Do I need Xenon?
Old 06-08-2017, 07:28 PM
5th Gear
sherv's Avatar
Do I need Xenon?
I need to replace both headlights, but I was wondering if I could cheap out and get the halogen ones instead of the OEM HID lights?
Will the plugs fit, and everybody's happy?
Old 06-08-2017, 07:29 PM
Received 8,575 Likes on 6,626 Posts
No... That's not how it works. You have HID bulbs projectors and ballasts. You can't just swap halogen bulbs in there.
Old 06-08-2017, 07:30 PM
Unless you men replacing the entire headlight assembly? You'd have to figure out which harness to get to replace the wiring for halogen bulbs as opposed to HID
Old 06-08-2017, 07:38 PM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
OP - Why would you want to downgrade? Any why do you need to replace already on an ILX?
Old 06-11-2017, 04:34 PM
Chrifff's Avatar
I believe it is possible to change out the OEM HID kit, however you will need to remove the ballast and find a way to match up the connector to a typical halogen 9006 bulb - This is a pretty big task as you first need to remove the front bumper to remove the head light assembly then you will need to unscrew the white cap behind the assembly to gain access to the ballast and the bulb. (see attached photograph).
I agree with NBP04TL4ME.... I don't know why you would rather replace HID's(Xenon) with Halogen bulbs. The HID (High Intensity Discharge) bulbs run a brighter spark than a filament that glows hot in a Halogen bulb with Halogen gas which burns yellowish opposed to Xenon gas (inside HID's) which burn whiter and brighter. A typical HID set up runs close to double the lumens and approximately twice the distance opposed to halogen bulbs.
Old 06-11-2017, 04:45 PM
Chrifff's Avatar
Oops sorry the ballast is the silver box located below the large white plastic screw cap. You can see the black connector plug which is not the typical connector for a halogen bulb (the wires to the actual HID bulb are accessed above the ballast).
Old 06-24-2017, 09:08 AM
Mprotege92's Avatar
HIDs FTW. No reason to downgrade..
MisterABdub
03-21-2017 10:44 AM
vegasmartin
03-20-2017 12:38 AM
vegasmartin
03-17-2017 03:14 PM
Yaseen Gabr
03-11-2017 04:25 PM
chawdhry
12-04-2016 05:30 PM
Quick Reply: Do I need Xenon?
