Help with Airbag Light
Disconnect the battery for 15 minutes and the message should go away if everything is good with your airbag system.
Did you have a dead battery recently? I ask because sometimes a faulty battery will also trigger the SRS message. Its a Honda thing.
i will try that thank you, & the light did pop up when the car couldn’t start, not sure if it was a battery problem or starter problem, because it made a weird noise like it was trying to start but it couldn’t until i tried it a couple of times then it started that’s when that light popped up.
thanks man i did it light is still on which is crazy because if you look at my other post i had random lights popping up on my dash they disappeared and never came back. So idk wats wrong
Did you do a battery load test? If you did and the battery is still serviceable then most likely you'll need to take it to the dealer to diagnose. You could also peruse an independent Honda mechanic if you don't have the extended warranty and save some $$$.
Rhop09
1G TSX Problems & Fixes
04-08-2018 10:47 AM
Billu99tl
2G TSX Problems & Fixes
05-26-2016 03:26 AM
wmahmud
4G TL Problems & Fixes
06-09-2014 08:40 AM
bluesolara
11-27-2013 02:55 AM
