TL Brake booster/ master cylinder swap
Old 09-03-2018, 10:59 AM
Glepage22's Avatar
Hello everyone,
I want to know if anyone attemped to swap a complete TL brakebooster/mastercylinder on a 4cyl TSX to get better brake response and a harder brake pedal?
Thank you
Old 09-03-2018, 11:33 AM
BROlando's Avatar
Received 1,165 Likes on 876 Posts
Aren't the piston sizes much larger on the TL caliper?
Using the TL master cyl and booster would result in a harder pedal, but less force at the calipers. So....you'd need to push the pedal harder to get the same response out of the TSX's smaller calipers.
What's wrong with your brakes currently?
Old 09-03-2018, 05:42 PM
Glepage22's Avatar
My disc and pads are new, brake fluid new and purge correctly and i always feel like the brake of the cu2 tsx are soft and with no response like in an accord v6 or Acura tl. Its my second tsx cu2 and i want to correct the problem, if i cant i will sale the car and take something sportier.. still dont know what tought :p
Old 09-07-2018, 10:49 AM
t3hhcaptain's Avatar
Does the V6 tsx have the same brake calipers and booster/master?
Old 09-07-2018, 06:11 PM
BROlando's Avatar
Did they feel fine before you did the work?
Did you properly lube ALL the sliding surfaces, including the pad ears?
Do the pads move/slide freely on the bracket?
Did you bed in the pads?
What type of pads?
Yes, the TSX has more pedal movement with less agressive boosting. So...the pedal feels more "natural" or maybe slightly mushy. Idk if selling the car is your best option. But its certainly an option.
Old 09-08-2018, 06:39 PM
Glepage22's Avatar
- yes, same feeling before with old pads
- everything is properly lube et free without restriction
- yes pad were correctly bed
- OEM Acura pads
Too many thing to correct in this car so I will just get to sell it. I hate the seating position, mushy brake pedal, too smooth clutch pedal and I would like a V6 swap with a 6speed transmission. Already a K24 6 speed in it. But it's a lot a $$ for a daily that see snow and salt...
Old 09-10-2018, 07:36 PM
Glepage22's Avatar
I have done this mod often on my older EK and EM1, I have installed a brake booter and master cylinder from an ITR which was a 1inch.
TSX MC = 13/16
TL MC = 7/8
So i am pretty sure it would fit bolt on and increase brake feels and response
Now I am searching to find the size of a TL-S 07-08 MC
The RL MC is 7/8 too so no gain vs the TL . On ebay I can put my hand on a set of brake booster + master cylinder for +- 100$.
Old 01-09-2019, 02:06 PM
Sorry for reviving this thread, but I just want to know if the TSX V6 master brake cylinder would fit the i4?
Part number is 46100-TL1-G01
Old 01-11-2019, 09:17 PM
2snail's Avatar
i have a v6 tsx and compared to our SH AWD TL the brakes on the TSX are much softer. I think its the nature of the calipers too. I was under the impression the brakes are the same size between 4cyl and 6cyl maybe im wrong?
Joe Lui
06-25-2020 08:22 PM
mars
05-25-2013 08:52 AM
bigg_86
01-25-2012 01:57 PM
Ron A
07-30-2008 07:17 PM
732xghost
05-14-2006 09:17 AM
Quick Reply: TL Brake booster/ master cylinder swap
