L's TL's pre 6spd swap dyno
Old 02-17-2009, 11:26 AM
EL19's Avatar
Had a dyno day last friday.
Old 02-17-2009, 07:30 PM
Quarantuning
SlickShiftNall6's Avatar
Nice numbers. What mods do you have?
This will be interesting to see how much the 6spd swap will add to your hp.
Old 02-17-2009, 07:51 PM
scholtew's Avatar
Yea, cant wait to see the actual test results, from auto to 6 speed. Thanks for add a relevant thread to the community I'm serious,theres too much crap on the forum anymore and not a lot of stuff like this.
Old 02-17-2009, 09:29 PM
6th Gear
Goinfasterthanu's Avatar
x2
Old 02-18-2009, 08:33 AM
EL19's Avatar
Thanks. I have Intake, Headers, Outlaw IM spacers, TB coolant bypass, light weight underdrive crank pulley (the bomz $25 one), full exhaust and no cat
Thanks yea I agree with you on that one. I think its gona add somewhere between 20-30whp
Old 02-18-2009, 08:08 PM
CLS6SpeedNupe's Avatar
WTF?? 20-30whp from a tranny swap??
Old 02-19-2009, 09:21 AM
EL19's Avatar
yea the AT has a 20-25% powertrain loss while the MT has an 8-15% powertrain loss...thats a 17-10% increase in power which would be around 20-30 whp...im leanin more towards 20...
Old 03-06-2009, 01:17 PM
Accordinglo's Avatar
is this on a type S?
Old 03-06-2009, 02:51 PM
EL19's Avatar
yep
Old 03-06-2009, 02:56 PM
is in Honda heaven
Derk's K24's Avatar
Never even saw this thread. You better get goin buddy! Dont let my project beat yours! LOL!! I doubt it...
Old 03-06-2009, 02:57 PM
dru2's Avatar
very nice, you got yourself a sweet ride.
does your reverse light work? and are you using the same cluster?
Old 03-09-2009, 09:16 AM
EL19's Avatar
LOL I wouldnt be surprised if you did. We'll see though.
^^^^ for the swap the reverse light will work and no im using a cluster from an 03 6 spd cl
Old 03-09-2009, 03:38 PM
mrsteve's Avatar
What type of dyno? That's pretty hard to believe just for those modifications. Let's say you're around 200 whp stock (which is being very generous). You've increased your wheel horsepower by nearly 30% with just a few bolt ons that many of us have done before with results roughly 20-25whp less than what you show.
Old 03-09-2009, 10:31 PM
Steve your so technical. Well I dont know what extra mods he has, but I know he does have what he listed.
Old 03-10-2009, 09:42 AM
mrsteve's Avatar
I'm not being technical... just skeptical. His numbers are 30% higher than dozens of other dyno numbers that have been posted from similar mods.
Just wonder what type of dyno he used.
Old 03-10-2009, 02:07 PM
He used the same dynojet that I have been using my car on since last year. Who knows, he might have something extra but he got a new motor after his SC blew his other one up so this motor might be stronger.
Old 03-10-2009, 02:15 PM
mrsteve's Avatar
30% stronger?
What was his baseline dyno?
Old 03-10-2009, 02:28 PM
30% stronger?
Well I dont have the average set up for our cars, but based on what I was told my people who dynoed on that dyno with out kind of cars the dyno is fairly accurate but they said they have went elsewhere and got higher numbers. If you search this dyno section back to last year you will see that he posted a dyno before he put the SC on with the old motor and his numbers were way lower. The only mod that I see he has list now that he didnt have last year on the old motor is the test pipe so maybe thats where the power comes from.
Old 03-10-2009, 03:09 PM
mrsteve's Avatar
Not likely. Previous testing from years before you guys were on the forum showed the test pipe slightly increased horsepower but destroyed the torque numbers.
Old 03-10-2009, 03:11 PM
EL19's Avatar
the only things extra i have from the dyno where i dynoed 237whp is a 2.5 inch exhaust and a 2.5" test pipe. I gained 20whp with the addition of the exhaust and deletion of the cat.
FOR THE RECORD I DONT HAVE ANYTHING EXTRA THAN WHAT I LISTED. I HAVE NO REASON TO LIE ABOUT ANYTHING. MY BRAND NEW MOTOR DOES FEEL STRONGER THAN THE LAST THOUGH. PEOPLE ARE MORE THAN WELCOME TO CHECK OUT THE RIDE IF YOU LIKE.
Old 03-10-2009, 03:13 PM
mrsteve's Avatar
In what gear was the dyno run?
