CLS Front Bumper Removal DIY
Step 1
Open hood. You will see the black plastic cover around the top of the bumper
There are 8 clips you need to remove on this cover.
Once removed you can pull the black plastic cover off
Step 2
You will see 3 phillips head screws. These can be hard to remove without stripping them. I used an impact screwdriver & that broke them loose.
Step 3
There’s a screw at the corner of the bumper at the wheel well.
Remove this. You may need to move the wheels left or right to get the screw out. Repeat for the other side. Blurry I know but you can see it.
Step 4
There’s a 10mm bolt under the back edge of the bumper near the wheel well. Remove this, & repeat on the other side.
Step 5
There are 4 clips along the underside of the bumper. Remove these
Step 6
Pull the sides of the bumper out, & push down & pull the entire bumper. It should slide off. I had to finesse the bumper off. It was stuck on there
Reverse to install.
I never removed my bumper before & it took me about 10 minutes. So anyone can do it if they need to. There’s not much involved as you can see.
To get the clips off use a flathead screwdriver.
If you break a clip or 2 it’s not a big deal. Acura dealers should stock the parts, & they are less then $1.
When putting the bumper back on, the sides may be tricky to get in. They were for me. And BE CARFULL not to scratch the bumper, or nick it, or drop it.
NOTE: If you have stock road lamps you will have to remove them. The 03 has inserts & do not need to be removed.
Step 2
Step 3
Step 4
Step 5
Step 6
Reverse to install.
Uses turn signals in my
I see the pixs fine. Thanks for the great DIY, I may be putting it to use in the near future.
Clips are around $1 (@ my local honda) for those who break them (like me).
Damn pop-screws.
Damn pop-screws.
A clean ride is in
Fuzzy!! It's funny that you posted this last night. By the time you posted, I had already taken off the bumper and put it back on. I used Soopa's instructions from '02. I was trying to switch out my '01 for '03 headlights and hit a snag and ran out of daylight. By the time I finally get them installed, I'll be a pro at bumper removal.
Moderator Alumnus
fuzzy-I see the pics just fine...it WAS the damn site blocker. Good DIY by the way!
Originally Posted by fuzzy02CLS
Can this be moved to the info thread?
Moving this to the FAQ forum...
eh
Great post - Thanks - this was exactly what I needed.
I just finished replacing a balast control so of course I had to take the bumper off.
A few comments for anyone else considering taking the bumper off themselves:
Total work time for me was about 2 hours but I went pretty slow and I don't do this type of stuff very often.
I didn't need any power tools, the three tough screws on the top of the bumper were tight but I had no problems with a descent philips head screwdriver.
The bumper takes a bit of work coming off and going on so you might want plan on a little extra time unless you're experienced at taking off body panels.
The whole process isn't technically difficult at all ... and for anyone that's curious....once the bumper is off swapping the balast was easy (10-15 minutes if you're slow)
GO RANGERS!!!!!!!!!!!!!!!
Thanks for the great write up. I will be r&r'ing my headlights next week so I will be using this info.
Thanks!
Thanks!
CL smashin
Pictures no longer showing. Check out the thread below for bumper removal with working pictures:
D.I.Y. - Clearing Headlights!
https://acurazine.com/forums/frequen...lights-495390/
Oakes
Wash & Wax
10-12-2015 11:17 AM
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
robowarrio
09-01-2015 09:25 PM
