Aftermarket HU options?
Old 04-30-2014, 09:17 AM
  #241
ArtJ's Avatar
Kape....I can't speak for the 2012's.....I have a 2011 and all the shrouds from 2009 through 2011 work for my car...I would suggest you do some additional research to verify...I just searched ebay using "tsx navigation display" and came up with the below hits....they're pretty good deals...it seems that prices are dropping.....Firebrand used a 2010 shroud which made her installation a bit easier as no routing was required but she mentioned in one of her posts that you can cut the acrylic piece so that just the left and right "wings" are left...this will cover up the resultant holes on either side....the 2009 shroud worked great for me but it was a lot of work...I think if you could cut the acrylic piece on a straight line using a fine tooth blade and a fence that would be a better bet....the stuff is 1/8" thick and tough as nails.
http://www.ebay.com/itm/2010-Acura-TSX-Navigation-Display-Unit-OEM-LKQ-/360919301619?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ATSX&hash=item5408777df3&vxp=mtr
http://www.ebay.com/itm/09-Acura-TSX-Navigation-Display-Information-Screen-39810-TL2-A010-Tech-Package-/161284334582?pt=Car_Audio_Video&hash=item258d4ba3f6&vxp=mtr
http://www.ebay.com/itm/2009-2011-ACURA-TSX-NAVIGATION-DISPLAY-SCREEN-OEM-/321384616577?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3ATSX&hash=item4ad4041281&vxp=mtr
Old 04-30-2014, 01:02 PM
  #242
kape's Avatar
Thanks ArtJ. I think I was looking at eBay.ca. Also, on eBay.com the selection is limited to people that ship to Canada. I'll keep looking though.
Thanks for the info regarding the 2009 vs. 2010+.
Old 05-01-2014, 11:19 PM
  #243
firebrand13's Avatar
mine is a 2012 and the 2010 I got fits perfect. I do recommend attempting to keep the plexiglass or whatever it is, since it will look better... That being said, I don't hate mine at all :-)
Old 05-07-2014, 10:43 PM
  #244
there is also apparently a v-81
Amazon.com: VST V-81ACRD OEM Upgrade Multimedia Navigation System with 8-Inch TFT-LCD Touchscreen Monitor and Bluetooth for Honda Accord 2008 - 2013: Car Electronics Amazon.com: VST V-81ACRD OEM Upgrade Multimedia Navigation System with 8-Inch TFT-LCD Touchscreen Monitor and Bluetooth for Honda Accord 2008 - 2013: Car Electronics
Old 05-08-2014, 08:22 PM
  #245
ArtJ's Avatar
Yikes.....550 bucks!
Adotcaruso (01-25-2015)
Old 05-09-2014, 01:27 AM
  #246
TSX AMG Type //M i-VVT
iCrap's Avatar
I went cheapo and I'm in the process of installing a screen in the lower section
Old 05-09-2014, 12:37 PM
  #247
number17's Avatar
Not bad at all! What size of tablet did you install there? How do you fixate the tablet in that slot?
And how do you connect it to the car's HU system? (BT I suppose?)
Old 05-09-2014, 12:42 PM
  #248
iCrap's Avatar
Its a touchscreen monitor rather than a tablet. Connected to a laptop. And yeah it's using BT so I can still use the wheel buttons for next song.
Old 05-09-2014, 12:49 PM
  #249
number17's Avatar
I see ... why not use a tablet instead? Just curious ...
And what size is the monitor and how do you fix it to that slot?
Old 05-09-2014, 01:18 PM
  #250
iCrap's Avatar
A tablet won't fit in that spot unless i were to totally dismantle it.. there are bezels on the sides.
To install it i took off the door for the storage thing and just fabricated a little bracket thing to hold it all in place.
Old 05-09-2014, 02:36 PM
  #251
number17's Avatar
I see ... it doesn't look bad at all, though how do you control the laptop? The screen is a touch screen? And the temperature swing isn't a problem for the computer? Inside the cabin it can get as hot as 40C in the summer, and -30C in the winter here in Canada...
Old 05-09-2014, 02:53 PM
  #252
iCrap's Avatar
Yes its a touchscreen. The laptop temperature isn't an issue since it dosen't run while the car is off and parked. I'm using a SSD so there are no moving parts also.
Old 05-09-2014, 10:51 PM
  #253
number17's Avatar
cool ... should look more into it. How big is the touch screen?
Old 05-10-2014, 01:39 AM
  #254
iCrap's Avatar
7 inches. same as a double din size.
