TSX Dynos
Old 01-27-2007, 10:06 AM
  #361
is glad to be back!
tsxdriver's Avatar
Originally Posted by JTso
The way the chart is scaled makes it hard to read. Ask for the dyno file and send it to me.
will do. thanks a bunch!
Old 01-27-2007, 12:05 PM
  #362
Mugen CL9
FreDroRN's Avatar
Originally Posted by tsxdriver
man i don't know.... just got back from the dyno and i'm kinda shocked.... 173HP,158ft/lbs.... does that sound right?
I dyno'd my car back in April 06' with 3 passes - the best pass I hit 183whp / 150 lb/ft. torque.
The mods I had at the time was only the Mugen intake, Hondata reflash, intake manifold gasket, using synthetic oil and less than 5K miles on the engine. Outside temp was about mid 60's with low humidity so the engine wasn't bogged down, but I did dyno with the heavy 19" SSR's instead of the lighter stock wheels
I'm convinced that I could have gotten better results if I had put on the stock wheels.
Old 01-27-2007, 12:13 PM
  #363
Bye TSX, hello domestic?
xizor's Avatar
i read an article in sport compact car (or one of those import mags), lighter vs. heavy wheels had no affect on the dyno at all
Old 01-27-2007, 12:25 PM
  #364
Mugen CL9
FreDroRN's Avatar
The shop where I dyno'd the car told me that the difference would be minimal between the wheels also, but I think it's just me being hardheaded esp. after I saw the numbers posted on the Hondata site.
I'll be going back to the dyno again, hopefully soon, and I'll see if the wheels make a difference since I'm running with the stock wheels now for the winter. The only other difference would be that I have the cat-back exhaust now.
Old 01-27-2007, 12:57 PM
  #365
is glad to be back!
tsxdriver's Avatar
man pretty much the same setup except i don't have the IMG. plus it was hotter when i dyno'd. i must've been about 84-88 degrees outside. ran with royal purple and my gramlights with 6k miles. also ran with the 5zigen single exhaust. perhaps i should swap on my mugen and re-dyno.
Old 02-15-2007, 09:42 AM
  #366
h1coupe's Avatar
got the car dynoed after the reflash and got
about 3-5kw at top final number (average from 2runs) was 130.75kw atw(175whp) up from 170.44whp
and torque was up from 224.7NM(165.7lb.ft) to 247.5NM(182.5lb.ft) that was max not atw.
but like always with hondata the biggest gain was around 6000rpm where I gained around 24-25kw atw around 33whp.
http://www.youtube.com/watch?v=TkYFCOgiYRw
Old 02-21-2007, 11:54 PM
  #367
tracerit's Avatar
Originally Posted by TinkySD
This is an awesome graph for analysis.
dotted blue -Dougs Stock(no intake nor headers)
dotted green -Dougs Hondata + comptech i/h
solid blue -Taewlee Injen CAI
pink -Taewlee Hondata + Injen CAI
you can reference this page, http://www.hondata.com/images/dyno-k...stock-tund.gif, to see dougs' dotted blue line is all stock not with i/h.
Looking at this graph as an example, is peak torque achieved at about 2000rpm? Official specs say that peak torque is available at 4500rpm. Why is the cross at 6000rpm for the torque curve?
Old 02-24-2007, 10:01 AM
  #368
NYT
NYT's Avatar
Originally Posted by vwong
Ok, since my site is back up, here is the dyno plot for my car. Again, it was dyno'ed at Church Automotive Testing (same place Hondata did theirs). And since I forgot to get a print out from him, but I got the raw data. I plotted them in Excel.
You still have this graph that you post or email me?
Old 02-24-2007, 05:37 PM
  #369
minkl81's Avatar
2005 At
Comptech Icebox and Header
RandomTechnology Cat
Tanabe Medallion Touring Catback
UnorthodoxRacing Pulleys
BuddyClub Grounding System
Old 02-25-2007, 10:39 PM
  #370
Is waiting in
rex.'s Avatar
^^ i presume corrected would make it lower?
Old 02-26-2007, 12:34 AM
  #371
minkl81's Avatar
not sure. but think its about average for tsx with auto tranny. also the best run was cutoff even before 7000rpm.
Old 02-26-2007, 08:14 AM
  #372
h1coupe's Avatar
the cross is to show where maximum gain was realised
Old 02-26-2007, 08:41 AM
  #373
Reach's Avatar
Looks like your graphs are cutoff early, right around where the torque converter unlocked. Could be their software that does that. If thats true, its a more accurate result.
Old 02-26-2007, 09:11 PM
  #374
minkl81's Avatar
i think its not the software. they just cut it off before the redline.
i have a sae corrected graph in my other thread.
http://www.acura-tsx.com/forums/showthread.php?t=36334
Old 03-12-2007, 03:07 PM
  #375
Boost Junky
simplyscion's Avatar
bone stock 06 auto TSX dyno'd on a dynojet-Sorry for the large pics, I dont know how to resize them...these are pretty old to, did them back in October or Nov
Old 03-19-2007, 10:49 PM
  #376
1slowTSX's Avatar
'06 Auto
Well here is my dyno result. As you can see, I made 179.87 hp and 142.26 tq. I don't think it accurate though.
According to TOV, the loop area is a false reading. So If my car is anything similar to TOV's car then I should be making 170-175 to the wheels.
Any thoughts.
