buying a used hondata TSX?
I am looking at buying a 2006 TSX Manual transmission ECU Hondata Reflashed for a 2006 TSX Manual Transmission, to verify, i will still have to get the immobilizer reset but I can do this?
should be fine with the ecu. I can probably help you with immobilizer programming if your are in the US. Just wonder are you going to just do bolt-on or do you have bigger plans? Might be worth it to get a full hondata instead of just a reflash, but it really depends on your goals.
Not even going to do bolts on probably, only mod to engine i expect to do is the hondata intake maniford gasket as well.
Car has 166k on it this is as much as an investment as I should make i think in performance engine wise
Here reflash vs kpro
Hondata K-Pro and reflash FAQ/Tuning resources - Club RSX Message Board
per hondata website
https://www.hondata.com/reflash-cate...flash-tsx-2006
per hondata website
per hondata website
per hondata website