Old 05-10-2014, 07:07 AM
  #255
ArtJ's Avatar
Hey icrap I really like that setup....can you give us some details on the connection to the laptop and what kind of functions you're using? Does the laptop have 4G? You got me thinking 😁
iCrap (05-10-2014)
Old 05-10-2014, 10:58 AM
  #256
iCrap's Avatar
the laptop will automatically connect to my phone which shares it's 4G. I could easily add a 4G adapter directly to the laptop also if I really wanted to, but I think the internet sharing through the phone works just fine.
The functions i'll be using it for are mainly music and GPS. Also a few apps like pandora, google music, soundcloud, and well... really anything you can do on your computer you can do on this.
There is a built in windows 8 navigation app, which works fairly well... there is also google maps and microsoft maps. Still have to use them all to see what's the best.
I'll post full details on the install later once it's finished. There is an HDMI and USB cable going from the screen into the laptop, and that's' about it. Then I have a USB GPS receiver.... I am also considering adding a backup camera.
Old 05-10-2014, 04:17 PM
  #257
ArtJ's Avatar
Very cool icrap....sounds like a great way to go...I'll bet you could hide that laptop "permanently" somewhere like behind a panel so you don't have to mess with taking it in and out of the car......if you go with a backup camera just avoid the 2.4GHz wireless models...I tried one in the wagon....as soon as the OEM bluetooth system wakes up it wipes out the video. Looking forward to seeing the finished product...thanks.
iCrap (05-10-2014)
Old 05-10-2014, 04:22 PM
  #258
iCrap's Avatar
Thanks for the tip, i'll avoid the 2.4ghz ones.
I will also post a new thread with more details once I'm all finished with everything.
Old 05-10-2014, 04:25 PM
  #259
number17's Avatar
That's a great idea ... where did you get the 7" touch screen monitor?
I am thinking I can get a 7" monitor, and get some kind of an "Android USB stick" that has USB out, BT connectivity, and since it already has built in google navigation etc it will be an easy setup.
Only thing is if I'm playing music through it or using it as my GPS, the Acura's BT can only connect to 1 device at a time, and I lose the BT-link for handsfree with my own cell phone ... wouldn't you have the same problem icrap?
iCrap (05-10-2014)
Old 05-10-2014, 04:29 PM
  #260
iCrap's Avatar
I bought this one here:
http://www.ebay.com/itm/191037306291...84.m1439.l2649
The Android USB stick is a great idea also for sure, but I wonder if they support the touchscreen?
Nope actually, our HFL and BT audio system are actually running separately. I have disabled call audio from the computer while still having it run on my phone... so, if i get a call it just switches right over to the phone audio.
iamitman (05-13-2014)
Old 05-10-2014, 11:08 PM
  #261
number17's Avatar
Yeah that's a good point. I think Android stick / small Android box is quite ideal because of its low power draw, built in BT, Wifi and GPS, and many available apps (navigation, media players) that are quite ideal for car-puter use. Biggest problem is it doesn't seem like there is any easy way to connect Android to an external touchscreen. If I don't go with a touch screen, and use a remote to control then screen then it does work, but that's kinda stupid, especially for navigation app.
I'll have to do some more digging.
BTW, attaching the 7" screen to that 'box' is easy? Just a couple of brackets on the side and removing the door cover and that's it?
Old 05-10-2014, 11:37 PM
  #262
iCrap's Avatar
I'll also look into this android option as honestly i'd prefer having Android to the PC.
Yeah it's very easy... take off the door cover and springs and I also trimmed a tiny bit off the bottom of the box. Fits nicely. I fit all the screens electronics inside the box thing behind it.
Old 05-12-2014, 08:11 AM
  #263
number17's Avatar
BTW is that center console 'box' a standard double DIN unit in itself? If so there would be a lot more options for mounting ...
Where do you put the laptop icrap?
I am thinking if I don't need touchscreen, and can deal with a remote + touchpad solution then I can easily do a 7" screen + Android stick / box solution. But obviously, touchpad would be so much better, but I'd rather Android than Windows.
Old 05-13-2014, 02:03 PM
  #264
iamitman's Avatar
So you are saying the you can connect 2 Bluetooth devices to HFL simultaneously ?
Old 05-13-2014, 02:08 PM
  #265
iCrap's Avatar
Yep. You can have one on the HFL and one on the BT Audio.
The center box is not a standard double din btw, it does require a tiny bit of fitting.
After some reading i've found that the Android stick may be able to support the touchscreen, I've ordered one and will test when it arrives.
Old 05-13-2014, 02:29 PM
  #266
iamitman's Avatar
Ok, I am going to give it a shot. Also, going to post pictures of my setup later today, which I think is pretty wicked!
