DIY - Rear Differential oil change
Old 03-07-2017, 06:57 PM
  #81
heykosal's Avatar
Originally Posted by af145
For what it's worth, I ended up using DPSF. That was 1 year and 10K miles ago. No problems so far.
Okay, I think that's what I'll go with, thanks.
Old 10-03-2017, 09:14 AM
  #82
FC2012RDX's Avatar
I'm gonna probably give this a shot this weekend and since reading through the thread there was some discussion on which fluid to use, I think this will clear it up. This is from my 2012 RDX Owner's Manual:
Old 11-16-2020, 10:28 AM
  #83
CSmoney28
CSmoney28's Avatar
So helpful this thread is I’m going to do this with my next oil change...I’ll post pictures to help!!!
Old 11-16-2020, 01:15 PM
  #84
CSmoney28
CSmoney28's Avatar
Does anyone have the bolt part numbers for the refill and drain?
Did anyone ever add a second rear differential mount to the ride sides missing hole?
Old 11-16-2020, 02:59 PM
  #85
CSmoney28
CSmoney28's Avatar
Hope this helps someone
Old 11-16-2020, 03:40 PM
  #86
CSmoney28
CSmoney28's Avatar
Old 04-09-2021, 03:26 PM
  #87
deepa1600's Avatar
Hi guys, I know this DIY is old. I was wondering if there is only one mounting bolt and bushing which goes through the rear subframe in to the rear differential? Because there is only one on the left side and right mounting hole is missing the bolt and bushing from the sub frame at least in mine or if that is how it's from the factory? And another thing why RDX only has one differential chamber in the rear? Because my RL has 2 separate rear diff chambers for DPSF.
BDoggPrelude
01-15-2021 01:17 AM
5thTo2nd
12-23-2018 09:31 PM
KaMLuNg
1G TL Problems & Fixes
48
04-19-2018 04:51 PM
5point9Limited
1G TL (1996-1998)
08-20-2010 08:18 AM
Quick Reply: DIY - Rear Differential oil change
