Oil catch can anyone?
Old 06-29-2004, 05:50 PM
  #81
Stokeless
Stokeless_TSX's Avatar
i swear it was ontha intakeside
Old 06-29-2004, 05:52 PM
  #82
JTso's Avatar
Same side...
Old 06-29-2004, 05:56 PM
  #83
Stokeless
ok i quit....my heads hurt
Old 06-29-2004, 06:00 PM
  #84
JTso's Avatar
Step away from the keyboard! NOW!
Old 06-29-2004, 06:02 PM
  #85
Stokeless
i am i am................................................ ..............
Old 06-29-2004, 09:13 PM
  #86
Bye TSX, hello domestic?
xizor's Avatar
TSX559's setup is more ghetto than mine, lol. nothing holding it down
Old 06-30-2004, 07:23 AM
  #87
gogozy's Avatar
Old 07-01-2004, 12:43 PM
  #88
TSX559's Avatar
I Dont Have Any Time To Make A Bracket. And I Do Have Something To Hold It Down Xizor. I Have Clear Zip Ties. You Just Cant See It. I Want To Make It Look Ghetto Just Likes Your Xizor. Lol. And I Have One More Question, Can I Pour The Oil Back Into The Engine? Or Is That Bad?
Old 07-01-2004, 03:19 PM
  #89
JTso's Avatar
You don't want to pour it back to the engine. That contaminated oil/oil vapor in the can is normally routed back to engine and burn off. So, just dump it out.
Old 07-01-2004, 07:39 PM
  #90
TSX559's Avatar
thankz a lot JTso. you have helped me a lot with my tsx. you da man.
Old 07-03-2004, 01:13 PM
  #91
TSXChef's Avatar
Warning label
Hey guys,
Did you guys see this Explosion warning label on your filters?? Should I be concerned about this?? Since most of you guys have the similar general filter installed, I'm thinking not... but I'm going to be using full Synthetic oil from this point on so I ask the question.
Thanks!
Old 07-05-2004, 07:59 AM
  #92
Stokeless
Originally Posted by JTso
Same side...
Johnny are you using the same filter as the rest of the guys i see the top of yours is black theirs is blue??
Old 07-05-2004, 10:25 AM
  #93
xizor's Avatar
mine's black. I believe the color depends on what store you buy it from, mine was from Lowe's.
Old 07-05-2004, 10:30 AM
  #94
JTso's Avatar
They are the same. The only difference is the color. I think the bowl explosion problem has to do with high pressure air going through it in the normal air compressor setup. It's now working with about 26" of vaccum in our setup.
Old 07-05-2004, 01:31 PM
  #95
Stokeless
hmmm ok i got it
Old 07-07-2004, 12:09 AM
  #96
tai
All Show, No Go!
tai's Avatar
I like that alot thanks for the idea!!! Good job man!!
Old 07-11-2004, 09:04 PM
  #97
TSXChef's Avatar
Does yours get really hot?
Hey guys,
First, thanks for your write-up (JTso/Xizor)! I got mine installed thanks to you. HOWEVER, I do have a question, does your hose & your filter get really hot to touch?? I drove for about an hour (it was pretty hot day, 88F) and the hose and the filter was pretty hot to touch... just wanted to know if you guys are getting the same thing. Also another question then, sorry, is there such thing as temperature ratings for these PCV hoses?? Thanks!
Old 07-11-2004, 09:49 PM
  #98
xizor's Avatar
looks good, i think you can shoften up the hoses a bit, if you want a little cleaner look. check mine out on pg 2, I routed my return line to the injector base on the other side of the alternator to avoid routing around the pulley. i'll post some pics w/ the intake manifold cover off tomorrow.
I haven't touched the lines, but they are carrying oil vapor, so its normal that its hot. I don't think its a problem though as the S2000 users have been taking them to the track w/ no problems at all.
Old 07-11-2004, 10:00 PM
  #99
TSXChef's Avatar
Great, thanks bunch for your feedback!
I did make sure that my quick-ties are all loose, just to make sure that I wasn't choking the flow. I also used clear packaging tape around the glass/plastic portion in case they explode/implode, which I'm sure it's unlikely.
Thank you again!
Old 07-12-2004, 08:10 PM
  #100
xizor's Avatar
This is my setup w/o the intake manifold cover on. I reused the original tubing and added another one.
Old 07-12-2004, 10:02 PM
  #101
TSXChef's Avatar
Cool. Thanks!
I drove about 90 miles so far and collected few drops of oil already.
Old 07-14-2004, 06:14 PM
  #102
xizor's Avatar
I found this filter browsing though a catalogue today, very inexpensive and the built in gauge seems cool, Its smaller though, and of unknown quality.
link
A lot cheaper than the $20-25 I paid for mine at Lowes.
Old 07-14-2004, 07:19 PM
  #103
JTso's Avatar
Hahaha... you don't need that man! That's an air compressor filter and pressure regulator combo.
Old 07-14-2004, 07:27 PM
  #104
xizor's Avatar
haha, I said "cool" not useful
And I got mine, just thought maybe someone else wants a cheap one... that measures... something... whatever
Old 07-14-2004, 09:06 PM
  #105
TSXChef's Avatar
...A lot cheaper than the $20-25 I paid for mine at Lowes.
I paid $12.99 for my filter at local Auto-zone store, little cheaper there than Lowes I guess.
Old 07-14-2004, 09:09 PM
  #106
xizor's Avatar
can you find it on their website? might help people find cheaper parts than i did :'(
Old 07-14-2004, 09:54 PM
  #107
TSXChef's Avatar
I looked around Autozone and I'm unable to find it online. The product number from Autozone is (MP5138) based on my receipt, $12.99
However, here is the actual manufacturer site:
CHPOWER.COM
If you go to their site, there are two products that may work for our application:
1. Mini General Purpose Filter: Model: MP513810 (one that I bought, I hope my SCFM per PSI is correct)
2. General Purpose Filter: Model: PA2121
Hope this helps...