Old 05-13-2014, 02:39 PM
  #267
iCrap's Avatar
Yeah, post up some pics.
btw make sure you disable the MEDIA BT from your phone. it's very easy on an Android phone, unsure on iPhone.
Old 05-13-2014, 03:02 PM
  #268
number17's Avatar
hey icrap wanna share how it goes and if you have any success connecting Android stick to touchscreen?
I've done some digging but can't find a definitive answer.
Old 05-13-2014, 03:13 PM
  #269
iCrap's Avatar
I have not been able to find a definitive answer either. Some claim it dosent work and some claim it does... I figure i'll get it and see how it goes.
I will post with my results.
Old 05-13-2014, 09:56 PM
  #270
number17's Avatar
One ebayer told me a capacitive version of the touchscreen is coming out in about a month and will easily work with Android. Till then, a lot of work has to be done to make the resistive screen work with Android ... think I'll wait a bit then.
Old 05-13-2014, 10:08 PM
  #271
iCrap's Avatar
oh well damn i should have waited for that...
Old 05-14-2014, 07:57 AM
  #272
number17's Avatar
He said it can still work but is not plug and play ... and when he says "1-2 months" it can also take a lot longer too.
I was thinking even without the touchscreen it could work with a remote and touchpad as input ... and I would have gone for that too, but obviously, touchscreen is better.
Old 05-16-2014, 08:38 PM
  #273
kape's Avatar
Finally had some time to test the P-81ACRD I got from Amazon a few weeks ago. When I first plugged it in, the screen just displayed scrambled lines so I thought for sure I got a defective one. But I turned it off and back on again and everything seemed to work fine.
I tested the navigation, radio, HVAC, bluetooth, etc. One thing I couldn't figure out is how to set the time. There is the car time that's displayed under "Trip" but there's also the Ingenix time which is in the top-left corner of the home screen. If I click on the top drawer then clock, I can adjust the timezone and what looks like daylight savings, but not the actual time. Also, when I turn the car off and back on again, the time goes back to "PM 12:00". Anyone else have this problem? This time is what's used for the automatic brightness, and if it always resets to 12:00 then it's useless. My OS version is P81ACRD M1.20Z2
Overall, I wasn't too impressed to be honest. It's not very intuitive, but I guess I was expecting similar features to a tablet. If I compare it with the OEM screen, that only has navigation, so definitely the Ingenix unit is better. I didn't like that there are two clocks and two Bluetooths, the OEM one and the Ingenix one. It's confusing. I take it the Ingenix bluetooth uses the external speare and mike which sucks but you can at least see your contacts, dial from the unit not your phone, etc. I assume the same goes for streaming music through bluetooth? if you're connected to the Ingenix bluetooth then your music will play through the external speaker but you'll have a nice interface, song name, artist and so on, which you don't have through the OEM bluetooth.
Now all I need to do is find an OEM screen so I can install this thing.
Old 05-16-2014, 09:54 PM
  #274
iCrap's Avatar
My little android HDMI stick showed up, out of the box it did not work with the touch... so i flashed a ROM... But i flashed the wrong ROM and bricked it.
Waiting on my replacement now.
Old 05-16-2014, 11:04 PM
  #275
number17's Avatar
ah man, that sucks ... sorry to hear that. At least you are getting a replacement unit
I once bricked my wife's Galaxy Note and could not get a replacement That was an expensive mistake.
Keep us posted!
Old 05-16-2014, 11:15 PM
  #276
iCrap's Avatar
Yeah stupid mistake on my part, i flashed the non Bluetooth version firmware onto my Bluetooth version of the stick... Also i read AFTER i flashed it that you can't use windows 8.. which I did.
Well, at least I know what to do when my replacement arrives.
Old 05-17-2014, 11:55 AM
  #277
ArtJ's Avatar
I've had my share of screw ups on this project as well but they say if you're not screwing up you're not in the game....carry on!
The following 2 users liked this post by ArtJ:
BlackNsexy2010 (05-17-2014), iCrap (05-17-2014)
Old 05-18-2014, 05:03 PM
  #278
iCrap's Avatar
updated shot of what it looks like now.... Raspberry Pi is currently plugged in.
USELESS camera phone makes everything blurry.
Slade037 (05-18-2014)
Old 05-19-2014, 01:11 AM
  #279
goodhed's Avatar
For anyone looking for a reasonably priced nav-screen:
http://www.ebay.com/itm/161310830910...84.m1555.l2649
Old 05-19-2014, 09:43 PM
  #280
number17's Avatar
Looks nice.
It's easy to get the touch screen input to work with the Raspberry Pi? But Pi only runs XMBC, and doesn't really have navigation app does it?
Quick Reply: Aftermarket HU options?
