Oem front bumper
Oem front bumper
How much does an oem front bumper cost as I kinda smashed mine and need to replace it. Also how hard is it to remove old bumper and install new one?
I believe that the bumper i order will come not painted.
I would recommend you trying to go to a pick and pull (wreaker lot) hopefully you will find one of the same colors. The bumper is not all that hard to take off it just takes a little time, however you should pick up a "clip removal tool" for $10 (If not expect to break a few clips) or less at your hardware store first. The bumper has two Philips screws near each wheel well and I believe four 10mm bolts underneath.
The MuffinMan
09-27-2013 08:12 AM
82SADAT
03-14-2013 08:40 AM
