LED turn signals for rear - no resistors required
Old 08-14-2018, 12:13 PM
2021 RDX A SPEC
Acura604's Avatar
..as posted in the 3G RDX area.
Picked up a set of these for the 2G / 7440 bulb type. They have built in resistors so there is no hyper flashing.
BE WARNED - they are double...hell, maybe even triple the brightness of stock incandescent amber signals.
*I may tone them down a bit by covering up/sharpie some of the LEDs on the bulb.
you can order via Ebay but from China if you dont mind waiting 2-3 months for a possible lost shipment...
https://www.ebay.ca/itm/2x-Amber-No-...53.m1438.l2649
OR you can order from the USA via iJDM toy:
https://store.ijdmtoy.com/No-Hyper-F...s-p/20-095.htm
Attachment 98908
sathiyan (08-16-2018)
Old 08-14-2018, 12:39 PM
2021 RDX A SPEC
Acura604's Avatar
NOTE - for the 2G 2013-2015, you can ONLY use these at one end... or you will get hyper flash. so pick a side...front or rear.
Old 08-16-2018, 01:10 PM
sathiyan's Avatar
Nice. Just curious, Which one did you install? Since the specifications on ebay item is crazy 14000LM/140W vs 1000LM/24W in iJDM toy
Old 08-16-2018, 03:39 PM
2021 RDX A SPEC
Acura604's Avatar
got the ebay one... .which explains the crazy brightness....this is kinda good and bad when you think about it... considering they're so bright...great for safety if stuck on a dark road.
Old 10-13-2018, 09:55 PM
halfclueless's Avatar
Update does the LED still stabile with no hyper flashing?
Old 10-16-2018, 05:18 PM
2021 RDX A SPEC
Acura604's Avatar
still working 100%. used everyday since i got them.
Old 10-16-2018, 05:21 PM
2021 RDX A SPEC
Acura604's Avatar
i think these bulbs are identical.. the LM is incorrect.. i have 3 sets of these and compared them all from different brands... exact same brightness.
Old 10-16-2018, 05:30 PM
2021 RDX A SPEC
Acura604's Avatar
also installed in the CIVIC
InFaMouSLink
10-04-2016 05:56 PM
CryingMidget
11-13-2015 04:31 AM
EVOLICARUS
03-05-2009 08:11 PM
RedHOT411
09-13-2008 09:07 PM
nyclio
02-13-2008 10:10 PM
Quick Reply: LED turn signals for rear - no resistors required
