DIY - Repair Cat Heat-shield Tinny Rattle
Old 10-06-2010, 08:56 PM
haole kama'a-ina
737 Jock's Avatar
We had a tinny rattle from underneath during cornering and reversing uphill.
The secondary catalytic converter has a thin aluminum heat-shield which bends easily. The corner of it was chafing on the heat-shield for the A/C drain:
Here is a close-up of the contact. The dent in the drain's heat shield is visible. To fix, simply bend the tab on the corner of the cat heat shield away from the A/C drain. Your hands or any kind of pliers should work:
Make about 8mm clearance and the noise should stop:
DRR98 (01-19-2014)
Old 10-07-2010, 01:53 AM
big shot.
MMike1981's Avatar
dude, ur posts are the best.
Old 10-07-2010, 05:59 AM
2008 Acura RDX
wspy's Avatar
^ Oh for real!
Further, I had my secondary cat R&R with a straight through pipe.
Old 02-15-2011, 01:48 PM
PM me if you need a reply
InfamousJamous's Avatar
So that's where the rattle was coming from! It would rattle at idle and annoyed me so much!! I was afraid it was knock, ping, or something wrong with the turbo since it sounded like it came from that area.
I laid down some cardboard, crawled under, and fixed it in minutes. Thanks!
Old 02-15-2011, 09:01 PM
superblast's Avatar
Wow, I just started noticing that noise last week and was wondering how I was going to describe it. You nailed it with your description though. Thanks so much for the detailed fix!
Old 02-16-2011, 01:36 PM
brizey's Avatar
I had the noise and fixed it years ago...I am just not as nice of a guy as 737 and kept it to myself, lol.
Old 07-15-2012, 05:26 PM
Kristoefur's Avatar
I think I've got this same dreaded rattle, but have yet attempted to fix it. Did anyone notice that the rattle is more audible after the car has been sitting for a long period of time? I hear it the most in the morning.
Old 11-20-2012, 07:13 PM
jchungum's Avatar
Thanks for your help 737 Jock. This rattle started a week ago, and I knew it was not brake or engine related. I got under my 2007 RDX tonight, bent back the heat shield and all is good now!
Old 04-13-2017, 01:17 PM
rossmo's Avatar
Anyone have the pics for this process? I don't see them above anymore. thanks!
Old 09-02-2018, 04:45 PM
mass978's Avatar
Bump, anyone got any photos of this mod? I just bought a 12' and believe I'm hearing this too!
Old 09-04-2018, 06:29 PM
CSmoney28
CSmoney28's Avatar
I got mine fixed by the dealership I don’t remember exactly what it costs but I’m thinking around a hundred.
Old 06-03-2019, 02:20 AM
7th Gear
Sleepyosu's Avatar
My heat shield was starting to rust off by the bolts.
I drilled 4 holes through the 4 layers.
I used scrap 12 gauge bare copper solid core home electrical wire.
Twisted each tight its 100% better.
Old 06-09-2019, 07:03 PM
CSmoney28
CSmoney28's Avatar
Any pictures 😃?
Mike734
12-10-2021 01:25 PM
tsx_boy
12-13-2019 08:33 PM
08_UA7_Gr33k
02-11-2016 02:17 PM
CL-S progression 01
01-26-2016 04:15 PM
scionxb3003
09-22-2015 05:28 PM
Quick Reply: DIY - Repair Cat Heat-shield Tinny Rattle
