Turbo Blanket Anyone?
Old 09-24-2018, 10:43 AM
mistryp's Avatar
Does anyone have a turbo blanket installed? I'm looking at purchasing one but don't know which size and how to install...
Old 09-24-2018, 10:58 AM
Received 16,260 Likes on 11,971 Posts
a turbo blanket, blanket or covers the turbo and keeps heat away from main components...
the way Honda implemented the turbo on the RDX; close to components without any real space will make it hard to find a blanket that does it's job
Old 09-24-2018, 06:46 PM
CSmoney28
CSmoney28's Avatar
I would be interested in a turbo blanket but I have never even heard of someone mention that on this forum to be completely honest. You’ll definitely be the first person to attempt something like that right now. I never even heard of someone wrapping any part of the exhaust with the heat wrap either. I’m interested so keep me posted.
Old 09-24-2018, 08:17 PM
DRR98's Avatar
Ask the wrench, if anyone knows, he would.
But just look at it and see. I wonder if the vane actuator and coolant lines might be in the way.
Maybe insulate the heat shield and wrap the down pipe.
Old 09-24-2018, 10:43 PM
CSmoney28
CSmoney28's Avatar
Bump, for the Wrench to chime in...
I think 🤔 the lines would be okay since the side are usually open.
I don’t even have a heat shield it got taken off with my catted downpipe for the cattless one.
Old 09-25-2018, 06:33 AM
@TheWrench116 we need your expertise
Old 09-25-2018, 07:20 PM
CSmoney28
CSmoney28's Avatar
bump!
Wrench 🔧!
Paging!
The wrench 🔧!
Please pick up!
Old 10-26-2018, 06:13 PM
PM me if you need a reply
InfamousJamous's Avatar
This one was bought off Amazon. I tried others but they didn't fit. Better than nothing I guess.
I don't recommend leaving the stock one on with an aftermarket DP unless you have the 3rd bolt fastened. Just having 2 bolts will cause bad vibrations and may crack the turbo housing like mine did.
josiahmgillespie (03-07-2021)
Old 10-26-2018, 07:44 PM
CSmoney28
CSmoney28's Avatar
Looking good, you did the turbo blanket and the down pipe wrap it looks like...how is it running temperature wise?
How much did that set up cost you money and time wise?
Old 11-01-2018, 05:40 PM
The blanket was cheap. I had to get some wire to mount it.
I also had to protect the firewall and A/C lines since the A/C was not blowing cold as it should and the firewall material was coming apart.
Blanket
Amazon Amazon
Downpipe wrap
Amazon Amazon
Heat barriers
Amazon Amazon
This heat sleeve may work for the A/C lines
Amazon Amazon
Old 11-02-2018, 10:50 AM
CSmoney28
CSmoney28's Avatar
Nice, thanks for the links. Did you see a temperature difference?
Exterminator
02-03-2017 01:14 PM
Hi speed
29
05-12-2012 10:11 PM
lokijibber
02-01-2012 12:43 AM
Type S
10-11-2002 10:35 AM
Quick Reply: Turbo Blanket Anyone?
