayed with me all of these years and frankly to me it said everything that I needed to know .Except perhaps they should have added Alfa Romeo.
Soul ,you either have it or you do not it is as simple as that .
Jens
Old 10-23-2003, 09:57 AM
  #62
Spectacular Aroma About
ChadT's Avatar
Well put Jens and very true. The last car I had, a 1993 Audi S4 had soul. When you punched the gas on the highway it was like you were transported to the Autobahn. Same thing when I've driven a 911. Seems like there is always a trade off though and the Audi "quirkiness" eventually offset it's enjoyment as a daily driver. I'm very happy with the Acura though. The CL 6 speed may not have a lot of soul but it does have a lot of endearing qualities and isn't really a copy of anything. It's fun and exciting like a good video game. Nothing magical like a Ferrari though. I hope I get to drive one of those someday.
Old 10-23-2003, 10:04 AM
  #63
retired
Jens H.'s Avatar
Trust me Chad my Alfas were lousy cars in some respects but that quirkiness was part of the charm part of the magic and I guess part of that soul .
jens
Old 10-23-2003, 11:17 AM
  #64
Lead Footed
RUF87's Avatar
I always refered to them as a 'poor man's Maserati', but they did have character that made them stand apart from the crowd.
That's why I still love older American Muscle cars . . . mechanically the were POS compared to today's new cars, but I'd have one in a heart beat.
'Cuda, Judge, GS-1, 442, Chevelle SS, you name it.
Ruf
Old 10-23-2003, 11:40 AM
  #65
4th Gear
Sutts_TO's Avatar
IceBox Filter
Hey Guys,
When you installed the new K&N filter, have you noticed any difference in performance??
Old 10-23-2003, 03:39 PM
  #66
drrfs's Avatar
K&N air filter
Smitty,
Thanks for doing the research on this filter. I have always liked K&N filters better than the foam ones. I went ahead and ordered one. Thanks again.
bob shadel
03 CLS
Icebox
Comptech sways
ground control/Konis
Old 10-23-2003, 03:48 PM
  #67
drrfs's Avatar
Jens,
Talking about Alfas on the CL site!! But anyway, brings back fond memories of broken motor mounts, distributors that rotated around by themselves, starting the car under the hood with a pair of small needlenose pliers, the smell and sight of good Italian oil, dropping a chain connector down the front of the engine and spending 2 hours finding it with a magnet...ah -- Alfa days!! After 5 Alfas, I still miss my first Alfa Spyder 1300.
Old 10-23-2003, 06:40 PM
  #68
dj5
dj5's Avatar
Got my icebox in this past weekend. Ordered the K&N filter,
when it's time to clean the foam filter I will replace it with the K&N.
Thanks guys
Old 10-23-2003, 06:44 PM
  #69
What, me drive fast?
blackmagiCL_S's Avatar
I had a K&N in my Prelude before I got the CLS and put the CT Icebox and I wonder if the "foam" filter lets in more than the K&N filter? Anyone that has handled both would wonder also. THe CT filter is...thin...which is why you need to clea it ever oil change not like the K&N every 40K or more? Could you be betraying some of the gains by changing the filter? Just because it fits....
Old 10-30-2003, 03:42 PM
  #70
cldriver's Avatar
I goto K&N and they valid arguments for their filters, I goto Unifilter and they present arguments for foam filters.
http://www.unifilter.com/performance-facts.htm
Who should I believe?
Old 10-30-2003, 05:32 PM
  #71
Smitty's Avatar
As stated on the 1st page, Steve, Brad, Eric and few other guys were not happy with the Foam filter... I think it is garbage, but that is just my opinion... We never really found out how many CFM's went through the FOAM filter, but K&N stated on their webpage with the application we were looking at and Steve confirmed that the CFM's were more than enough for us FI guys...
So do whatever you want..
Smitty
Old 10-30-2003, 05:49 PM
  #72
ModAddict's Avatar
Have you cleaned and oiled the foam filter yet,...like at every oil change?
Old 10-31-2003, 06:34 PM
  #73
Sold 12/29/04 :-(
Another interesting article...
Click Here
Old 10-31-2003, 09:37 PM
  #74
lou_RENAMED's Avatar
smitty again showing that he is on the ball...good job bro. Allthough I think the AEM filter exposed outside like the Aem CAI may expose to much dirt to the filter.....inside the Icebox its like its found it new home.. I wouldnt doubt a 1-2 HP
Old 01-29-2004, 06:49 PM
  #75
TopGum's Avatar
Just replaced my Comptech foam filter with the K& N. THANKS FOR DOING THE RESEARCH! The foam one looked like s%^t.
Old 01-29-2004, 07:35 PM
  #76
2 C Not 2 Touch
musclehead's Avatar
Damn, I don't even have an Icebox, yet. But when I do get one, I'll remember to replace it. BTW...any chance someone getting rid of their Icebox?
Old 01-30-2004, 09:04 AM
  #77
Smitty's Avatar
The power of the automotive car forum..
Old 05-06-2004, 10:01 AM
  #78
Smitty's Avatar
^----^... bump .....^------^
Send it off to the archives.
Old 05-06-2004, 10:25 AM
  #79
mrsteve's Avatar
Just put mine on 2 weeks ago! Thanks for you help over the phone too Smitty!
Old 05-06-2004, 10:31 AM
  #80
philgates's Avatar
What did you need help with?
Quick Reply: Comptech Icebox Filter Alternative!
