Crossed drilled rotors?
Old 03-31-2015, 11:19 PM
ISM Gray's Avatar
Hi everyone, I've had my TLX for a few months now and I've already had the rotors resurfaced. I don't want to go through what I what I experienced with my 2003 type S. Non stop warped rotors... I eventually found cross drilled and slotted for it and this alleviated the problem. Have any of you found an upgrade for 9AT?
Old 04-01-2015, 10:22 AM
Received 16,260 Likes on 11,971 Posts
^drilled rotors will crack. it's just the nature of the beast with multiple closely drilled holes taking away surface area.
2nd of all; warped rotors is a misnomer. it's actually pad material built up on the rotor.
turning/machining will alleviate the un-even-ness of the pad deposits.
slotted and drilled rotors are PURELY aesthetic and do not add any function
NBP04TL4ME (04-03-2015)
Old 04-03-2015, 04:15 PM
Former Sponsor
ExcelerateRep's Avatar
I looked into it, and Stoptech offers their cross drilled+slotted rotors for the TLX. They don't have them in stock at the moment, but we can get them shipped out in about 3 to 4 weeks. Shoot me a PM if you have any other questions!
Old 04-03-2015, 05:44 PM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
I might consider slotted, but would never do cross-drilled for the reason justn mentioned.
Old 04-03-2015, 05:53 PM
i'm running slotted rotors; but i dont think it helped with stopping distances....
Old 04-04-2015, 12:00 AM
Treblig's Avatar
I'm running cross drilled and slotted rotors, can't say that stopping distances have been improved either. However, the brake pads certainly feel like they "bite" harder.
Old 04-04-2015, 10:35 PM
Ero
Ero's Avatar
Slotted rotors will probably eat the factory pads for dinner
Also OP, I had that same generation TL-S but an 02...Only time it warped rotors was when I bought crappy, but expensive 'top of the line' ones from Raybestos.
I swapped them out for Bosch rotors + akebono pads and problem solved forever.
Speaking of which, what the hell is the stock rotor/pad combo on TLX V6? I'm thinking of getting some 'bitey-er' pads!
Old 04-11-2015, 09:07 PM
BellaTLX's Avatar
Better brakes would be great.
Old 05-24-2015, 12:08 PM
slats's Avatar
Drilled and slotted rotors do serve the function of keeping your rotors cooler and allowing outgasing of the pads which eliminates float.
What I can't figure out is why the TLX has a 19' longer stopping distance from 70 than the 328i which shockingly has smaller rotors both front and rear. Maybe it's the tires?
Either way I plan to do a brake upgrade if I buy the TLX. Drilled/slotted rotors at minimum but possibly some sort of upgrades calipers as well
Old 05-26-2015, 07:24 AM
Treblig's Avatar
Pads could be a contributor.
Old 05-27-2015, 01:38 AM
accord1999's Avatar
I think it's a significant contributor, there are C&D instrumented tests of 3 and 4 series with all-season tires and they have noticeably worse braking performance as compared to those equipped with summer tires:
2012 BMW 328i Sedan Automatic Test ? Review ? Car and Driver
2014 BMW 335i xDrive Gran Turismo Test ? Review ? Car and Driver
2015 BMW 428i xDrive Test ? Review ? Car and Driver
I really wish that Acura had summer tire package though so the car magazines could do a test on it just to see if there's an improvement in braking.
Old 05-27-2015, 11:15 AM
sixkplus1's Avatar
I've traditionally never liked factory pads. Or at least I've never owned a car built well enough from the factory with proper pads. I would purchase upgraded pads and go from there.
Old 05-27-2015, 07:18 PM
BellaTLX's Avatar
This guy again:/ Sure haus. Whatever you say. Purely aesthetic LOLZ OMG HAHAHAHAHAHAHAHAHHAJA
Old 05-27-2015, 07:32 PM
musty hustla's Avatar
I used to have cross drilled and slotted rotors, I didn't like the sound they made. I reminded like some softly shushing me in a library.
