New England Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island & Vermont
Excelerate Performance: Fall Specials
Old 10-04-2016, 04:01 PM
Former Sponsor
ExcelerateRep's Avatar
EXCELERATE PERFORMANCE
Fall SERVICE SPECIALS
What is a Timing Belt and why is it important?What is a timing belt? The timing belt is crucial to proper engine operation; the timing belt maintains synchronization and control of the timing components. Components such as the crank(s), camshaft(s) and operation of the valves to allow the proper amount of intake air and exhaust gas flow. Why is replacing your timing belt useful? The timing belt is a rubber product and resides in a sensitive environment where it experiences extreme heat cycles. The extreme heat cycles and constant tension. The heat cycles and tension cause the rubber to dry out and stretch. If this happens it can be catastrophic and cause complete engine failure. It comes highly recommended that one follows factory recommended maintenance intervals because if you wait too long you may wind up in a bad situation with an even bigger problem. We consider this preventative maintenance, replacing parts because it’s a problem.
Kit includes: Timing Belt, Tensioner Pulley, Idler Pulley (if applicable), Hydraulic Damper (if applicable), Water Pump and Gasket, Balance Shaft Seal (if applicable), Camshaft Seal
Comprehensive parts kit:
  • Hydraulic Damper – For applications requiring the use of a hydraulic damper, Pro Series timing kits contain an OE-quality unit ready to go. One less thing to slow you down.
  • Water Pump – An OE-quality water pump is included in all Pro Series timing kits, along with any necessary seals and gaskets. In selected cases, we even offer an option of metal or plastic impellers and a choice of housing or no housing.
  • Timing Belt – A durable OE-quality ContiTech timing belt is the heart of every Pro Series kit, and it’s covered by a written guarantee that matches the vehicle’s original service interval.
  • Idlers – All necessary idlers and pulleys for the belt path are included in Pro Series timing kits. OE-quality, of course.
  • Tensioner – A Pro-Series OE-Quality tensioner will keep the proper amount of tension on the timing belt system.
  • Cam & Balance Shaft Seals – The new Pro Series Plus kits add these critical seals to the already strong Pro Series parts list. (Recommended But Not Included – Additional Labor Also Required)
PRICING
  • VW TRANSVERSE 1.8T - 5.5 hours of labor - $799 - Kit includes: Water Pump with Metal Impeller, Timing Belt, Tensioner, Damper and Cam Seals. - (Interference Engine)
  • VW/AUDI LONGI 1.8T - 6.5 hours of labor - $899 - Kit includes: Water Pump with Metal Impeller, Timing Belt, Tensioner, Nut, Washer, Damper and Cam Seals. - (Interference Engine)
  • VW TRANSVERSE 2.0T FSI - 5.5 hours of labor - $799 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler Pulleys and Bolt - (Interference Engine)
  • VW/AUDI LONG 2.0T FSI - 5.5 hours of labor -$799 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler Pulleys and Bolt - (Interference Engine)
  • AUDI 2.7T - 6.5 hours of labor - $949 - Kit includes: Water Pump with Metal Impeller, Water Pump Gasket, Timing Belt, Tensioner Pulley, Tensioner Damper, Idler Pulley, Bolt and Cam Seals. (Interference Engine)
  • VW 1.9 TDI - 4.5 hours of labor - $699 - Kit includes: Water Pump with Plastic Impeller, Timing Belt, Tensioner, Idler, and Cam Seal. (Interference Engine)
  • VW 2.0 TDI - 4.75 hours of labor -$799 - Kit Includes Timing Belt, water pump w/metal impeller tensioner pulley, idler pulley, ideler pulley w/bolt, relay roller, & installation instructions.
Tire and Alignment special
Purchase 4 Michelin tires from us, have us mount and balance them with Hunter Road Force and receive $50 off your alignment.
Carbon Cleaning Special
Walnut blasted and finished by hand.
  • VW/Audi 2.0T TSI/FSI – $699
  • Audi 4.2 FSI – $999
  • Inquire for Audi V10
Brake Fluid Flush
Brake Fluid should be flushed once a year or every 20k miles. $129 with MOTUL DOT 5.1 (up to 1 liter)
Winter Tire Packages
Inquire for pricing on winter tire packages.
CLICK HERE TO SEE OTHER OFFERS
Check Us Out on Social Media!
ExcelerateRep
06-20-2022 09:21 PM
ExcelerateRep
Sponsored Sales & Group Buys
06-13-2016 10:54 AM
ExcelerateRep
05-20-2016 04:09 PM
Quick Reply: Excelerate Performance: Fall Specials
