V6 cams
Old 03-13-2018, 02:27 PM
ultrapogi's Avatar
V6 cams
I was looking at Bisimotos website the other day and noticed he does regrinds for j series motors. His stage 1 gives about 10% gains. I know this is hypothetical and most people in this vehicle probably would not want to attempt it till the TLX was paid off or as a project car but just something fun to think about. Brand new stock cams can be bought for $400 then sent in to Bisimoto for the regrind $850. Add on the stiffer springs and titanium retainers $500, add on a j37 manifold and throttle body $500 use Ktuner to tune and with a raised limiter and valve rain going up to maybe 7500-8000rpms. Probably about $3000 all bought and installed. A little more and one could rig up a turbo though. Just a fun idea.
Old 03-13-2018, 02:29 PM
Received 16,260 Likes on 11,971 Posts
that's why you buy a beater honda to try this on.
fuck up a $40k car while still paying for it....and you'll just have a cool TLX shell that you're still financing.. until you swap in used motor...
then the value of the car has gone down and hope to god you're not underwater...
but you're right! it's fun to think about
AcuraPrincess (04-02-2020)
Old 03-15-2018, 03:32 AM
NBPaspec's Avatar
As an alternative, I would look into trying the RLX camshafts. That engine makes 20 more hp using the same compression ratio, same intake manifold, same (intake only) vtec system. A lot of that power is probably from the cams.
The valve springs are the same parts as the TLX so you don't need to upgrade them.
Old 03-16-2018, 07:32 PM
ultrapogi's Avatar
That sounds like a great idea if I wasn’t so scared to try it out. I will keep that in mind for the future but your right that is probably the most reliable method. Maybe when it comes time to change my timing belt I will swallow the lump in my throat and do this at the same time.
Old 03-18-2018, 11:34 PM
ultrapogi's Avatar
I just checked an Acura parts store and the part numbers are the same for the RLX and TLX for the following
Throttle body
intake manifold
cylinder head front and back
valves
springs
block
pistons
The crankshaft, rods and cams seem to be the only different part numbers so yea just dropping in the cams would probably (think of them as the modern Type S cams) make a difference. I know with the old J series you could drop in type S cams and make power with out a tune. I wonder how well it would work with the newest engines. I don’t have any K-tuner dealers in Utah where I live so the closest area would be Las Vegas. Maybe they will make a base tune one day. I asked hondata just the other day as well as 2 years ago if they plan on tuning the TLX and they said, “no plans”.
Old 12-03-2019, 04:46 PM
Troncoso51's Avatar
Anyone try this out yet?
Old 12-03-2019, 05:25 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
a guy tried some cams that were reground and found that they were out of spec causing issues with the J-series.
Old 01-29-2021, 09:31 PM
REGULAR RU's Avatar
I feel like the RLX cams would be in spec with the engine since it is the same engine just different cams..
Old 01-29-2021, 09:32 PM
REGULAR RU's Avatar
i_love_cars
158
02-15-2019 08:24 PM
michbroo
05-17-2016 05:54 PM
NBPacuraTL
22
11-29-2008 02:20 PM
allmotor_2000
04-29-2003 06:27 PM
hungy
10-13-2002 06:49 PM
Quick Reply: V6 cams
