Oil catch can anyone?
Old 06-21-2004, 01:57 AM
  #41
JTso's Avatar
No, it has to be mounted vertically. If you mount it horizontally, oil can get sucked in to the intake manifold when the oil level reaches the filter.
Old 06-21-2004, 03:45 PM
  #42
Bye TSX, hello domestic?
xizor's Avatar
I ended up mounting mine on the AC line, which gets really cold. Think its possible that the hot vapor inside the catch can and cold line next to it could cause the glass/plastic to shatter?
Now what else can I do to make my engine bay like JTso's... hmmmm, where's that CompTech strut bar , j/k
Old 06-23-2004, 12:48 AM
  #43
yup.
kangjin's Avatar
just picked up the parts today...
xizor and jtso, did you guys remove the black spiral disc inside, as recommended by the guys at s2ki for better flow?
the thread is here
a direct link to the image here
also, i wonder if the length of the vacuum tubing has any effect on the performance of the catch can?
great post!
Old 06-23-2004, 01:42 AM
  #44
JTso's Avatar
Yes, I've removed the spiral disc. The total length of hose that I used didn't have any problems operating the pcv valve. It has collected quite a bit of oil since the installation.
Old 06-23-2004, 01:50 AM
  #45
Stokeless
Stokeless_TSX's Avatar
Johnny when i get back can i come over to your place and look at yours? i wanna make it exactly as you did...very clean install...and do you have the welder or did you go somewhere to get the bracket made?
Old 06-23-2004, 08:34 AM
  #46
xizor's Avatar
I removed the spiral piece as well. And I haven't driven far enough to collect any oil yet, but my hoses are shorter than JTso's.
And Stokeless, you don't like my ghetto rigged zip ties? I'm offended, j/k. The maker of the filter sells a fitted bracket that looks just like the one JTso for the catch can.
Old 06-23-2004, 09:33 AM
  #47
JTso's Avatar
Stokeless, I hand made the bracket and welded it myself. However, like xizor mentioned, a bracket is available but some modification might be necessary for the proper mounting. Mine was made to fit in that exact location.
Old 06-23-2004, 09:37 AM
  #48
xizor's Avatar
here's what their bracket looks like
it has a ton of holes as its "universal", so I would think at least 1 would be in the correct position for the window fluid bolt.
Old 06-23-2004, 10:06 AM
  #49
Stokeless
i think im gonna go with johnny on this one hehehe..ill be over in october johnny =)
Old 06-24-2004, 05:26 AM
  #50
moda_way's Avatar
Bought all the materials yesterday and noticed on the back of the catch it say something to the affect of not using with synthetic oils, etc etc.... Wonder if my synthetic oil in the car will damage anything.
Other question, did you just get vacuum hose from a local automotive store?
Old 06-24-2004, 11:14 AM
  #51
JTso's Avatar
I saw that synthetic oil label too. The o-ring could be the only thing that can be affected by synthetic oil. I'll have to wait and see. If it wears out, I'll just go to the hardware store and get a different one. You need to use PCV hoses. Most vacuum hoses won't come in that dia.
Old 06-24-2004, 11:17 AM
  #52
Stokeless
roger doger
Old 06-25-2004, 05:34 AM
  #53
moda_way's Avatar
Started thinking more and more about the label and the purpose of the unit... If you think about it, what it is probably saying is that if you use synthetic oils in your compressor system, then the potential for it to by-pass or clog the plastic piece of the filter may occur. Because we take it out, it may not be cause for alarm. Just a thought.
Old 06-25-2004, 08:28 AM
  #54
gogozy's Avatar
which plastic piece? filter? or ? the worse i can think of is synthetic degrade some plastic and cause it to emit some bad gas.
Old 06-25-2004, 07:25 PM
  #55
TSX559's Avatar
Old 06-25-2004, 07:28 PM
  #56
TSX559's Avatar
does your filter get really oily? i drove it about 100 miles in 3 days and the filter is really oily. i dont think it even filter out the oil. i can see a little bit of oil in the output side of the unit. is that bad? im just concern.
Old 06-25-2004, 07:31 PM
  #57
TSX559's Avatar
JTso by looking at your picture, your filter looks a lot better then mines. my filter is like brown already. do you think that we can replace the filter and get a better one that will filter our more oil? if so that will be good.
