New England Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island & Vermont
Honda / Acura Techs in Metro Boston / Providence Area?
Old 05-14-2015, 03:05 PM
Stay Out Of the Left Lane
NBP04TL4ME's Avatar
Received 1,236 Likes on 1,023 Posts
I know there are some Honda / Acura technicians doing work on the side in some of the other regional forums. I was wondering if there might be some in the Boston / Providence / Worcester or even further out surrounding areas who might be looking for some extra $$$ outside of the dealership. Maybe some AZ members might know some that aren't members???
We used to have a neighbor who was a Nissan tech and he always had someone else's car in his driveway. I bet New England AZ members would be able to make good use of one.
Old 05-15-2015, 09:21 AM
Franchise1124's Avatar
There was a forum member in Manchester, CT (not sure where you are but less than 2 hours from Boston) that was a certified tech and doing work on the side. He did my TB/WP/etc and certainly knew his stuff. I can try and track him down if you'd like. Shoot me a PM and let me know
Old 05-15-2015, 12:16 PM
NBP04TL4ME's Avatar
Franchise is his AZ member name - 3rdGenHybrid? I have reached out to him in the past via PM when I needed some brake work. He answered me once but then went MIA. He got a very good recommendation from another member here on AZ, but like I said he went MIA. He hasn't been here on AZ in about 20 months.
In terms of where I am - I'm down in the Attleboro / Mansfield area and believe he was in the Windsor, CT area.
Old 05-16-2015, 04:05 PM
NBP04TL4ME's Avatar
Bump - Anyone else??
Old 05-21-2015, 06:32 AM
NBP04TL4ME's Avatar
Ttt
Old 05-21-2015, 06:43 AM
iSeeYouTwo's Avatar
What kind of work do you need done? I have a friend who is a Tech at Bernardi Honda on Route 9 (Natick Area) who does side work.
Old 05-21-2015, 07:24 AM
NBP04TL4ME's Avatar
We have three Acuras / Hondas in the driveway and it's good to have a good tech available from time to time where I can save some $$ vs. a dealer or even an indie shop and he / she can make some extra $$ on the side.
I'm sure other AZ members would be able to make use as well, not unlike - https://acurazine.com/forums/ny-nj-3...rth-nj-883797/
Old 06-30-2015, 06:57 PM
NBP04TL4ME's Avatar
To those that are interested, I think I have found the New England equivalent to Paul from Clifton, NJ (see link I posted above).
His name is Nick and is on the MA / RI border. He is currently a tech at a local Honda dealer and has worked at two Acura dealers, another Honda dealer and briefly at a Toyota dealer over the last 12 or so years. Last week he diagnosed and fixed an issue I have been having over the past year in what I thought was a suspension issue. Today he did rotors and pads all the way around on my wife's Lexus for less than half what the dealer quoted me. He is a really nice guy and looking to do some more work on the side. He can do general maintenance items all the way up to timing belts and larger repairs. He is a genuine honest guy, tells you what you need or don't need done. You can PM me for more details or reach out to him directly via email at : nmangz28@aol.com.
give him a try and you won't be disappointed!
Old 08-25-2015, 08:20 AM
NBP04TL4ME's Avatar
I apparently fat fingered Nick's email address above. The correct address is nmagz28@aol.com and if you would prefer to call or text him, his contact number is (401) 330-0535.
Franchise1124 (09-11-2015)
Old 09-11-2015, 05:38 PM
Just figured I'd check in on this thread as I'll be needing some work very soon. I'll drop your guy a line this weekend
Old 09-12-2015, 09:40 AM
NBP04TL4ME's Avatar
Sounds good. I don't think you will be disappointed.
Old 11-19-2015, 08:49 AM
NBP04TL4ME's Avatar
Going to have Nick mount and balance my new snows this week He also is going to take a look at my whiny power steering pump
Old 12-31-2015, 05:27 PM
NBP04TL4ME's Avatar
Had Nick do some maintenance on my daughter's CR-V today.
This is what he did for me:
Oil change.
Coolant flush.
Rear differential fluid change.
Replaced battery.
