Sunvisor replacement?
My drivers side sun visor broke and doesn't stay all the way up anymore. Anyone replace this before? I'm just curious if there's an electrical connector for the light in the mirror or not?
Bottom of Page 1792 and 1793 of the Acura Repair Manual
see thread https://acurazine.com/forums/fourth-...manual-956811/
for the manual
1. Insert a flat-tip screwdriver through the hole in the front side of the bracket cover (A), and push the hook
(B). Make sure the hook is unlocked.
2. While pushing in the hook (A) with a flat-tip screwdriver, release the sunvisor (B) from the holder (C),
and rotate the sunvisor backward about 45°. Make sure the hook slides into the bracket cover as you
3. Pull down the sunvisor (A) to release the pin (B) and the bracket (C) from the holes in the body. Then
pull out the vanity mirror light connector (D), and disconnect it.
Manual had pictures that better describe it.
for the manual
echodigital (07-31-2018)
IGOTJUICE007
08-16-2003 03:43 AM
OUTRAGEOUS CL TYPE S
05-08-2002 02:32 PM
