Hondata: Post your long term reviews
Old 09-11-2015, 01:30 PM
4th Gear
urbtsx's Avatar
Post up about your experiences with Hondata for the long term. How long you've had it, any issues, and just your thoughts in general.
Curious to see how it is over time.
Thanks!
Old 05-29-2016, 12:17 PM
me3
me3's Avatar
depends on the mods you have or will have ......sometimes it's not worth it
Old 05-31-2016, 09:47 AM
Jdrum1's Avatar
Are you referring to just a Reflash or Flashpro?
Stock, then Flashpro isn't necessary, but a Reflash seems to yield some good results.
Old 05-31-2016, 09:43 PM
green_henry's Avatar
Unless you are going the forced-induction route (which is very expensive), the reflash is the way to go.
I have had mine for ~6 years and ~72k. I can't imagine going back to stock, especially now that I'm taking it to the track.
No issues that I can attribute to the reflash.
It's a no-brainer. Do it (if you haven't already).
Old 06-23-2016, 01:50 AM
Acuragirl23's Avatar
Old 07-10-2016, 11:44 AM
6th Gear
TYPExR's Avatar
I had both and here is my take.
I had the reflash for about 30k miles and loved every moment with it. My other mods were Injen CAI, UR pulleys, and CT Header. Top end just felt smoother and kept pulling till the 7600 rpm redline. Shifting into the next gear was also improved.
The fun eventually wears out and that's when I went to the route of force induction. Of course now I had to get the FlashPro with this setup: CT Intake, CT Supercharger, CT Header, Fastline high flow cat and Fujitsubo catback. Vtec was even lower and with all this mods, it felt like a car with 6 cylinders.
So really it depend on the mods you get. Reflash was great for a near stock car. Anything more, you are required a FlashPro. Both are reliable if tuned properly with the FlashPro.
Old 07-24-2016, 03:01 AM
lt23's Avatar
https://www.hondata.com/forum/viewto...p?f=11&t=19593
Old 02-20-2017, 03:28 AM
6th Gear
Nenad1985's Avatar
Definitely go for Reflash!
Old 03-04-2017, 06:29 PM
teng_her's Avatar
I am wondering also. Anyone here choose the reflash over kpro and vice versa? I suppose i'll get the "depends on mods" answer. From what I understand, reflash is a good bang for buck upgrade along with bolt ons. Kpro, on the other hand, is meant as a means to get the most out of your motor and will allow for more aggressive builds such as cams....someone correct me.
Old 03-04-2017, 06:53 PM
kpro is only needed if you are adding cams, supercharger, or turbocharger. I suppose you could tweak a few things with the normal set of mods (header, intake, etc) but the minor gains would not be worth the extra expense.
RDX10
1G RDX (2007-2012)
19
11-08-2019 01:54 PM
pstomps
02-20-2017 03:29 AM
ostrich
09-11-2015 04:28 PM
Quick Reply: Hondata: Post your long term reviews