Now you can say or argue that all of this is DIY, but for his rates it doesn't make sense for me to do this on my own. I don't have to worry about the old fluids and over and above the oil change, he topped off all the fluids and set tire pressures as needed.
If you need anything done - you have to reach out to Nick just to get a quote. You won't be disappointed -
Old 07-10-2016, 06:45 AM
Novichek's Avatar
Hi, do you think your guy still does side work? I want to have my tsx looked at about high frequency rubbing noise at highway speeds. Is he good at diagnosis?
Thanks!
Old 07-10-2016, 06:51 AM
NBP04TL4ME's Avatar
He absolutely does. I have him lined up to do ball joints on my car - just haven't had the time to get my car to him. Give him a call/text and let him know you are from Acurazine and/or I sent you
Rob
Novichek (07-11-2016)
Old 07-11-2016, 11:16 AM
Novichek's Avatar
Rob
Will do - thanks Rob!
Old 09-23-2016, 05:15 PM
NBP04TL4ME's Avatar
My wife's Lexus ES350 had the common water pump failure on Monday. Wasn't positive that was the issue because it died / overheated on her commute home and by the time I got to her it was getting dark. I filled overflow bottle and radiator and got it to the local Toyota dealer. Surprisingly the dealer called us shortly after we got home and confirmed my suspicion that it was in fact the water pump. Total repair cost - ......$1040!!!!! I told them I needed to think about it. Texted Nick and said he felt he could save me some $$ but needed to get pricing on parts. He got back to me in the morning and said he could take care of the water pump, new serpentine belt, seals, thermostat and system flush all for $518.
Old 09-29-2017, 08:23 PM
NBP04TL4ME's Avatar
Visited Nick again today -
New Timing Belt
New Water Pump
New Belt tensioner
New Pulleys
New Drive belt
Oil Change
Quick visual inspection
Top off all fluids
+/- $400 in roughly 2.5 hours - can't beat that!!!
If you need work done on your Japanese car you need to reach out to Nick!!!
The following 2 users liked this post by NBP04TL4ME:
Franchise1124 (02-07-2018), jpxvboi9x (02-03-2018)
Old 02-03-2018, 03:15 PM
jpxvboi9x's Avatar
I also just went and saw nick and had my timing belt water pump tensioner and had fluids topped off. He does excellent work and very good price as well. I would highly recommend him and I travelled from Connecticut to get the work done at his house.
NBP04TL4ME (02-03-2018)
Old 04-30-2018, 10:53 AM
VT Skier's Avatar
Can anyone tell me exactly where (which town) Nick is located? Thank you.
Old 04-30-2018, 05:31 PM
NBP04TL4ME's Avatar
Nick is located in Barrington, RI, just off Rt. 6 near Seekonk. I sent you his contact info via PM. Let me know if you need anything else.
Old 05-02-2018, 11:15 AM
VT Skier's Avatar
Thanks Rob. I'll try to find one a little closer to Vermont.
Best,
Jon
Old 05-27-2018, 12:37 PM
kingofire's Avatar
Just had an oil change and a tire rotation completed by Nick and I can't say enough good things about him. Such a nice guy! Very professional and very thorough. Brought my own oil and filter and he only charged me $20 to do the entire job!
FYI, he is now working for Boch Toyota in Norwood and if what you need is just a simple job like an oil change he'll do it at the dealership but usually at the end of the day after he's done with work.
pawelTL6MT (07-13-2018)
Old 07-13-2018, 09:03 AM
pawelTL6MT's Avatar
So glad I just saw this. How can I reach him?
Old 07-13-2018, 09:25 AM
NBP04TL4ME's Avatar
I posted Nick’s contact info above in post #9.
He works at Boch Honda in Norwood on Rt 1, but lives in Barrington, RI.
I will send his contact info via PM as well.
Text/call his cell - you won’t be disappointed!
ssjkev16
03-08-2020 08:17 PM
csmeance
09-10-2018 09:15 AM
iRaw
ILX
09-05-2015 12:10 AM
asahrts
09-04-2015 05:55 PM
Quick Reply: Honda / Acura Techs in Metro Boston / Providence Area?
