A-Spec Brakes :-/
#161
EBC Redstuff
DP31753C (I believe these are the fronts)
DP33018C (and I think these are the rears)
These remind me of the Brembos that were on the 3G Type-S I can't recommend these enough, but on silver wheels there will be visible dust.
#162
I just do oil changes when the car "tells" me to do them, after hitting the 15% oil life left warning. I do feel like that happens sooner than it should, for synthetic oil. I guess they just use a "blend" though, not full Synthetic? I go do the dealer and they use the OEM specified "Acura brand" oil. I did read that the oil filters are actually quite good, better than the orange Fram oil filters commonly bought at auto supply stores.
#163
Unfortunately a front wheel drive understeers like crazy and is extremely hard to slide the back out.
#164
Maybe so, but your tires won’t last nearly as long as a fwd car that isn’t sliding the ass end out
#165
But seriously... I can’t lie. Sh-AWD is bad ass.
#166
SH-AWD has matured nicely. In early iterations it only kicked in when only really needed, now it tends to be engaged even under mild acceleration or load. It is truly an under appreciated and under advertised feature that sets Acura apart from most of its competitors.
BEAR-AvHistory (08-26-2018)
#167
Received 2,599 Likes
Did a lot of drifting at the BMW performance drive school, 49 seconds on the Rat Race Vid, but can't really figure a reason to ever do it in my own car on the street. Kills tires & not all that great for the suspension.
For U turns I live close to a lot of old NC bootlegger roads but have never felt the need to a bootlegger U turn with big a** pine trees as curbs.
#168
For the U turn I goose the throttle just enough and slide it ever so lightly. While in the middle turn lane I have almost hit the curb on my front end from the wide turning radius doing a normal u turn. So the slight slide gives me enough clearance. I did it once right after a light rain without thinking and I almost slide right into the curb on the back end from sliding so far. Felt like I was in the movies! Dirt along the road throws in a little monkey wrench too. Dry pavement seems to be pretty predictable.
#169
The SH-AWD makes it easy to slide the back end around a corner. It also makes it much easier to do a U turn since the extremely wide turning radius The more practice I do the more comfortable I become and I figure out the limits of the car in a way to do it safely without loosing control. My sweet spot is driving in sport + then right before the corner drop it into paddle shifter 2nd and accelerate controlled through the corner.
#170
#171
#172
oh wow. I am by no means perfect but maybe I can see what I can do. I apologize for thread jacking slightly. Let’s get back to the red stuff breaks and if I am able to do that I can start a new thread.
#173
My SH-AWD experience is limited to the 2G RL, but driving it in the deep snow this past winter was a ton of fun. The car is super easy to control. Just mash the throttle and steer in the direction you want to go. And this was on meh Pirelli all season tires. No opposite lock, no throttle handling, no skill required. Just point and go.
But, to be perfectly honest, I’ve had similar experiences behind the wheel of a Subaru Legacy GT Spec B, and a WRX, in the winter.
#175
TacoBello (08-29-2018)
#176
Styl1n
You will be waiting a long time, my 15 TLX with 24K on it when I turned it in the brakes had plenty of life left on them.
EBC Redstuff
EBC Redstuff
#178
Very infrequently have I found that I don't like my brake pads...I've experienced brake fade before, and having a few vehicles I obviously feel different brakes on a day to day basis but I think it becomes the job of the driver to learn the vehicle and adapt and drive accordingly.
#179
Brain Fart already posted this earlier, DUH
Thought I would put this in. These are dirty pads Hawk HP+ combo performance street & track. Stop fast under 100ft from 70mph excellent fade resistance but dust quickly.
The bad news: About 2 weeks dail driving.
The Good News: A single wipe around with a dry paper shop towel.
Armor All OutLast Brake Dust Repellent. At this point did the normal spray the wheel with McGuires (sp?) wheel cleaner, hosed it off then a once over with a big sponge. Reparayed the repellent & hit the tire with some wheel black. Good to go for Cars & Coffee Saturday. About 20 minutes for all 4 wheels with no real labor.
#181
Quick update. 2K miles on the car about 1500 on the Red stuff pads. They are freaking amazing. I washed car 3 weeks ago then today and very little brake dust likley due to using the Amor All Brake Dust Repellent, it works great, my wife's 19 RDX with 890 miles had far more brake dust.
#183
Thanks for the recs on these. Will be ordering them soon. I can live with a little more dust if the pads are as good as you guys say, and nothing will be as bad as OEM Audi/BMW dust.
I've always felt that most Honda/Acura brakes weren't aggressive enough, and I've gotten intermittent vibrations with heavy braking at high speeds in the TLX from to time due to pad deposits. The PSS tires are so good, they really point out the brakes. Have about 4mm left on the stock front pads with 38k on the clock. Plan to swap pads to these at my next oil change. Love the PSS so much, think I may ditch the OEM Goodyears, and get some DWS tires for the winter on the stock wheels.
Let me know how it goes with the MDX, may consider the same for my wife's. What SUV couldn't use some better braking.