Old 07-15-2004, 08:48 PM
  #108
I make Boom Boom in
txathlete's Avatar
okay, i got my kit today sans pcv hose. my filter unit costs $11.97 at home depot and the npt adapters were $1.19 each plus 4 metal clamp thingys for $0.87 each, total plus tax = $19.30. Where can I get the pcv hose?? Lowes didn't have one with a 3/8" inner diameter fuel hose. Where can I get a bracket or I can ghetto rig it with zipties?
Old 07-15-2004, 08:53 PM
  #109
I make Boom Boom in
txathlete's Avatar
Hey Zixor, did you need that other piece to the right of the filter?
Old 07-15-2004, 09:03 PM
  #110
xizor's Avatar
You can ghetto zip tie it, its worked very well for me so far. And the piece on the right is the throttle body bypass mod, you can search for more info on that one.
Old 07-16-2004, 07:25 AM
  #111
TSXChef's Avatar
PCV hose can be found at Autozone or PepBoys. I paid ~$4.00 for 4 feet.
As Xizor pointed out, zipties are quick and easy solution to fasten the hose.
I don't know if it makes sense, but I put a clear packaging tape (2" wide) once around the glass/plastic portion in case of breakage... hope it never happens of course, afterall mine gets pretty hot after drive and filter I think is rated for 115F max...
Old 07-16-2004, 09:51 AM
  #112
xizor's Avatar
post the homedepot part #'s so others can find it easily. I couldn't find it at my local HD for the life of me.
Old 07-17-2004, 10:14 PM
  #113
I make Boom Boom in
txathlete's Avatar
The fuel line hose - part no. 301018 (3/8" I.D. X 2 ft.) - $3.49 @ Pep Boys.
NPT Attachment - UPC#: (0)4556420579(9) - 1/4" NPT male and 3/8" female - $1.19 @ Home Depot located in the air compressor/tools department.
Metal screw clamps - UPC#: (0)7857516306(2) - Size 06, 10-22mm - $0.89 @ Home Depot plumbing section.
Mini General Purpose Filter - USA SKU: 401-910, CAN SKU: 131-688 - Husky brand NDC #: (0)4556460664(0) - $11.97 @ Home Depot located in the air compressor/tools department.
How's that Xizor?
Old 07-18-2004, 06:28 PM
  #114
berksean's Avatar
Does PVC hose = Fuel line hose? I think I bought the same stuff as TSXChef (Hose has the SAE 30R7 marking on it), but on a subsequent trip to home depot I found some clear PVC hose in the plumbing section that seemed a whole lot stiffer. Will the fuel line hose suffice (I see several people are using it on their setups)? I tried comparing the fuel line hose with the stock hose (with my oh so precise finger-pinch-ometer), and they seem pretty similar, with both being MUCH softer than the PVC hose (wasn't even able to bend the PVC hose much at all).
As a side note, is it PVC or PCV? All the hoses at home-depot are labeled PVC, but google confirms the existance of a PCV hose as well?
Thanks for your help!
Old 07-18-2004, 10:51 PM
  #115
I make Boom Boom in
txathlete's Avatar
I do believe that PCV is different than PVC hose. My fuel line hose says that it is a "nitrile hose that resists teh effects of oil, gasoline, and pressure. Reinforced for maximum burst strength. Durable cover resists abrasions, weather, heat, and ozone. Designed to meet or exceed OEM requirements." PVC sounds like the tubes you use for plumbing and water lines and pipes. I did see someone on the thread with what looks like a vinyl hose. Is that safe?
Old 07-18-2004, 11:04 PM
  #116
xizor's Avatar
I used fuel line hose as advance auto didn't even sell pvc hose. Seems to be working ok for me. Home depot had PVC, but only in clear which was too ugly to bear.
Old 07-19-2004, 01:09 AM
  #117
JTso's Avatar
I used fuel line/PCV grade hoses and NAPA auto parts should have them. They are more expensive than just regular fuel lines as it also needs to handle heat and not get brittle and falling apart or deteriate inside. You can use fuel line/PCV quality hose for both fuel line or PCV applications, but shouldn't use fuel line grade for PCV. If you have both types side by side, you will see and feel the difference. I know many auto parts stores sell fuel line as PCV hoses but some will carry the correct type. However, it probably won't cause any problems if you just monitor the condition of the hoses from time to time.
Old 07-19-2004, 01:30 AM
  #118
I make Boom Boom in
txathlete's Avatar
JTso, so should I return my hose and try to find some real PCV hose? It seems like most of the auto parts stores sell "fuel line" type hoses. When removing the hoses, do you need to clamp them down with pliers like the throttle body hoses?
Old 07-19-2004, 09:08 AM
  #119
JTso's Avatar
If it's already installed, then I wouldn't worry too much about it. I'm just more picky about how things are done. If you want to remove the hoses, It's not necessary to crimp them down because nothing will leak out.
Old 07-19-2004, 09:31 AM
  #120
I'm allergic to bull
Helicobacter Pylori's Avatar
JTso, is this what you are talking about??
NAPA Belts and Hoses Fuel Line / PCV / EEC Hose -- .375'' (9.53mm)
Item#: NBHH177
Price: $ 0.99
Attributes: Fuel Line / PCV / EEC Hose
I.D.: .375'' (9.53mm)
Working Pressure: 50 psi
Type of Packaging: Reel
Quick Reply: Oil catch can anyone?
