Computer Building Thread
#161
Received 2,773 Likes
You guys don't have battery backups already on your machines? SMH
You guys need to get on that, I probably have a very brief outtage for lightning or whatever about once a week so I got the router, modem and computers all on backup so if we get a brief power outtage I don't lose interwebs.
I guess I should get one.
Can you hook up a lamp to one? So if the power goes out at night time I'll still have light?
#162
Needs more Lemon Pledge
ok, miz called it!
New power supply and it boots to Windows loading, and then cycles again. Probably has something to do with needing the RAID drivers (I had single 80GB as OS and two 250GBs as RAID0 using on board RAID/SATA).
Guess I need to find the RAID driver floppy disks...
80 bucks is a lot better than 800, fo sho...
#164
It wasn't me, it was Stunna that called it.
But I'll take the credit
#165
well, you both get the credit then...
thanks.
Just need to figure out the RAID driver issue I think...
thanks.
#166
Sanest Florida Man
#167
Cant figure out why Windows STARTS to load, then reboots...
#168
lol!
#169
Sanest Florida Man
What happened that you need to reinstall raid drivers? Do you need to rebuild your RAID array? If you disconnect your RAID drives does it boot? Does it boot in safemode?
#170
Sanest Florida Man
you can call me if you need help.....srs
#171
#172
I have unplugged all SATA but the OS drive.
pc gets to XP loading screen, a few passes of the progress bar and it reboots.
Thinking of poping in the XP disc at boot and seeing what happens...
I also have an Ubuntu boot disk and a copy of Vista business I never installed...
#173
Sanest Florida Man
^yes try those discs. I know that you're smart enough to backup your data so I don't have to ask about that.
try booting into safemode and if it freezes while loading drivers what's the driver listed at the bottom of the screen as the last one? that's should be the problem one.
#174
Safe mode does hang and reboot, will get the file it hangs on...
I also think maybe the CMOS battery is dead or dying, hence the loss of BIOS data.
#175
Geebus your PC is fvcked...
#176
Sanest Florida Man
is the date and time all wrong now too? Go in the bios and make sure its setup the way you had it.
AHA! figured it out! God I'm awesome! Go into the bios and for SATA setting make sure change the setting for ATA mode. If it's set to ATA or IDE then change it to AHCI, it it's set to AHCI then set it back to IDE.
/thread
/thread
#177
Sanest Florida Man
Not having that set to the right setting will cause windows to crash and reboot so if your bios settings got lost then it got reset back to the wrong setting and just needs to be changed back.
#178
I'll accept stunnas computer repair donations via Paypal
#179
you may be on to something Stunna.
Time was wrong, date was right.
I had changed those setting (Configure SATA as Standard IDE, AHCI, RAID mode) for the single OS drive, but now have all three drive in and will try each option (it's global, not drive specific).
#180
In Recovery Console, all logical volumes (even RAID) are visible as a directory listing.
Just cant boot.
Just cant boot.
#181
Sanest Florida Man
then you'll have ti set it up as RAID and then rebuild the RAID 0 array in the configuration utility
#182
the bios sees all three HDDs. The RAID config sees none of them.
I am considering a fresh XP install...
#183
Sanest Florida Man
uuhhh...that's weird. I guess you won't be able to configure RAID again then unless you get an add-on card.
Guess who has a brand new never opened PCI Express add-on RAID card with Sata II, ATA and eSata on it and it looking to sell it? Guess!
#184
OK, now Bios sees as RAID and also nonmember disk (OS) BUT
While in Recovery Console, I used the FIXBOOT command on the C:... May have just junked up the boot sector...
I need to figure out how to set the correct disk to be the boot drive in the MBR.
#185
Sanest Florida Man
Fixmbr and then run fixboot?
#186
going to try Checkdisk /f first, then those....
Gparted sees the drive ok, says may be issue with MBR, partition table, etc...
#187
no dice. Looks like a clean install of XP is in the cards...
#188
sux.... sorry to hear stogie, but i guess you dont have to spend $800?
me and stunna will gladly take your savings via paypal
#189
definitely drive related.
Plugged a hdd in as the only drive that was the old OS drive from this netbook (cloned to a larger hdd) and booted up to the logon page...
Format C: imminent...
#190
decided to install XP to the small laptop drive instead, in case I end up wanting to take a look at the contents of the original OS drive... They are both 80GB drives...
I am forgetting the RAID volume for now, until I get a working boot drive with a bootable partition and OS.
#191
Posting from a clean install of XP Pro...
#192
sweet.
#193
Yeah, running OS off of a 80GB laptop drive right now, so hopefully tomorrow I can try adding the old OS drive as a secondary and see if I can move a few things off.
All the important stuff was backed up, although I never tested a backup to see how the recovery would go, so that may be interesting...
Also, not getting into the RAID issue tonight. Need a fresh head for that.
THANKS TONS guys for the help. Also, Will still probably be upgrading to a new machine here shortly... Glad I was forced to spec it out.
#194
Sanest Florida Man
Make sure you click on the little pop up balloon offering to give you a tour of Windows XP, it's got some good information in it.
If you dont have it already then download SP3 here
http://www.microsoft.com/download/en/details.aspx?id=24
also do IE8
http://www.microsoft.com/download/en/details.aspx?id=43
Then go to www.ninite.com to get all your 3rd party software and .Net 3.5 SP1 and MSE too.
www.ninite.com
Then do all the windows updates which will be a few hours worth but following these steps in this order will make it quickest and make the update process as hands off as possible.
Then if you need more drivers you can try connecting the other 80GB drive and going into device manager right click on the unknown device and choose update driver and point the folder at the windows or system32 folder of the old 80GB drive and it should see the drivers.
also do IE8
www.ninite.com
#195
Thanks, doing all the updates now...
The tour was awesome. Who knew Windows would autoplay things?
#196
It's alive.... Cool. Guess that means you're holding off on the system upgrade for a bit longer (like me) then.
#197
Yeah, for a little while. Nice to what I am going to get in advance though...
#198
so what are you going to do with the money saved?
vegas?
treat me to some whores?
vegas?
#199
Sanest Florida Man
I didn't get any "Thanks" for my very helpful posts.....
Mizouse (08-27-2011)
#200