Old 06-25-2004, 07:35 PM
  #58
JTso's Avatar
Did the bottle collect any oil? Is you oil dirty? It's normal for some oil vapor to get past the filter. The purpose of the catch can is to cut down the amount of oil going into the intake port but it won't eliminate it. Post some pic of your setup.
Old 06-25-2004, 07:49 PM
  #59
JTso's Avatar
A few more hundred miles later since the installation... The bottle is getting full.
Old 06-25-2004, 09:49 PM
  #60
Stokeless
yea johnny you are gonna have to help me with mine =) i got money i can pay or ill take you to chinatown =) there is actually a really decent place close to where we live too. But i usually head into chinatown let me know =) ill be back in october haha
Old 06-26-2004, 01:47 AM
  #61
xizor's Avatar
I drove 250 miles 2 days ago and collected about half of that!! I'll post some pics tomorrow, yikes!
Old 06-26-2004, 09:41 AM
  #62
Stokeless
damn
Old 06-26-2004, 05:53 PM
  #63
xizor's Avatar
Collected over 400 miles.
Old 06-26-2004, 07:31 PM
  #64
JTso's Avatar
It looks like we need a larger bottle. LOL! I just saw this one at Sears for $24.99. Sears item #00916008000
Old 06-26-2004, 07:41 PM
  #65
xizor's Avatar
ick, I'd hate to have that thing in my engine bay. at this point, one of the huge Greddy or Cusco cans seems necessary, but do they even have a filter?
Old 06-26-2004, 09:59 PM
  #66
JTso's Avatar
Nope, no baffle or filter at all.
Old 06-26-2004, 10:07 PM
  #67
xizor's Avatar
so how do they even work? just hope the oil vapor condenses while in the can and doesn't exit?
Old 06-27-2004, 12:26 AM
  #68
JTso's Avatar
It will work but not as effective as one with a baffle or filter. More oil will get to the intake port as the result. Then again, how many mods out there are simply for looks?
Old 06-27-2004, 01:06 AM
  #69
Stokeless
just for looks omg whats that?
Old 06-28-2004, 06:22 PM
  #70
TSX559's Avatar
Hey JTso i dont have a way to host my setup, but i can e-mail you the pix
Old 06-29-2004, 07:03 AM
  #71
gogozy's Avatar
i forgot i read it somewhere, but can someone confirm that if engine oil is main cause for carbon build up in intake area?
thanks...
Old 06-29-2004, 10:00 AM
  #72
xizor's Avatar
I believe JTso said it earlier (in this thread?), he probably knows a source
Old 06-29-2004, 11:20 AM
  #73
JTso's Avatar
Oil is not the only cause of carbon buildup. Fuel is another source. Here are some info....
http://www.federal-mogul.com/cda/con...6_7501,00.html
http://www.ngkspark.com.au/bulletin_T01-5.htm
Old 06-29-2004, 11:21 AM
  #74
TSXChef's Avatar
Hey guys,
I'm about to install the Oil Filter setup. Any last minute comments, cautions, or suggestions? thanks.
(I purchased all the items from AutoZone after few attempts at HomeDepot and another smaller AutoZone)
BTW, Thank you guys for this great information and the "how-to"s!!!
-Chef
Old 06-29-2004, 11:40 AM
  #75
JTso's Avatar
TSX559, you've got pm.
Old 06-29-2004, 05:14 PM
  #76
JTso's Avatar
Here is TSX559's setup. You need a bracket bro.
Old 06-29-2004, 05:38 PM
  #77
Stokeless
i think somehow the pix got flipped backwards....our tranny should be on that side =)
Old 06-29-2004, 05:40 PM
  #78
JTso's Avatar
Stokeless, are you still drunk?
Old 06-29-2004, 05:42 PM
  #79
Stokeless
yyup...im hurtin man i didnt mean to say it that way what i jatnt to say was that the catch can shoujld be on the othesa ide like youres right??.
Old 06-29-2004, 05:46 PM
  #80
JTso's Avatar
Itt's on thea saam sde. It jstu needs a brkket.
Quick Reply: Oil catch can anyone?
