TLX Speaker sizes?
TLX Speaker sizes?
For those that already own the tlx. Does anyone know what the tlx speaker sizes are for the base model? I Pre-ordered mine, but i'm trying to buy things ahead of time for my audio build.
Link above was truncated when pasted. Here's the breakdown:
2 hybrid titanium dome tweeters
Three 8 centimeter Super Dynamic Range (SDR) speakers with double-press polypropylene cone, providing low distortion and extended bass.
Four 17 centimeter Super Dynamic Range (SDR) speakers in the front and rear doors featuring extremely lightweight designs.
One 20 centimeter Super Low Distortion Driver (SLDD) Subwoofer with extended bass response to 20 Hz.
DSP Multi-Channel Power Amplilfer with 490 Watts of system power.
The system is made by Panasonic.
well I finally got my tlx friday.
The TLX sound system consists of 10 speakers of for the upgraded ELS system
There are four 6.5" speakers (front doors and rear deck)
There are two 1" tweeters
There is one 8" inch subwoofer (very underwhelming)
There is one 3" inch center speaker
There are two 3" inch speakers in the rear doors
The Base model just has the 4 (6.5" speakers in front and rear deck, 2 tweeters, and the sub)
If the sub is the only real weakness, I wonder if that should be my first upgrade. Could I get fix this problem with $200 at Car Toys? Or would I also need a better amp to go along with it?
I'd rather not screw with wiring, amps, etc, but a higher quality sub would be no big deal if that's all I need. I don't need crazy thumping like a teenager, but I want it to at least be in balance.
i mean it's your own personal preference, but problems you will run into is that the stock amp of the car doesn't send enough power to the subwoofer. So even installing a more powerful 8inch sub i don't personally think would solve the problem. May need some form of an amp to add to increase the power.
I just don't know enough about audio components to figure out the weak link. Off the top of my head, 490 watts (current ELS amp setup) sounds like plenty, but 8" is on the smaller side. I wonder if the issue is just that the sub needs to be bigger? Also, I don't really know the quality of the components. Traditionally, it seems like even upgraded stock stereos tend to be poor quality components. I wonder how the 8" ELS sub compares to the typical quality you'd see at Car Toys for $200... My guess is it's a lot worse.
xiaosongz (09-30-2014)
That is definitely true about the stock speakers. Only getting about 20watts rms to each of the 6.5" speakers. Just isn't enough power. I changed out the rear deck speakers which wasn't too hard.It made a nice difference so far. Will be adding front door speakers tomorrow and then adding an amp for the speakers and then completely getting rid of the 8inch subwoofer and putting in an aftermarket sub. I took the 8inch subwoofer to car audio shop and he basically laughed at it.
Interesting, so you're saying you have the ELS system and these are the upgrades you're planning? If the amp in the ELS is 490 watts, that ought to be an average of 49 watts per speaker (10 speakers), which is not too terrible. In fact, it's probably more than 50 watts each for the larger speakers, as the tiny tweeters would be less. Are you sure a new amp is needed?
I want to know what level of impact an upgrade would have on my car. For example, I don't like the idea of replacing my rear deck with a custom speaker box, nor of having a massive boxed subwoofer taking up space in my trunk. Could you cram a 10" sub in the current rear deck setup? Or just a better quality 8" sub? I'll be very curious to see what you come up with.
(Basically this means that if the system was 100watts at 7 speakers and the next 3 speakers were 10watts each the system is now 130watts, but amp isn't stronger)
Hence i changed rear deck speakers and front door speakers and i'm adding an amp to feed it more power to have a cleaner, crisp, and louder volume.
The stock sub woofer can't handle that much power and the stock amp just doesn't send enough power to the subwoofer either. i do think that upgrading to a stronger 8" subwoofer could help but wouldn't make a substantial difference.
I thought about replacing all the speakers and sub after couple months driving. After reading and asking questions, I ended up disconnecting the stock sub, added an amp and a 10in sub. imo, this is the quick, easy way to add some bass into the TLX. And with the ELS system, the external sub makes the whole car sounds a lot better.
Mugen TSX
Eastern Canada
09-16-2015 09:52 PM
Pegon95
09-15-2015 01:54 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
