Im still fat(according to OP)
#521
You ever shit yourself?
#523
Received 2,773 Likes
i did once while deadlifting. It was bad. I pretty much packed up my stuff and left.
justnspace (03-08-2019)
#524
Before I head to the gym I now make sure to force out a shit and take a piss to clear things out.
#526
It's worse on sumo since you spread your legs apart. Harder to squeeze to hold it in
#528
Considering a sanctioned meet in February.
fvck it's expensive thou. $55 for the annual membership to USAPL, then $115 to register for the meet. WTF.
Mizouse (11-27-2018)
#530
Unless there's a ton of babes and prizes to be won.. then hells yeah brother
#531
Any updates? did you short circuit in December like I did. I was fitting into my thinnest pair of jeans before Thanksgiving and then....yeah. This past week, I leaned back out pretty quick. Got a compliment I lost weight but they probably got used to December fat me.
#532
I somehow fit into a pair of 30W chinos the other day. It was the highlight of my day. For the past 3 years I'd been wearing 32-33
Even sometimes had to use the hair tie trick for 31W pants. A girl showed me that if you looped a hair tie around the button, through the button hole, then around the button again, you could buy yourself another inch (if only it were that easy for other things)
Mizouse (01-11-2019)
#533
Definitely gained weight (read fat) between Thanksgiving and New Years.
bulked up to 208lbs
working on a cut again. It’s slowly coming back down.
gonna try hard to cut this year and get my body fat down.
last week I tested my max for my lifts to get a baseline on where I am for 2019.
Squat = 385. Probably could’ve gotten 390-395 but I jumped to try 405, was able to get out of the hole but then I died.
Bench = 260 (competition style)
Deadlift = 405 (tried 420 next but couldn’t lock out)
My deadlift has definitely been lagging and regressing since I changed my stance up 3 months ago.
2 weeks ago I changed it back to my old stance and I’ve started seeing some progression.
bulked up to 208lbs
#534
Goals for this year:
405 squat
unrealistic goals:
300 bench
495 deadlift
405 squat
unrealistic goals:
300 bench
495 deadlift
#535
I played with my form all last year and my lifts went down. My original form was always the best.
I won't even write my goals but honestly, this past year was to get leaner and healthy and mission accomplished. Passed physical last month including cholesterol which was the only outlier in the prior year. Probably will continue to focus on leaning out with the cardio after rather than going balls to the walls on weights.
My shoulder has been bothering me, I think rotator cuff so my bench has plummeted. I think the heaviest I hit last year was 275 but the year before that 330. Plus weight loss hurts bench a little. I can't keep up with these 20 somethings. I know one dude reps 405 bench like nothing and another was squatting 495x6. Don't think I can hit those without some serious gear so meh to that.
#536
Yea... there’s this Chinese guy I know at my gym.
hes probably 10 years younger than me but For his conventional DL...
He warms up with 3 plates.
Does 4 reps.
Goes to 4 plates.
Does another 4 reps.
And then bangs out a 5x5 at 495
and he doesn’t bounce the weights.
for bench he warms up at 2 plates and then does like a 5x8 at like 355
Does 4 reps.
Goes to 4 plates.
#537
He tells me sometimes he does 8x8 at 450ish for DL.
guy is a monster and can handle ALOT of volume.
#538
The kicker is he does this all the time while buzzed/drunk in street shoes and in jeans
#540
Ohh yea he does this all with no accessories.
No belt. No straps. No wrist wraps etc.
must be nice.
only thing for him is that is back squat sucks.
his max is 300. But that’s cause like 5 years ago he injured his back and has a mental block on squatting.
must be nice.
#541
im aiming for a meet in May.
Should be plenty of time to cut and build strength.
Maybe drop down to the 83kg (182.984 pounds) weight class
#542
Any of you guys have an Apple Watch and use a fitness tracking app for it? Mainly for weight lifting.
I don't want to carry a little notebook around to track my reps nor do I wanna dig my phone out every time. Narrowed it down to strong and gymaholic, will try something tomorrow
#544
I have the strong app on my phone but I don’t use it
i just record everything onto the stock Apple notes app.
I can’t wear my Apple Watch during my heavy working sets since I’m using wrist wraps or straps.
#545
I had an old Motorola 360 Smartwatch that I would wear while training. If I was doing something like light deadlifts or bar rows, it'd break off since your forearm expands a little when you squeeze hard and lift heavy shit. From then on, I take off my smartwatch to lift. The only apps I use are the timer and Spotify.
#546
One day I'll get back to the point where I need to wear my weight lifting belt and wrist straps again smol boi problems
I would remember my weight before, but as I'm just starting out again it's hard to remember all the exercises and rep weights and quantities.
