Went to the Dyno today....
Weather was 60 degrees....6-speed/Comptech Intake/Comptech Headers/Cat delete/Comptech Mufflers/P2R TB Spacer/Honda Ridgeline IM Spacer/ Lightweight Pulleys/Mugen Stat/Cooler Fan Switch....from my cat to my mufflers its stock, so I dont have true full exhaust.
Max whp:264.52
Max Torque: 236.49
They were done in 4th gear. The pull that I got 256.87 was done in 3rd gear.
2ndgentl
Not sure yet, maybe you guys can give me some idea's
All motor
Nice numbers! Are they SAE or STD? Next mod(s) should be ported runners/3.7 intake manifold and maybe Blox 76mm TB. You would put down 280+
takin care of Business in
Received 4,732 Likes
Nice numbers...
All motor
^ SAE or STD numbers?
All motor
Found it!...it says STD. Is that good? Bad? I know in human terms STD's are bad....does my car have Chlamydia?... Gonorrhea? I know my car got raped by a CL63 once and a McLaren but they looked clean....
Sonnick (03-10-2013)
All motor
LOL.
Depending on the conditions, the numbers will be higher or lower. If it was 60 and dry with high pressure, your numbers will be lower. If it was 85 and humid with low pressure, your numbers will be higher. Ask the shop for the SAE corrected graph.
So the SAE corrected numbers will be 2% lower
D-Rob
62
01-05-2016 11:44 AM
JarrettLauderdale
2G CL Dynograph Gallery
09-21-2015 07:51 PM
