Headlamp Assembly
Old 07-02-2018, 06:16 PM
DidiBob's Avatar
Headlamp Assembly
Anyone have experience with a replacement brand calling themselves " Replace"
https://www.carid.com/2012-acura-tl-...098005575.html
I need to swap out my lenses, and I know a ballast is going in one unit, so it might make sense to order a complete assy.
Thanks!
Old 07-03-2018, 01:06 AM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
If you are cutting the lights up, you can buy bi-xenon projectors from the retrofit source that fit our cars plug and play! They can also be equipped with ZKW or TSX lenses. I'd honestly do that! Plus get a used ballast, OEM last the longest.
Old 07-03-2018, 08:12 AM
frankjnjr's Avatar
Thanks!
Just curious: ("I need to swap out my lenses") Do you mean the headlamp itself, or the lenses? Is the headlight, or lens, Damaged?
Old 07-03-2018, 09:47 PM
DidiBob's Avatar
Great question. One lens is sun damaged and sanding isn’t enough. The other lens Is still good but I want them both to match and look new and then age together. I know that the ballast and lamps are getting up there in age, and it would be prudent to replace everything complete rather than take things apart and re assemble down the road. Literally. Lol. I know it’s slightly throwing money at something which works, then again, time is also valuable and let’s just do this once.
So...If anyone knows a reliable supplier for OEM lamps, I’m interested. Nothing aftermarket. Please disregard the above link, I want to go OEM.
Old 07-03-2018, 10:37 PM
frankjnjr's Avatar
IMO: OEM New= $$$ very expensive. If money is no object, any on-line Acura OEM supplier, like Delrayacuraoemparts.com, will sell you the (BARE) headlight, no bulb, ballast, igniter, etc. for $ 539, + shipping, + ballast +bulb + igniter. That light, lists, for $771. Even if you were to go used, OEM, from a north western state, where the sun damage is not as severe, you would have to pay in the $800 range, for one headlight, with "0" damage, with used, ballast, bulb, and igniter. I do a lot of headlight restoration work, and it puzzles me, when you say, " One lens is sun damaged and sanding isn’t enough." I have yet, to encounter, a sun damaged, faded headlight, that could not be restored, to ( NEAR PERFECT ) condition, to include the restoration of the UV protective layer.
Old 07-10-2018, 08:46 AM
DidiBob's Avatar
I took some time and refinished the lenses. They are near perfect and they look extremely clear.
Sanded with 1000, 1500, 2000, then 3000. Turtle Wax rubbing compound then polish.
The only thing Ive noticed - there are slight scratch marks still in the plastic. I assume I went too tough on the 1000 grit. Its only noticeable from the side angle if you were to look at the lamp.
Any advice for how to further clear this up? I would appreciate it. Buying the lenses just does not make sense after review.
Old 07-10-2018, 07:18 PM
The inconvenient truth
dopeboy1's Avatar
I know you said you dont want aftermarket. But consider the TSX-R lens from theretrofitsource.com. Its only $40 and supposed to be much better than oem.
LTABA
02-12-2008 02:02 PM
Dani
07-09-2004 08:54 PM
Dani
03-26-2004 05:16 PM
anothercls
03-01-2004 02:00 AM
ChinozTL
03-30-2001 05:48 PM
Quick Reply: Headlamp Assembly