The idea of a timer for the next set is nice too. I sometimes get distracted in a conversationor by eye candy and forget to start again.
#547
You'll be surprised how long people talk for especially a chatty dude. I typically take 3 minute breaks for the main lifts and even that might be enough time between the initial take off the belt, reset the timer, I'm tired rest, changing the weight, walk to the paper towel dispenser and back, roll on the roller to loosen up, change the song, put on the belt again, and get in position.
#548
Don’t feel like I’ve gotten much gains.
but I’ll be testing them next weekend with my gym buddies
also changing up my programming.
3x5 at 85-90% just isn’t enough volume.
gonna be doing a volume block. 4x8 at 75-80%
I’m aiming for:
S 395/400
B 265
D 430
I’m aiming for:
S 395/400
B 265
D 430
#549
Damn, still pretty impressive man.
I'm not dedicated enough, so I'll be satisfied with hitting the 500 lb club
A year or two from now might be different, but I'm aiming to go to the gym at least 3-4x a week, forever. I've only had phases where I would go 4-5x a week but only 6-12 months at a time.
#550
Holleeeee looking back at my old posts. I havent just plateaued.. I hit a damn wall.
My maxes are really close to my numbers from April of last year!
Currently:
S: 385
B: 260
D: 415ish (struggle bus with this one )
Anyways I’ve kind of noticed this so I’m reformulating my programming since I’ll be trying for a meet at the end of May.
Starting a volume block with 4 or 5 sets of 8-10 for about 1.5 months.
Then a strength block for a month.
then finaly hopefully a peaking block up until the meet
Gonna need more than a miracle to get my numbers up a significant amount by the end of May
went better than I expected, opening lifts were too conservative and felt really easy so I bumped up my later lifts.
Ended up with the following:
Squat: 172.5kg / 380.3lbs
Bench: 117.5kg / 259.04lbs
Deadlift: 187.5kg / 413.37lbs
Took in the 93kg weight class.
The guy that beat me was some crazy olympic lifter that decided to give powerlifting a try
Currently:
S: 385
B: 260
Just an update. Ive been getting heavier and fatter.. I've bloated up to almost back to 200lbs
anyways back in April I broke over the 1000lbs cumulative total.
1RM are:
Squat = 370lbs
Bench = 255lbs
Deadlift = 415lbs
Also signed up for self-sanctioned powerlifting meet in September.
Its basically following IPF rules but I don't need to be an IPF member nor wear a singlet :gheylaugh:
Gonna need to drop back down to 83KG to be more competitive
We'll see how that goes.
1RM are:
Squat = 370lbs
Bench = 255lbs
Deadlift = 415lbs
bulked up to 208lbs
bulked up to 208lbs
#551
Welcome to the club man. Same has happened to me. I pretty much played with form all last year. Haven't PR'ed in forever because I'm focused on bodyweight. Life gets in the way and we're natty soooo...
Mizouse (02-25-2019)
#552
Also watched a USAPL powerlifting meet on Saturday.
(my friend was lifting)
it was held at Dan Green’s gym.
Big punch to the gut seeing all those strong lifters in my weight class
There was a guy lifting in both the open and junior (19-23) division in my weight class (93kg)
he squatted 550, bench 450 and deadlifties 650
the meet im doing in May is being held there too
#553
93 kilos to lbs
Mizouse (03-05-2019)
#554
Switched up my programming to prep for the meat.
going to do a month of a volume block (yay 4-5 sets of 8-10 reps )
then a month of a strength block.
then a short peaking block into the meat.
im already on the 2nd week of Volume.
Yesterday for back squats I repped out a 4x8 at 295 pounds (weight is supposed to be 75% of max)
RPE felt like an 8.
Last week I did a 4x8 at 290 pounds. RPE felt like 9.5
i hope this volume pays off
RPE felt like an 8.
#556
bench last night felt great.
5x8 at 200lbs at RPE 8. Went smooth as butter. Went so fast my gym buddies thought I was doing speed reps
last week did 5x8 at 195, RPE 9.75
#557
Slowly losing weight too.
This morning I woke up at 196lbs. haven’t been there since around September
#558
Good shit Miz
I'm sure some days are fantastic and some days are off
Just keep at it.. right mindset.. I'd get into some yoga as well.
Keep shit even and probably help improve your strength and growth.
Read Goggins book if you haven't
It's reveals that you can tell that little bitch in your head to shut the fuck up and put out
Mizouse (03-06-2019)
#560
Yoga was incredibly difficult for me when I tried it with P90X. I'm about as flexible as a flagpole. I've never sweat so much without moving before.