#185
Ditto here. 2700 miles on them and yeah they dust a little, but not noticeable on ASPEC wheels. Amazing pads, smooth grippy stopping power. I am loving my 19 ASPEC, I sure hope they don’t f up the 20.
#186
Thanks for the recommendation on the EBC redstuff pads; I really love them.
Had them on for a few weeks, and they are just better in every way performance wise. Can;t comment on dust due to all the rain we are having, but having owned BMWs and Audis, even with low dust pads, these are not even in the same league for dust.
With "spirited" driving, or repetitive high speed braking, you could just tell the OEM pads were at their limit. I wouldn't say my factory brakes were warped, but you could just tell the brakes went from being smooth to feeling much coarser which I attributed to very mild pad deposition.
With the EBCs, right off the bat, just on initial bite, the brakes are almost touchy in comparison. I've quickly become accustomed to them though, and really like having that additional stopping power right off the bat.
I haven't beat on them yet, as EBC recommends casual driving for their brake in procedure, but in local driving, and with a few instances of high speed braking, they stop much better in those scenarios as well.
In all scenarios, besides actual braking performance, the brake pedal feel itself is just so much better. I am super happy with these pads, so happy, that just behind getting rid of the crappy goodyears,this is the best thing modification/maintenance upgrade you could perform on your car. Really wish I didn't wait til I had 40k miles to swap them out.
These pads feel so good, I am definitely going to get them for the wife's MDX. Driving both cars back to back, I always felt like it didn't stop as quickly as I would expect, and had a more vague pedal feel than the TLX. That gap has only gotten bigger now, so definitely looking forward to some improvement,
The following 2 users liked this post by Mr Hyde:
BEAR-AvHistory (01-07-2019),
csmeance (05-26-2020)
#187
#189
Styl1n
#190
I just bought and had installed a full set front and back with some stainless steel brake lines. The braking power difference is...WOW. I can brake so much later into a turn. I am surprised at the difference is stopping power. This is definitely how the car should have come from the factory. These are the best set of brakes now that I have had on any vehicle that I have ever owed. Total cost was $800+ yuck. $500 for install but man what a difference this has made. I haven't even put them through hard testing to see their limits but so far I am extremely happy with the results.
The following 2 users liked this post by ultrapogi:
BEAR-AvHistory (08-03-2019),
Christopher. (08-09-2019)
#191
The EBC red barrels make a huge difference. I have 7500 miles and the brakes are great. They do dust a bit more than I would like, but the ASPEC wheels mask it well until it gets real bad. What needs EBC brakes is the new 19 RDX, I have never felt such soft uninspiring brakes in my life as the RDX. My wife's RDX has 10K miles and I hate driving it due to the brakes.
#192
So... I have a '19 3.5L V6 TLX SH-AWD Aspec on loan for about a week or who knows how long, until mine is done being fixed... So far, I prefer my FWD P-AWS TLX to this SH-AWD, but, that's because mine has "learned" how I like to drive and this hasn't yet (I presume that's why) and, I also have a Sprint Booster on mine. This one seems to have more of that "must rev up before you feel acceleration" aspect that I absolutely hate. I want to feel the acceleration WHILE the engine is revving up!?! I don't want to have the engine revving, meanwhile, I'm still waiting for the accel to kick in, wtf is that?!? Torque converter too sloppy or something? Slow clutch engagement in the automatic? I really don't know.
Strangely, also, turning of Traction Control on this SH-AWD has a much less noticeable effect than it does on my FWD TLX - once I do that on mine, I feel fully in control of the throttle, I can even burn out at will if I want (which I do not often feel like doing, just once in a while it's fun). So, yes, I have to be more careful not to slip my front wheels as you do not on the SH-AWD, but, it's not like it happens often against my wishes, I simply have learned how to modulate the throttle, use the paddle shifters, and my car feels like it has plenty of power and is decently fast off the line (though not like a RWD V8 of course).
#193
#194
I am pretty sure that they are all the same across the board at least on the V6. I contacted Chris at Xlr8 and told him what I wanted and he got everything set up for me and sent me an invoice and mailed it off after I paid for it. He made it really easy for me.
#195
Styl1n
Hope everyone is safe during these times. After 24k miles it’s time for me to change my ebc reds, they are low and ready to be swapped out for a fresh pair. I ordered another set and will be installing this weekend. I recently flashed my car with Ktuner….best thing I ever did and now I decided to change the brakes since it’s low and there is some extra power there. My lease is up in September but I may extend it to wait for the Type S.
csmeance (04-18-2020)
#198
#199
Styl1n
Finally swapped out my current EBC reds for a fresh new set, also changed the rotors I got regular Centric plain. As you can see from the pic the pads were pretty much done, I should not have waited so long but the rotors took over a month to come. Got about 24k miles out of the pad and it feels good again to get that Big bite back lol. I also bedded them after the install 6 stops from 60 to 15 so it's nice and coated.
#200
Where did you get your centric disks? I had them on my accord with akebono pads and LOVED the pairing.
