Honda Accord 19" on the TLX?
Old 09-14-2016, 11:21 PM
8th Gear
Fadij's Avatar
im about buy 19" Honda Accord factory wheels. I have 2 questions, first is would they fit? Second, how would they look? I can't find a pic of the flx on factory 19" accord rims.. I'm thinking I'd bet better ride quality than aftermarket 19" rims.. what do y'all think?
Old 09-14-2016, 11:38 PM
dezymond's Avatar
1. I don't know, check the specs.
2. It's up to you, your money and your personal preference. There are quality aftermarket wheels out there, but if you want to stick with OEMs then more power to you.
If you're talking about the Accord Sport wheels, good choice, they're a good looking wheel.
Old 09-15-2016, 12:27 AM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
I don't see why not.
Accord:
19x8.0 +55 , 5x114.3 , 64.1mm center bore
TLX (depending on trim):
17x7.5 +50 , 5x114.3 , 64.1mm center bore
18x7.5 +50 , 5x114.3 , 64.1mm center bore
19x8.0 +50 , 5x114.3 , 64.1mm center bore
If the Accord looks good with them, then I'd imagine the TLX will look good.
1) No TLX owner has them yet
2) No TLX owner that has them has posted pics
3) Try searching for TLX and not FLX
Why do you think 19" Accord wheels will ride better than aftermarket 19" wheels? They're both 19". I could maybe see it giving a better ride if the aftermarket 19" wheel was significantly heavier. But all things being equal, a 19" Honda Accord wheel will ride the same as an aftermarket 19" wheel.
Old 09-15-2016, 01:03 PM
MonsterZero's Avatar
Will the TPMS be compatible?
I know 2013 and up Accord uses a TPMS in the suspension.
I don't know if TLX uses the same. I think TLX still has sensors mounted in the wheels themselves.
I would like to know if anyone can clarify. The 2016 Accord sport has sexy wheels!
Old 09-15-2016, 01:06 PM
Received 16,260 Likes on 11,971 Posts
^you can wrap a TPMS sensor along the barrel of the wheel if you must have too.
MonsterZero (09-15-2016)
Old 09-16-2016, 01:29 AM
8th Gear
Fadij's Avatar
doesnt the tlx have tpms?
Old 09-16-2016, 11:48 AM
_
AZuser's Avatar
Yes, it does. All cars starting in, I think, 2008 need to have TPMS. It's a federal requirement.
What MonsterZero was asking is if the sensors on the TLX are indirect like on the Accord. They are not. TLX sensors are direct.
Tire Tech Information - Tire Pressure Monitoring Systems (Direct vs. Indirect)
DIRECT VS. INDIRECT
Direct Systems attach a pressure sensor/transmitter to the vehicle's wheels. An in-vehicle receiver warns the driver if the pressure in any tire falls below a predetermined level. Direct systems are typically more accurate and reliable and most are able to indicate which tire is under-inflated.
Indirect Systems use the vehicle's anti-lock braking system's wheel speed sensors to compare the rotational speed of one tire versus the others. If a tire is low on pressure, it will roll at a different number of revolutions per mile than the other three and alert the vehicle's on-board computer. Indirect systems (except for the TPMS on several 2009+ Audi models and 2010+ Volkswagen models) are unable to generate accurate readings in cases where all four tires are losing pressure at the same rate, such as the effects of time and temperature.
Old 10-24-2016, 07:58 AM
Styl1n
kuzdu's Avatar
i drove the V6 touring this weekend and it felt a bit heavy, could of been due to the 19 inch wheels. they do look nice
Old 10-27-2016, 09:42 AM
F23A4's Avatar
Received 1,659 Likes on 926 Posts
I'm also planning to purchase 9.5G Sport/Touring wheels for my V6 FWD. Tight looking setup for OEM.
Old 08-06-2017, 04:49 PM
78calikev's Avatar
2016 V6 Base w/ accord sport wheels
TPMS Sensors installed. Fitment is good but the ride is a bit harsh compared to stock.
The following 4 users liked this post by 78calikev:
Fidel CashFlow (08-06-2017), hadokenuh (08-07-2017), honda_nut (08-07-2017), teelx2015 (01-02-2019)
Old 08-06-2017, 11:32 PM
Fidel CashFlow's Avatar
Thanks for posting pics!
Old 08-07-2017, 06:51 PM
dezymond's Avatar
Looks pretty good!
Old 02-09-2018, 09:51 PM
Bo_vo08's Avatar
I literally was just talking to my brother about these wheels, I think it looks really really good, how did you get the sensors installed and to work? And if you have more pics please.
Old 02-09-2018, 10:05 PM
Flipster23's Avatar
Received 2,334 Likes on 1,962 Posts
Don't look good IMO.
Looks better on an Accord.
Old 02-10-2018, 08:38 AM
I'm assuming you take tlx tpms and install them like regular
Old 02-10-2018, 04:57 PM
78calikev's Avatar
I bought OEM sensors and had a tire shop install them. When I get a chance, ill take a couple more pics.
Old 03-01-2018, 09:10 AM
boe_d's Avatar
I ended up getting the EX-L last night. I tried out the Touring but HATED the 19" wheels - loud as hell and unforgiving. I was going to not buy the car all together until I took the EX-L out and it was really pleasant. I was very tempted to get the Audi but I was too much of a sissy to risk getting a car with a lot of maintenance. They may not be bad any more but I know people who have just 4 year old Audi's and they bitch about the repairs/maintenance a lot. Maybe in another several years Acura will have a car I crave (Nice looking, latest tech, hybrid with decent acceleration 0-60 in 7 seconds or less, and great gas mileage) but until Lexus or Acura releases something that really shivers me timbers I'll keep the Honda for now. I prefer the seats in my old Acura but other than that it is a very nice car.
EE4Life
04-01-2024 09:42 AM
chrisdonnelly
01-19-2017 10:23 PM
EE4Life
06-27-2016 06:19 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: Honda Accord 19" on the TLX?
