2G CL Frequently Asked Questions No New Threads Please.
3.5 liter hybrid build information
Old 11-29-2010, 02:38 PM
  #81
Whats up with RDX owners?
civicdrivr's Avatar
Received 8,143 Likes on 4,810 Posts
Its cool. This is the auto setup:
6MT setup:
The thing thats sticking out past the engine cover on the auto is the VSA, its right in front of the throttle body.
Old 11-29-2010, 06:06 PM
  #82
type r teggy's Avatar
ok cool so thats pretty much all thats different is the cam, cam gears and cam sensora dn im good? if thats the case im in good shape. lol 3.5 here i come
Old 11-29-2010, 06:08 PM
  #83
oh yea one me thing. can a new stock clutch hold that power of a 3.5 with power adders? lol sorry for if im annoying i just want to make sure it all will come together nicely
Old 11-29-2010, 06:19 PM
  #84
I Drive Like A Dick 8≈
Nersh7's Avatar
Should be fine but upgrading is always recommended
Old 11-29-2010, 06:22 PM
  #85
Nersh7's Avatar
Originally Posted by StreetKA
You can use TL S motor but you have to swap the cam and gear sensor and gear from manual head. Or just simply reuse manual heads. But thats all. You can reuse block it has iron sleeves and pistons but i would go with RL ones. All you really need to build spare motor is heads bottom from odyssey or mdx on the first page you have all the info you need. If you want save money you should reuse CL pistons but the have different compression than rl ones iirc that makes you able to run regular gas if you want.
Is this with the CL or RL pistons? and is it true?
Old 11-29-2010, 06:34 PM
  #86
civicdrivr's Avatar
No, I missed that post.
No matter what you need to run premium or you may get some detonation.
The CL pistons lower compression to 10.5:1 IIRC while the RL pistons keep it at 11:1.
As far as the clutch goes, what sort of power adders?
Old 11-29-2010, 06:41 PM
  #87
Nersh7's Avatar
I kinda figured that just wanted to confirm
Old 11-29-2010, 06:43 PM
  #88
This is going to be the setup.........
j32a2 with mdx crank, rods and rl pistons. j32a2 heads ported and polished. ported and polished intake manifold. throttle body.comptech headers. comptech airbox, p2r tb spacer, unorthadox pulleys, aem fpr and fuel rails,.... If i need to get a clutch idk what to gettttt I got one brand new from honda but i hope itll be enuff... would you recomend any other upgrades?
Old 11-29-2010, 08:07 PM
  #89
civicdrivr's Avatar
For that build the stock clutch would be fine. Worst case scenario you can always run the P2R disk.
Old 12-03-2010, 06:15 PM
  #90
p2r disk it is. WHat Greddy emanage should i run on my car. I want the most potential power out of my na build. the motor is almost ready to drop into the car. the emange blue or the emanage ultimate? Im an idiot becuase i had anultimate around the house and i sold it like a moron becuase i had no use for it
Old 12-03-2010, 07:03 PM
  #91
civicdrivr's Avatar
None.
The eManage and the f/ic dont adjust timing so its pointless on your motor.
Old 12-03-2010, 07:49 PM
  #92
3.5 psi
gnuts's Avatar
won't the emanage control air/fuel, which is want is wanted? Pulling timing is obviously the best, but i didn't think anything did that as of yet.
Old 12-03-2010, 07:53 PM
  #93
civicdrivr's Avatar
Hes not boosted. On the stroked motor the stock ECU pulls timing to begin with. To make more power it needs to advance it. The eManage controls fuel/air.
The only thing that has full control over the motor is the AEM EMS.
Old 12-03-2010, 07:59 PM
  #94
3.5 psi
gnuts's Avatar
i was thinking of picking up an emanage blue for a future 3.5. bad idea? will a FPR be enough?
Old 12-03-2010, 08:39 PM
  #95
civicdrivr's Avatar
My AFRs are holding steady to redline with just an FPR cranked to about 55psi:
I just wish the car would stop pulling timing.
Old 12-03-2010, 09:12 PM
  #96
3.5 psi
gnuts's Avatar
well that's nice to know...i can check a few things off the list. thanks.
Old 12-03-2010, 09:18 PM
  #97
civicdrivr's Avatar
Lol, np.
Alot of the Accords need to use a F/IC after an engine build because the stock injectors are 270cc IIRC. Ours flow more so we dont max out the injectors on relatively mild builds as easily as them.
Old 12-03-2010, 10:53 PM
  #98
damn. thats crazy the stock ecu contols like that. so no type of piggy back will give me more power? thanks for all the help civic driver.. so how mch power will i make around?
Old 12-04-2010, 09:03 AM
  #99
3.5 psi
gnuts's Avatar
look at his dyno above....280whp/256wtq (stock exhaust i belive). He said the AEM EMS will be best.
Old 12-04-2010, 02:50 PM
  #100
civicdrivr's Avatar
The power numbers all depend on how good the PnP is. It makes the difference between a 250whp 3.5 and a 270whp 3.5.
