2016 ILX lowering springs(informative )
Old 11-11-2015, 08:07 AM
slow-k24's Avatar
OK so I've come to realize most people on these forums aren't true enthusiasts and wait on other people or shops to do all their research for them, that's fine I get it. With that being said I put in the effort to try and find a set of springs that will work for the 2016 ilx.
Results: in 2014 the civic SI received a revision to the front suspension, likewise so did the 2016 ilx. Is it possible the same revision done on the civic was done to the ilx? The answer is yes.
So ANY 2014-2015 civic SI suspension part swaps direct into the 2016 ilx. Now be careful when looking for springs and coil overs most sites claim their product is 2012+ SI which is not the case you MUST find the product for 2014+ in my case I ordered 2014+ d2 lowering springs I even cross referenced the part number to the 2012 to make sure I wasn't getting the wrong kind, they will hopefully be installed this weekend.
The following 2 users liked this post by slow-k24:
jspangan (11-11-2015), The6ix (07-08-2019)
Old 11-11-2015, 10:44 AM
jspangan's Avatar
Just so i am clear, you are strictly talking about springs and not coilovers correct? Or is there a fitment difference between the two?
There are many threads regarding coilover fitment and an AZ User actually has godspeed 2014 civic SI coilovers installed and it fits perfectly.
I actually had Eibach's R&D department keep my car for a couple of days and test fit their springs products (pro-kit and sport line springs) on my 2016 ILX sometime in March of this year. They only tested the previous year ILX springs and here is what the R&D Manager mentioned to me.
"The previous kit fits on the vehicle physically however the lowering amount is not correct.
The kit lowers way to much in the front and not enough in the rear."
If what you are saying is true, would you think Eibach's 2014 Hondoa Civic SI Pro Kit Performance Springs fit our 2016 ILX?
PRO-KIT Performance Springs (Set of 4 Springs) | Eibach Springs
Old 11-11-2015, 11:49 AM
slow-k24's Avatar
PRO-KIT Performance Springs (Set of 4 Springs)| Eibach Springs
Coil overs from 2014+ SI work, and as for the issue eibach had doesn't surprise me the suspension is very similar the insulators are different also the front will be slightly lower than an Si due to our heavy 8spd . They main change from previous year was the angle of the front mounting point
Old 11-11-2015, 12:04 PM
jspangan's Avatar
Right on, thanks for the info. So do you think 2014 civic si Eibach Springs would work over previous year ILX's ?
Old 11-13-2015, 09:07 AM
slow-k24's Avatar
As long as the 2014 si eibach part number is not the same as previous years.
Old 11-13-2015, 06:51 PM
slow-k24's Avatar
So I installed the springs this morning took me only 2 hours
The rear took some time to settle to final height because they are progressive springs
Attached Thumbnails 2016 ILX  lowering springs(informative )-downloadfile-9.jpeg   2016 ILX  lowering springs(informative )-downloadfile-8.jpeg   2016 ILX  lowering springs(informative )-downloadfile-7.jpeg   2016 ILX  lowering springs(informative )-downloadfile-6.jpeg   2016 ILX  lowering springs(informative )-downloadfile-5.jpeg
2016 ILX  lowering springs(informative )-downloadfile-4.jpeg   2016 ILX  lowering springs(informative )-downloadfile-3.jpeg   2016 ILX  lowering springs(informative )-downloadfile-2.jpeg   2016 ILX  lowering springs(informative )-downloadfile-1.jpeg   2016 ILX  lowering springs(informative )-downloadfile.jpeg
Old 11-13-2015, 07:14 PM
aomechmarine's Avatar
Good info. Helping people avoid mistakes.
Old 11-20-2015, 11:31 AM
jspangan's Avatar
How is the ride quality on those springs? What brand springs are those?
Old 11-20-2015, 11:45 AM
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
2 hours...you're a seasoned mechanic!
Nice, man...love seeing others taking the time to share information instead of just taking taking taking...
to you!
Old 11-21-2015, 09:42 AM
slow-k24's Avatar
to you!
Thanks, I've been working on cars for 11years, currently I'm an aviation mechanic specializing in ch-47F (chinooks)
Old 11-21-2015, 09:44 AM
slow-k24's Avatar
They are D2 lowering springs, ride quality is....well they aren't like a good coil over setup but not harsh or bouncy, I scrape the lil mud flaps in front of the tires everywhere though :/ but I'm used to that.
Old 11-22-2015, 02:24 AM
iRaw's Avatar
Much appreciation for taking the time to give Civic SI springs a try. Makes sense, if everyone else is using 2014 SI Coilovers why not try springs. That's a lot of leg work you must have put in to figure that out.
Since I'm not a true enthusiast, I've been waiting for a reputable company to release a set of springs that are actually designed to fit the '16 ILX. Proper springs rates and all. I'm sure there's about 150lbs difference between the two cars. With the ILX being mostly front end heavy.
Maybe you can post up some pics once the rear end settles.
I'd be pretty disappointed if my front end was slammed and scrapping mud guards while my rear end had 2.5 inches of wheel gap. Especially after putting in all that research on 2014 Civic SI springs.
Old 11-27-2015, 12:58 PM
ILXDyna's Avatar
Great job thanks for sharing!
