2009 TSX "Check Charging Sytem" Warning
Old 09-14-2018, 06:18 PM
Danosaurus's Avatar
Exclamation 2009 TSX "Check Charging Sytem" Warning
So I was out of town for a couple weeks and left my car in the airport lot...when I got back and started the car I got the "Check Charging System" warning, but the car started and ran just fine all the way home. I figured it was because it was sitting for a couple weeks without being started, maybe the battery had gotten a little low. I have driven it a couple times since and had not seen the warning again until today. I drove a short distance around town then came home, parked in the driveway, then started the car to pull into the garage and got the warning again.
Is this a sign of a failing battery or alternator? I've never seen this warning before, even when my last battery went bad.. Thanks!
Old 09-14-2018, 06:45 PM
fbt
fbt's Avatar
Sounds like it. Probably should get it checked out before the first really cold weather comes. That's always a good time for batteries to fail.
Old 09-17-2018, 04:37 PM
RTM
RTM's Avatar
Factory Manual says check the PGM-FI system for DTCs when that occurs. That's Programmed Fuel Injection in Honda speak. There are 130 pages in that section
Did you get any codes, we can do more from that. That is only 100 pages. Go to Autozone, they'll read it for you (Among others)
One of them is
DTC P0652 Charging System Low Voltage, and its brother.
P1549 is Charging System High voltage
Old 09-17-2018, 04:48 PM
Received 8,568 Likes on 6,621 Posts
Likely just low battery. Your driving it around should have charged it up and you should have no issues.
Old 09-18-2018, 12:28 AM
Tsx780's Avatar
You need a new alternator.
Old 09-18-2018, 10:05 PM
Danosaurus's Avatar
Thanks for the replies guys, I am hoping it's just a low battery since the car has not been driven much. I have not seen the error message again. If it does pop up, I'll have the battery and alternator checked out.
OhhNoVtec
4G TL Problems & Fixes
60
04-26-2020 04:39 PM
Skirmich
09-12-2018 09:29 PM
wmahmud
41
01-03-2017 11:12 AM
MDXOKIE
1/2G MDX (2001-2013)
09-04-2016 08:02 PM
bradykp
1G TSX Problems & Fixes
05-19-2014 02:12 PM
Quick Reply: 2009 TSX "Check Charging Sytem" Warning