Old 03-10-2009, 03:14 PM
mrsteve's Avatar
I'm not calling you a liar by any means. The numbers are right there to be seen. It's just the numbers don't line up with what they should be.
What was your baseline number?
Old 03-10-2009, 08:10 PM
EL19's Avatar
dyno run was in 3rd gear since 4th gear has a speed cut
Im not sure what you mean by baseline #. If you mean the # i was going by to see what gains were then it was 237whp and 202wtq with intake, headers, light weight crank, and IM spacers.
For this run I had all of that + the 2.5 inch exhaust and 2.5 inch test pipe.
What else could I possibly have done?
Only thing that I could think of that would help me yield more power was that when my block was destroyed Tischer Acura bought me a brand new bottom end and sent my heads off to the machine shop to have them freshened up. But that wasnt a performance job.
Old 03-10-2009, 08:16 PM
mrsteve's Avatar
Too many variables involved. Dyno likely is just reading higher than most we typically see here.
Old 03-16-2009, 10:59 PM
scholtew's Avatar
God dammit, you are totally the buzz killington of this thread. I was pretty excited to see the results of this swap and now it may be tainted..
Old 03-17-2009, 08:00 AM
mrsteve's Avatar
You'll get over it.
Old 04-02-2009, 02:23 PM
sinfulj32's Avatar
the dyno chart is uncorrected. if corrected by preferrably SAE or at least STD, it would be more accurate.
L's Tl, if you get the dyno file from your dyno shop on a thumb drive or something, dynojet has a website with a downloadable app that you can play with your dyno reading with corrections and different settings.
and theres nothing wrong with having a strong motor. it happens
Old 04-06-2009, 08:38 AM
EL19's Avatar
^^^ ur right didnt even notice that. I just made the corrected SAE #s and it came to 247whp and 211wtq. Thanks man Thats still more power than any auto ive seen I have a few more mods Ima do before I get swapped.
Old 04-06-2009, 07:46 PM
sinfulj32's Avatar
gl man, let me know how those new mods work out
Old 05-03-2009, 07:48 AM
lowrd on tein CS biatch
CL-S progression 01's Avatar
247whp on an auto? I'll take it!..
I'm looking to get to the 250whp mark myself by the end of the year.
headers are coming in 2 days along with the pulley.
So i just need plenums, tb spacer and IM thermo gaskets... and OH the comptech exhaust....MMMMMM
then I should be right with you (I hope)
my motor's a youngin, was babied it's whole life. Wouldn't suprise me if she's still got the beans!
Old 05-04-2009, 07:01 AM
EL19's Avatar
^^^ Good luck man. My car is gone now but its memory will live forever
Old 05-04-2009, 09:37 AM
Quarantuning
What happened? Its gone, sold, totaled? Sux to hear that. I was looking forward to seeing what the 6spd tranny is really doing in comparison to the auto.
Old 05-04-2009, 01:40 PM
sinfulj32's Avatar
update if you dyno. im interested in seeing dyno from a babied motor
Old 05-05-2009, 08:47 PM
wham bam thank you ma'am
Rajca's Avatar
L's TL tl is totaled, look on the tl side, has pics of teh accident. horrible outcome
Old 05-06-2009, 06:42 AM
EL19's Avatar
yep totaled, I was looking foward to seeing the comparison too as well as feeling it but oh well. Onto other things now, id get another TLS and do the the 6speed swap or even a CLS6 but I know its not going to feel the way my car did because I had a new motor. Time for something with some more power and two doors now
Old 05-07-2009, 11:12 AM
sinfulj32's Avatar
gl L
Old 10-22-2010, 08:51 PM
Jacobpockros's Avatar
So what was the end result?
Old 10-22-2010, 08:57 PM
Received 16,260 Likes on 11,971 Posts
towards the end of the thread, he said he totaled his car.
there is no end result.
Old 10-23-2010, 11:20 AM
StreetKA's Avatar
247 whp SAE its nice man... i have similar mods just dont have spacer and TB coolant bypass(whatever it is you can explain:P PICS) headers Intake underdrive crank pully
im hoping for 235 whp
what kinda dyno was that? and whats the diff between SAE and not SAE exept Not SAE is higher.
TypeS860
09-03-2021 06:42 PM
navtool.com
3G MDX (2014-2020)
32
01-20-2016 11:43 AM
xsilverhawkx
09-28-2015 06:51 PM
hpfiend
09-27-2015 06:59 AM
mellsonnj
09-24-2015 04:42 PM
Quick Reply: L's TL's pre 6spd swap dyno