Old 11-28-2015, 06:25 AM
jspangan's Avatar
So apparently i noticed on Acura of Glendale's (CA) instagram that they decided to throw some 19" wheels lowered on H&R Sport Springs.
I contacted them via instagram and they confirmed that H&R manufactures springs for the 2016 ILX.
I did some quick searches and simply found out that H&R just uses 2014 Civic SI spring part#
I suppose on the picture below you can still see how the front is way lower than the back.
Just as iRaw mentioned ... I can't wait until an actual spring set is created for the '16 ILX, rather than manufactures simply labeling their '14 Civic SI springs as '16 ILX friendly!
https://www.instagram.com/acuraofglendale/
Searched '16 ILX = Part # 51890
Searched '14 Civic SI = Part # 51890
Old 12-21-2015, 07:35 AM
FaKloveaD
Derka's Avatar
I think the drop looks nice. I wonder how it rides
Old 12-24-2015, 03:24 PM
slow-k24's Avatar
Rides decent for springs feels a tad bit more stiff than stock, front is soft but doesn't rebound like a car with cut springs,
Old 03-08-2016, 10:52 PM
schen72's Avatar
Back in my younger days, I used lower springs on a '92 Integra and while it looked good, the ride was horrible. There's no way I could stand that kind of ride quality these days. Is there such a thing as lowering springs that still has mostly OEM original ride quality?
FZ427 (08-22-2017)
Old 03-09-2016, 10:37 AM
peti1212's Avatar
I'm pretty sure the moment you lower you car the ride becomes pretty stiff, no matter how good the springs are. There is just less space for movement, so it needs to be stiffer. Correct me if I'm wrong.
Old 03-09-2016, 11:02 AM
usdmJON's Avatar
You are correct. If you take away an inch of suspension travel its impossible to get the same ride feel.
Old 03-10-2016, 11:33 AM
schen72's Avatar
I'll stick with stock suspension then. Back in the old days, Honda/Acura had huge wheel gap and (comparatively) small wheels, but not anymore.
Old 03-15-2016, 08:42 PM
SlaammedILX's Avatar
Props to you & I'm glad you found this out on your own, you could have called me at Godspeed and I would have told you lol.
2012-13 Civic Si =2013-15 Acura ILX (all models)
2014-2015 Si = 2016 Acura ILX
2016 Honda Civic EX has different suspension so that if the 2017 ILX is sharing the same chassis again than it is completely different.
Old 04-05-2016, 09:41 PM
9th Gear
ccasanova's Avatar
My 2016 ILX
I purchased my ILX at Acura of Glendale. They installed the H&R springs. Same ones as above. Here are some images. I cant decide if I want to install wheel spacers or opt for wider rims.
I've also tinted the windows. That's all for now.
Anyone know of any big brake kits for the 2016 ILX?
Attached Thumbnails 2016 ILX  lowering springs(informative )-image1.jpg   2016 ILX  lowering springs(informative )-image2.jpg   2016 ILX  lowering springs(informative )-image3.jpg   2016 ILX  lowering springs(informative )-image4.jpg   2016 ILX  lowering springs(informative )-image5.jpg
Old 04-06-2016, 12:36 PM
jspangan's Avatar
Very nice, On the H&R website the part number for 2016 ILX is 51890. Your part number is 51891?
How is the ride quality? Is it noticeably bouncy?
Old 04-07-2016, 02:28 AM
9th Gear
ccasanova's Avatar
Bouncy? No. tight, yes. Overall happy with the springs.
Old 05-12-2016, 12:58 AM
jspangan's Avatar
Great. The H&R Springs website applicator says the part number for 2016 ILX is 51890; but acura of glendale installed part no. 51891 as shown on your pictures.
I believe the 51890 is the same as the 12-15 civic si sedan and 51891 is the same as 12-15 civic si coupe
I wonder why H&R website says 51890 but acura of glendale installed 51891?
Any thoughts?
Just want some clarification before purchasing.
Old 07-06-2017, 03:51 PM
5th Gear
kiwigummy's Avatar
So it seems like there is nothing on the market that is specifically designed for the 16+ ILX... I called Eibach earlier and they mentioned they are currently developing one for 16+, however, no one knows when the product will actually be available.
Old 08-02-2018, 09:32 AM
davidlstewart's Avatar
I may have very easily missed someone answering, but is there a "good" brand out there with coil overs for the 16+ years. I have a 17 and am looking for a decent coil set up again I may of easily missed someone answer this already but I didn
t see the answer I was looking for.
Old 08-02-2018, 01:27 PM
visi_d's Avatar
17x8 40mm offset with 235/45/17 tires Lowered on Tein S-Tech springs
That's an aggressive drop. Says 2" drop for those D2 Springs plus the extra few mm once they settle. I lowered mine on Tein S-techs and i think its pretty low. I wouldn't be surprised if you dont rub with any aftermarket wheels wide/bigger offset.
Old 08-14-2018, 09:45 AM
Any idea what those wheels are? I love them
bluetl04
12-24-2015 10:34 AM
CU2_Ang
12-06-2015 02:40 PM
Typer0817
11-03-2015 09:29 PM
gtdrake
ILX
40
11-02-2015 06:55 PM
c0mikal
10-25-2015 03:07 AM
Quick Reply: 2016 ILX lowering springs(informative )
