18" wheel set ups
Old 01-31-2013, 09:45 PM
  #41
Old Guy
Simba91102's Avatar
Originally Posted by tsxoniner
Can any of this A-spec equipment be used/fit on CU2 TSX's? I've seen the body kit, but what about suspension components?
Sorry for a late reply, and I'm quite sure that none of the 1st gen TSX suspension stuff is interchangeable with the 2nd cars. It seems that they changed just about everything (rear camber kit looks quite different for instance). There are Aspec wheels available for the earlier cars, along with a body kit. I'd imagine the stuff is getting pretty scarce now (new anyway).
tsxoniner (01-31-2013)
Old 02-27-2013, 10:24 PM
  #42
wontonjohnny's Avatar
Originally Posted by Terdbath
Same wheels as BobbyC and 245 40 18's, on S techs.
Recently found these knock out plugs as an inexpensive alternative to the stock center cap.
Is the offset +35 aswell?
Old 02-14-2014, 02:37 PM
  #43
4th Gear
octsx714's Avatar
18x9+38 fitment
hey guys, i just recently got an 14 tsx and would like to get some new wheels. i see you guys have 18" setups and they look nice so im currently looking at the works xd9 18x9 +38 /5x114.3 and was wondering if that would be able to fit w/o any fender rolling or shaving.
thanks in advance
Old 04-07-2014, 04:35 PM
  #44
Miketsx09's Avatar
Need some advice. Looking at a 18" rim with 225/40/18 tire I'm lowered I H&R's 1.25". Will I rub. Don't wna roll fenders. Rims are a nice 10-spoke with about a 1 inch lip
Old 04-07-2014, 04:43 PM
  #45
Miketsx09's Avatar
The offset is 35 ^^^ on the rim
Old 04-07-2014, 04:52 PM
  #46
Miketsx09's Avatar
Does 35 offset 18" rim with 225/40/18 work with 1.25 drop ?? Rub issues
Old 07-15-2016, 07:42 PM
  #47
Rdub81's Avatar
Tried searching, but thought I'd just ask here. Anybody out there with 18" wheel set ups on their CU2 TSX's? The 19's are sexy porn for sure, but wonder about 18" combinations. Care to share? Thanks in advance.
reving this thread because I like how op used the term sexy porn
so here's mine 18x8 Axis Widetrack 235/45/18 Michelin
Old 01-14-2017, 09:27 PM
  #48
D_Valdez's Avatar
I would have went 225/45 on those wheels
Old 02-11-2017, 07:37 PM
  #49
2snail's Avatar
I can finally post in a wheel thread. Asa ar1 18x8 et35 all around. On megan street coils, I have to adjust the height and i will need to get a camber kit for the rear.
Tires are 235 45 18 yokohama
Old 11-19-2017, 04:06 PM
  #50
97CL_NC1102's Avatar
18x9.5 +35 square
245/40I would like to run 18x9's +35 or higher and with a 255/40 or 45 and raise the car
The following 4 users liked this post by 97CL_NC1102:
KulawyJohn (02-13-2020), Noah Grace (06-07-2019), SiiRBrooklyn (07-13-2019), Teo_cleanNlean (03-06-2019)
Old 12-10-2017, 02:16 PM
  #51
dsf3g's Avatar
Enkei EKM3, 18" 38 mm offset
Old 12-11-2017, 09:54 PM
  #52
MC MiYoung3269's Avatar
Received 1,000 Likes on 712 Posts
18x10.5 +39
265/40/18
Square setup
The following 4 users liked this post by MC MiYoung3269:
BigEezee (10-15-2019), julius071 (12-14-2017), SiiRBrooklyn (07-13-2019), Teo_cleanNlean (03-06-2019)
Old 03-28-2019, 12:18 AM
  #53
Unkindwindow22's Avatar
What wheels are those?
[QUOTE=Terdbath;14225851]Same wheels as BobbyC
Old 06-07-2019, 11:12 PM
  #54
Noah Grace's Avatar
Please tell me what wheels those are. I need to know.
Originally Posted by 97CL_NC1102
18x9.5 +35 square
what wheels are those😍
Old 06-10-2019, 12:37 PM
  #55
Terdbath's Avatar
^ Enkei NT-03
Old 02-03-2020, 10:34 PM
  #56
wagonfanatic's Avatar
After a fair bit of research I'm VERY happy with my 18X8.5 Flow One F2's. The 235/45ZR-18 Michilen Pilot Sport 4S's are so sticky sweet. Probably not practical where there is actual winter but in Texas it's pretty much summer performance tire season year-round.
Old 02-13-2020, 02:34 PM
  #57
KulawyJohn's Avatar
typeS rims look pretty cool for me here are mine with distances 10mm front, 15mm rear
forward (02-23-2020)
Old 03-22-2020, 08:39 PM
  #58
forward's Avatar
Here are a few shots of the 18" x 8.5" (+55 offset) Subaru WRX STI wheels and P245/40R18 tires I recently picked up to use on my '11 TSX Sport Wagon. Stock height suspension (for now), with about 2.375" of gap between the crown of the LF tire and the high point of the fender arch, and about 2.675" for the LR. Very close to stock fitment, so I didn't see any areas to be concerned about regarding potential rubbing. Pics are huge, but nobody is still on dial-up, right?
LF, Subaru WRX STi 18x8.5 wheel, P245/40R18 tire
LF, looking straight down
LF wheel/tire-to-suspension clearance
LF, looking forward, camera against F/R door gap
LR, looking (mostly) straight down
LR, looking forward, camera against rear bumper cover
Old 04-24-2020, 09:24 PM
  #59
EzeE1o's Avatar
18x8.5 +45 enkei TS-V. 245-40-18 pirelli p zero nero gt Tires. Don’t mind the SHawd ride height.
Old 04-25-2020, 12:11 PM
  #60
49erfan's Avatar
where did you find this wheel in 18x8.5? I can only find 8” wide
Old 04-25-2020, 12:22 PM
  #61
49erfan's Avatar
I am considering these wheels as well but 38mm offset
Old 06-01-2020, 11:32 PM
  #62
EuroRspec's Avatar
Old 06-29-2020, 03:01 PM
  #63
Tourian's Avatar
^Could you please post specs on your wheels and tires?^
Old 05-17-2021, 07:47 PM
  #64
4th Gear
Multifunctionstapler's Avatar
Enkei M52 18x8 +45 - 235/45/18 Pilot Sport AS3+
Old 01-01-2023, 06:49 AM
  #65
6th Gear
hlee96's Avatar
@wagonfanatic These look great. Looking at these from tire rack at 18x8" ET 45. Can you tell me if these are gunmetal gray or black machine/dark tint? thanks!
Old 01-06-2023, 01:04 PM
  #66
BROlando's Avatar
Received 1,163 Likes on 874 Posts
18x8.5 +35
245/40/18.
No fender work needed.
Designed and 3D printed the center caps to make them look more stock.
godfather2 (01-11-2023)
Old 01-08-2023, 05:03 AM
  #67
6th Gear
hlee96's Avatar
Beautiful wheels. What type is it?
Originally Posted by BROlando
18x8.5 +35
245/40/18.
Old 01-08-2023, 01:48 PM
  #68
BROlando's Avatar
Thanks. They're Konig Ampliform
hlee96 (01-08-2023)
DavidPitsul
44
06-29-2017 11:53 AM
cougtype_s
20
05-05-2013 12:46 PM
TypeAcuraTL
02-28-2010 05:56 AM
mdub
17
06-21-2008 11:52 PM
indopinoy
10-10-2001 12:30 PM
Quick Reply: 18" wheel set ups