Old 03-19-2007, 10:54 PM
  #377
JTso's Avatar
The test results are almost identical between the two charts. Time to add Hondata.
Old 03-19-2007, 10:58 PM
  #378
1slowTSX's Avatar
Shoots! Wanna pay for my reflash?
Old 03-19-2007, 11:23 PM
  #379
is glad to be back!
tsxdriver's Avatar
man i still can't figure out how you're producing more power than me!
Old 03-22-2007, 01:23 AM
  #380
Port & Polish Everything
outersquare's Avatar
Old 03-22-2007, 05:33 PM
  #381
n00b
vwong's Avatar
Yes, I still have the graph. My site has changed. Anyways, here it is.
The only mod I have is the Hondata reflash, and that dyno was done back in 2005. BTW, my dyno is also on Hondata's website.
Old 05-04-2007, 07:30 PM
  #382
EuroRuben97's Avatar
With just a reflash... how is that possible. ^^
Old 05-04-2007, 09:27 PM
  #383
NYT
NYT's Avatar
Very cool... thanks for (re)posting this dude.
Fairly substantial power curve gains at 4k+ and there's even a "blip" at 3k too. I gotta get on this sooner than later.
Old 05-09-2007, 10:34 PM
  #384
Nintova's Avatar
Stock vs. Comptech header, K&N intake and hondata
Old 05-10-2007, 12:47 AM
  #385
n00b
vwong's Avatar
^^^ What's with the spike?
Old 05-10-2007, 09:50 AM
  #386
Reach's Avatar
tq converter lock
Old 05-10-2007, 10:12 AM
  #387
Boost Junky
I really would like to get the reflash but my biggest issue is theres still no power down low and thats where I feel like the car is lacking the most...Its almost comparable to turbo lag on some of my other cars from 2-4K rpms...I leased this car so I dont wanna start adding I/H/E so the reflash I feel will be pointless without those additional breather mods. Plus as I mentioned, majority of the power is gained over 4000 RPM's which is not what Im looking for
Old 05-12-2007, 09:35 PM
  #388
kai!
n1ke5h's Avatar
Here's another for the 2006 MT-ers. Only engine mods are Injen CAI and Excedy Stage 1 Organic Clutch kit and Excedy Racing Flywheel, and TB coolant bypass if that counts. Just wanted to get my car dynoed before I get the Hondata done in a few weeks so I can compare.
Did two runs, first one apparently was better. Car was warmed up for about 15 minutes, sitting while I waiting for other people in front to dyno. Also, I think they guy didn't turn off the VSA when he did the dyno, if that matters. I wish I remembered to tell him to though. I also told them to run it until 7000 RMPs but it looks like they cut it before that But look at the VTEC kick in!
Old 05-12-2007, 09:46 PM
  #389
kai!
n1ke5h's Avatar
heres a video of the second run...
http://www.youtube.com/watch?v=1mw66K8DRkU
Old 05-14-2007, 02:18 PM
  #390
n00b
vwong's Avatar
I think he had it turned off. IIRC, you can't even do a dyno pull if the VSA is still on.
Old 05-14-2007, 02:31 PM
  #391
Boost Junky
sure you can, that wouldnt have anything to do with it...why wouldnt you be able to do a pull with it on??
Old 05-14-2007, 02:47 PM
  #392
JTso's Avatar
You can't do a dyno pull on a two-wheel dyno with VSA on because the system will apply braking action to the front wheels when the rear wheels are not moving. I have accidentally left VSA on before and the whole car was shaking on the roller.
Old 05-14-2007, 04:36 PM
  #393
kai!
n1ke5h's Avatar
cool beans...then i guess thats with the VSA off, but i still think i could have gotten higher numbers had he taken the RPMs a little higher. oh well, hondata here i come!
Old 08-22-2007, 12:47 PM
  #394
TSXRudebwoy's Avatar
My 07 made 189hp and 152tq stock
Old 09-17-2007, 10:24 PM
  #395
euro argh's Avatar
just got hondata installed today
i don't really know what the number's mean
but i'm happy with it
oh, and the guy said their afr number's 1.0 higher
Old 10-16-2007, 11:23 PM
  #396
05 Aussie Euro 6MT
Suntzu's Avatar
My DYNOS BAD
Just got my car DYNO'ed for the first time. Its stock.
Heres what I got
I dunno whats going on , thats less than 120 HP ATW
The Air/Fuel is all wrong and way too rich.
The guy doing the dyno started the dyno with VSA on but then turned it off. All the engine check lights came on and stayed on till i restarted the engine later and drove it for about 2 minutes.
Any ideas what might have screwed me here?
Old 10-17-2007, 09:44 AM
  #397
jwood_06TSX's Avatar
I know that the reflash provides a pretty large increase around 5-6k and that your dyno is flywheel HP not WHP, but holy crap, that seems like an AWESOME inscrease. Did you do anything other than hondata? What other mods do you have??
Nice though
Old 10-18-2007, 12:22 AM
  #398
euro argh's Avatar
really?
the guy said it was wheel, oh well
all the stuff is in my sig
Old 10-18-2007, 05:23 PM
  #399
10001110101
feuss2's Avatar
hondata + k&n pod instead of air box
Old 10-18-2007, 05:33 PM
  #400
n00b
vwong's Avatar
^^^ Did you leave out some information? There is no way to have that kind of increase with the 2 mods you listed. Sorry, I have to call this a BS.
Quick Reply: TSX Dynos