That graph was with my stock exhaust and, we found out afterwards, a clogged cat. Im trying to hit the dyno on Tuesday to see what the breathing mods did.
Old 12-05-2010, 12:58 PM
  #101
wow those are nice numbers... of course im looking to get the most so i ported as much as i could without going through the walls. I have stock exaust myself with comptech mufflers. maybe i should get a race cat or somthing. Im trying to break 12 in the quarter
Old 12-05-2010, 12:59 PM
  #102
it might be a little off topic but i wanna get a big brake upgrade too. maybe il just get some rl calipers for my baby lol
Old 12-05-2010, 06:32 PM
  #103
civicdrivr's Avatar
Keep in mind that my motor is a 3.6l, so a 3.5 will make slightly less power. Not much though.
And good luck getting into the 12s without any power adders. This is going into a CL right?
Old 12-05-2010, 06:34 PM
  #104
B A N N E D
friesm2000's Avatar
or some serious weight reduction
Old 12-05-2010, 09:52 PM
  #105
im just gunna order the aem stand alone tonight. i think i can get at least close the 12s with a good tune.. yea its goin in my cl. or mayb i can run a zex smart kit 50 shot lol
Old 12-05-2010, 09:56 PM
  #106
StreetKA's Avatar
did you ever raced your CL on the race track ? seriously GL and nitro is no go for me...
do you want to meet up anytime soon ? im like 5 miles away from you what color is your CL ? we may go to englishtown someday...
Old 12-05-2010, 10:09 PM
  #107
yea i ran 2 times 14.3 and 14.2. i only got a comptech icebox on my motor now thats the only mod i have on my motor thats in the car thats why i figured i can get into the 12s but i guess it takes alot to get these cars running strong. but mine is anthricite or how ever u spell it lol. but its up 2 u il meet wenever bro
Old 12-05-2010, 10:56 PM
  #108
civicdrivr's Avatar
With a good driver and the 3.5 you might run a 13.7. If you know where you can get 8/10s of a second out of a tune please let me know.
Old 12-05-2010, 11:19 PM
  #109
wowwwww. so ur telling me im only gunna run 13.7 from all this workk???? for that i shoulnt have built this motor. damn im upsett
Old 12-05-2010, 11:27 PM
  #110
civicdrivr's Avatar
These cars are heavy and front wheel drive.
A bump of ~40whp and ~50wtq isn't going to get the car into the 12s. You need ~400whp to do that, and launching aint easy.
Old 12-05-2010, 11:31 PM
  #111
Nersh7's Avatar
Not really much of a drag car anyways
Old 12-05-2010, 11:32 PM
  #112
civicdrivr's Avatar
Its the worst type.
Old 12-05-2010, 11:41 PM
  #113
mayb i should sell this motor nd just put a turbo setup on a 3.2. with the money i put into my spare motor i could have pieced together a bangin turbo setupp
Old 12-05-2010, 11:45 PM
  #114
its crazy because i had a k series integra with a full system, full interior. the car was heavy as shit nd i ran 11.6 on a semi built k24. i guess i got caught up in that worlddd lol
Old 12-06-2010, 12:33 AM
  #115
B A N N E D
friesm2000's Avatar
that might get you real close to those 12's, but i am personally running a zex kit at a 100 shot with no issues (and want to go bigger eventually, but need a bigger fuel, wideband etc. etc.first), and i have gone through quite a few bottles already
Old 12-06-2010, 12:39 AM
  #116
B A N N E D
friesm2000's Avatar
a 100 shot will get you very close to that ~400 range (and personally these motors seem to like to take a liking to the cooling effect of nitrous {part of why i think your's is very consistent with the timing and what not, and sometimes making great power and other times not so much
also i almost seem to run more consistent with even a 55 shot, because it took more of the heat soak factor out of the equation
Old 12-06-2010, 12:56 AM
  #117
civicdrivr's Avatar
The 6MT CL weighs 3,446lbs.
Never been a fan of the bottle. I like performance thats always there.
Old 12-06-2010, 01:07 AM
  #118
B A N N E D
friesm2000's Avatar
it works and personally i want a refill station so i can just refill it at home (yes it does get kinda expensive having to pay like $40 to refill it everytime )
also last post i meant "inconsistent"
Old 12-06-2010, 01:19 AM
  #119
civicdrivr's Avatar
I dont really know if its a heat soak issue causing my engine to pull timing. Sure, it does feel down on performance in the summer, but it is inconsistent in the dead of winter as well.
Oddly enough, I switched to the short ram setup on my intake and the engine is running much better. Odd.
Old 12-06-2010, 07:36 AM
  #120
3.5 psi
gnuts's Avatar
TypeR tracked a 13.3 with his 3.5 auto. I think lower 13s is very possible but 12s not without some nitrous or FI. You need very light wheels and an amazing launch & reaction.
Quick Reply: 3.5 liter hybrid build information
