Front Strut Brace 5G TLX, 9G Accord compare
Old 05-12-2017, 12:28 AM
UA8
UA8's Avatar
Guys, I am doing a bit of research. I work for Ultra Racing USA, the Malaysia chassis brace company.
I am trying to figure if the current OE tower braces from the 9G Accord is the same as the 5G TLX, disregarding the part numbers listed.
**15-17 Accord V6 (T2A)**
74180-T2A-A01
FRONT TOWER BRACE
**15-17 Acura TLX V6 (TZ3)**
74180-TZ3-A00
FRONT TOWER BRACE
2016 Accord V6 9th Gen.
2016 Acura TLX 5th Gen
Old 05-12-2017, 12:36 AM
UA8
UA8's Avatar
Ultra Racing tower braces.
These images are from customers who installed on a 9G Accord.
Customer powder coated his brace.
Old 05-15-2017, 11:50 AM
sinistah89's Avatar
Hm I would assume so but not sure, I can be a tester for a discounted price haha
Old 05-19-2017, 11:32 AM
blah blah blah
99CL's Avatar
The bar shows 74183TZ3AA010 on my car
Old 06-17-2017, 12:22 PM
UA8
UA8's Avatar
PM me, intetested.
Old 06-22-2017, 03:43 PM
ryguyGTSK's Avatar
if you need another tester im here
Old 10-30-2017, 03:27 AM
sillyjav's Avatar
I’d be willing to test as well.
74180-T2A-A01
FRONT TOWER BRACE
74180-TZ3-A00
FRONT TOWER BRACE
Old 02-10-2018, 04:36 PM
dsquire's Avatar
Any updates on this?
I just got a 2018 TLX with V6 SH-AWD and I'd be interested in a FSB upgrade
Old 05-04-2018, 03:19 AM
UA8
UA8's Avatar
SORRY IT TOOK US OVER A FEW FREAKING MONTHS.
Here are the results.
2016 Acura TLX using a 9th Gen Honda Accord Ultra Racing strut brace
Old 05-04-2018, 03:22 AM
UA8
UA8's Avatar
What did fit was the mid 4 point brace
Acura TLX 2015-2018
Old 05-04-2018, 11:07 AM
blah blah blah
99CL's Avatar
Did the 4 point brace break? The photos you posted with it on the floor is missing the mounting points. I will also assume the front strut bar could fit but it missing one of the mounting points.
Old 05-16-2018, 12:56 PM
noclue02's Avatar
any updates on this? I am looking for an upgrade to my 2016 4cyl.
Old 09-28-2018, 03:41 PM
UA8
UA8's Avatar
Sorry the update on the front strut brace. The person who tested was "David Squire" who I think is on this forum.
Ultra Racing said that we could get the braces dialed in if we could get a minimum start order of 10 users interested in the project. AKA "Group Buy"
Tested on 2017 Acura TLX AWD, using the 9th Generation Honda Accord.
Made the new mounting points to the Ultra Racing strut brace. Lefts Side
Right Side.
Works with slight mods to mounting points.
Old 10-01-2018, 12:47 AM
noclue02's Avatar
Does it have any clearance problem with the hood? Any noticeable different? I'm down for the front and the lower brace if there are no problem for the TLX
Old 10-01-2018, 11:29 AM
dsquire's Avatar
Mods to the 9G FSB involve marking & drilling 1 new hole to each side of the brace, all told it took me under an hour.
No issues with hood clearance on my '18 TLX, improves body roll and stability, especially at highway speeds.
My approach:
Find the strut bolt that doesn't have a corresponding hole in the brace and coat the top of that bolt with lipstick.
Now place the brace over the other pre-existing holes, carefully resting it on top of the bolt with lipstick and pick it up in as vertical a manner as possible. I had a friend help me with this as the bar is a bit clumsy to position accurately by yourself.
This will result in a blob of lipstick being placed on the underside of the brace exactly where you need to drill the hole, I used a sharpie to draw a circle around the lipstick.
Then drill a 1/2" hole (I used my drill press for this) where you've marked the bar with the sharpie and fit the brace.
You may need to use a small round file to get the bar to fit precisely, but if you were careful when you placed the bar over the bolts this shouldn't be a significant effort.
There may be a better way to do this (substitute beeswax for lipstick ...), but this is very doable given care is taken with the initial marking of the hole.
Old 10-04-2018, 03:51 PM
noclue02's Avatar
My approach:
Thanks for the info, that's good to know. Put me down if there is a group buy . I am also interested in the 4pt brace as well =)
Old 10-04-2018, 04:02 PM
dsquire's Avatar
I test fitted the 9G Accord 4-point mid brace and it does Not work for the 2018 TLX.
The Shape, Dimensions, and hole placement are all out
Old 10-05-2018, 09:49 AM
noclue02's Avatar
Oh darn, I thought the picture was mentioned it fit the TLX as well. I guess I misread that lol.
Old 10-08-2018, 11:17 AM
dsquire's Avatar
That looks to be a FWD TLX in the pictures.
I have the 2018 SH-AWD and it didn't fit my car.
Old 10-31-2018, 06:16 PM
sillyjav's Avatar
I’d be in for a group buy, mines a ‘15 v6 SH-AWD though.
Old 01-24-2019, 12:31 AM
UA8
UA8's Avatar
Done, got it all squared up
Introducing Ultra Racing TLX strut bracing
Old 02-07-2019, 03:17 PM
Mcfly's Avatar
How much is this new brace and where can we purchase it? I have a '18 AWD will this fit?
Old 06-08-2020, 10:28 PM
noclue02's Avatar
what is the torque spec for the front tower bar?
Old 06-10-2020, 01:07 AM
noclue02's Avatar
Installed this strut tower earlier today, noticed a bit better when driving in a circle lol. I just noticed tonight that my hood is slightly push up a bit where the bar meet the hood. Is this normal or is there a way to adjust this? I included a picture (copied from above for reference), where the red circle, I had the nut bolted back on, so the base of the strut tower is sitting on top of nut. Should I leave this unscrew or not? I am not sure if I leave this nut unbolt, would it be ok?
