New England Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island & Vermont
Mid-state CT Mechanic?
Old 12-29-2017, 03:12 AM
'17 RDX Tech AWD - WDP
meburdick's Avatar
Looking for an all-around mechanic, outside of Honda/Acura dealership preferably to save a little money. Side work is fine.
Issue right now is pulsing front brakes, pads and rotors are new (ish). Would like an assessment of what’s going on at a minimum without the usual dealership line about how it needs unnecessary services that will total $1,000 plus.
I’ve had a couple of guys recommended to me that work out of their house, work at a friend’s shop, etc. and they’ve flaked.
Old 12-29-2017, 10:26 AM
6mt swapped..smart
AnthraciteTypeS's Avatar
Where in CT are you located?
Old 12-30-2017, 10:15 AM
meburdick's Avatar
I'm looking for a mechanic in the mid-state area. So, Middletown, Cromwell, Rocky Hill, Wallingford, etc. Those general areas.
Old 01-02-2018, 02:27 PM
6mt swapped..smart
I sent you a message.
Old 01-08-2018, 09:24 AM
meburdick's Avatar
Still looking to see if I can find someone that will have access to the various tools and such to turn rotors (if necessary - they are fairly new and should be able to be put on a lathe if something is a little out of true) and verify that the calipers are working properly. If anything is found regarding heavy wear or warping on the front brakes, I'm going to need to know details so I can pursue parts replacement under warranty (they aren't that old).
kajohnson
NY/NJ
03-21-2014 05:35 AM
rgn
05-16-2007 05:47 AM
Scrib
02-22-2003 03:45 PM
Quick Reply: Mid-state CT Mechanic?
