P0848-Powertrain
Old 06-08-2018, 08:23 PM
inmydream316's Avatar
P0848-Powertrain
I just got Engine Light code P0848-Powertrain on my 2016 RDX AWD with mileage 71,xxx
it says Transmission Fluid Pressure sensor/switch "B" Circuit High
i searched but it relates to 3rd gear pressure switch plate?
anybody have DIY or repair guide?
is this related to TSB: Torque Converter Lock-up Clutch?
part# and diy would be appreciated.
thanks
Old 06-09-2018, 08:44 AM
Brown13's Avatar
Try here: https://www.acurapartsnow.com/oem-pa...1hY3VyYQ%3D%3D
Old 06-09-2018, 09:11 AM
Brown13's Avatar
Make sure You check fluid level first.Then locate switch and check for damage or unplugged.If not,then buy switch.
Old 06-09-2018, 06:13 PM
Originally Posted by Brown13
You sure on part#??
when i see 2016 it has two different sensors are there.
Diagram#8 is located outside of transmission and diagram#7 is inside of transmission??? They have different part no.
Switch Assembly, AT Oil Pressure - Acura (28610-R36-004) Acura Parts For Less - https://www.acurapartsforless.com/oem-parts/acura-switch-assembly-at-oil-pressure-28610r36004
i am going to replave transmission oil first and see it solves problem. If not i will change diagram#8 sensors one by one.
Old 06-09-2018, 09:21 PM
Brown13's Avatar
If You compare both pictures,they appear to be two different transmissions.You will have to crawl under and compare images to Your transmission. Both images are for 2016 RDX AWD.
Old 06-09-2018, 09:22 PM
i already. Sensor is right next to drain bolt
Old 06-13-2018, 07:57 AM
ok. i changed transmission fluid and also changed transfer case fluid while i am changing.
of course it got smooth gear shift feeling and not CEL came on. so i will keep you guys posted for update.
it's possible to have CEL light on if lower transmission fluid? when i took out old fluid, i had about 3 Liters so i's about 0.1 L short from manual says but i doubt it will cause CEL to trigger.
hope everything is ok for now
thanks
Old 06-18-2018, 01:53 PM
here's an update. no CEL or strange feeling so i guess it was the fluid.
deepa1600
09-15-2020 01:27 PM
filo4u
1G RDX Problems & Fixes
09-08-2016 04:42 PM
darocc
4G TL Problems & Fixes
01-22-2015 07:22 PM
sankov7
09-13-2012 10:10 PM
gavriil
08-13-2003 11:34 AM
Quick Reply: P0848-Powertrain