Old 05-27-2015, 08:11 PM
NBP04TL4ME's Avatar
what did I miss??
Old 05-28-2015, 09:41 PM
csmeance's Avatar
Received 1,987 Likes on 1,411 Posts
Float used to exist with old binding material outgassing when the pads got hot. Newer pads don't have any such gassing.
Slotted rotors help with the "bite" of the brakes and I recommend them for the front rotors. If you put it on the rears, you'll be going through pads on the rears faster than the fronts, although the stopping power added is great.
Cross-drilled are either a hit or a miss, they are used in applications where weight is crucial and fast cooling is needed IE racing. 98% of drivers won't need cross-drilled rotors
Get some good pads, Racing Brake makes some great pads and rotors. I've had the same set on my 3G TL for almost 130K without needing them resurfaced. I had the factory ones resurfaced 2x by 60K miles.
I put a slotted set on my MDX and it helped out a lot too!
Old 05-29-2015, 06:42 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
what did I miss??
justnspace insulted his love for plastidip. got butt hurt.
https://acurazine.com/forums/photogr...x-tech-930970/
NBP04TL4ME (05-30-2015)
Old 05-30-2015, 09:40 AM
NBP04TL4ME's Avatar
Looks like one of the Mods had enough as it looks like he was banned.
Old 01-12-2016, 05:37 AM
rocket_pup's Avatar
Cross drilled rotors just shred OEM brake pads, and have a highly likelyhood of cracking. Slotted may be a little better, but still shaving them.
I don't think putting new discs on is of too much benefit unless you'r going to track the TLX, and then I would consider a (big) brake kit instead.
OEM brake calipers are 2 piston, right?
Old 03-22-2016, 12:52 AM
K3RMiTdot's Avatar
got slotted for my old car useless. cant even remachine them
Old 03-23-2016, 12:02 AM
csmeance's Avatar
Slotted rotors can be resurfaced! Most shops don't want to do it as it wears down the machine much more than regular rotors.
Old 03-23-2016, 01:29 PM
rocket_pup's Avatar
Unless you autocross or track, cross drilled / slotted rotors are a waste of money. Same for a BBK. For everyday driving, it's best to stay with Honda OEM parts, IMO.
For the TLX, I think the safest thing to mod is the suspension/tires/wheels and interior.
A while back I tried "upgrading" the rotors and pads with Brembo solids and semi-ceramic pads... worst mistake of my life. The squeeking would never stop. I went back to OEM, and no problems at all.
Old 03-23-2016, 03:34 PM
csmeance's Avatar
Semi-Ceramic pads are the issue! Metallic pads are terrible at keeping quiet!
Brake upgrades can be terrible or great depending on the quality of parts used. Cheap no-name, no research parts are going to deliver terrible performance.
Old 06-07-2017, 01:29 PM
Former Sponsor
We sell tons of StopTech axle packs, rotors, and pads; I'd say about 95%+ of people have never had an issue with them!
Drilled and slotted rotors are mostly for ascetics, but not entirely. They allow some heat to get under the pad which means less brake fade, but brake pads really play a big part in how your brakes feel. Switching to a bite-ier pad (wether it's on a blank rotor or a drilled/slotted rotor) will always offer you a noticeable performance increase, and to really see a performance increase out of the rotor you'd need to increase size so it has a higher heat capacity.
I tend not to recommend the drilled rotors to people unless they're going on a designated track car. Track cars tend to have parts refreshed more often, (sometimes before the old parts are at the end of their life) and since drilled rotors are technically the weakest, and can be somewhat prone to grooving; it's better to change them at a shorter interval just to make sure you don't end up with a rotor in rough shape that eats through pads.
You can see all of our brake products here: Brakes - Excelerate's Honda & Acura Store - Japanese Performance Specialist
Feel free to send me a PM if you need help with something or would like a quote!
08_UA7_Gr33k
02-11-2016 02:17 PM
blacktsxwagon
10-27-2015 10:12 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
Quick Reply: Crossed drilled rotors?
