What parts from 91-95 legend bolt on or directly replace our tl?
Old 11-02-2009, 02:59 AM
bwallace530's Avatar
I have found a ton of legend all the sudden at junk yards and i was wondering what fits more on our tl's 91-95 what year would be better to part off of. And what parts can be replaced or changed. like engine, brakes, ecu im basicly just trying to see what all could go on to our cars.
And how hard would it be to take out a type II manifold?
Old 11-02-2009, 04:00 PM
'13 Hyundai Sonata
TLin401's Avatar
The brakes and manifold fit.
Get a Type-II manifold and also brake calipers.
Old 11-02-2009, 08:15 PM
so i can just take the brakes off the one at the junke yard and directly bolt them on to my car i do need new brakes would it in prove anything?
and how can i tell if it is a type 2 manifold? How hard will it be to take it out of the car that i found.
Old 11-02-2009, 08:17 PM
大日本帝国
Go90go's Avatar
It'll say Type-II or have a little rectangle where it used to say Type-II.
~Cheers~
Old 11-02-2009, 08:24 PM
'13 Hyundai Sonata
TLin401's Avatar
It should say Type-II right on it.
Old 11-02-2009, 08:35 PM
okay the ones that i was looking at they dont say type II, is it only certain years and models? What tools should i bring to take the manifold out?
Old 11-02-2009, 08:40 PM
'13 Hyundai Sonata
TLin401's Avatar
This is what the manifold looks like.
Old 11-02-2009, 08:41 PM
'13 Hyundai Sonata
TLin401's Avatar
This thread may help.
https://acurazine.com/forums/showthr...egend+manifold
It gives you some info on it.
Old 11-02-2009, 09:43 PM
And if it does not have the type II on it then its not the type II
Old 11-02-2009, 09:46 PM
'13 Hyundai Sonata
TLin401's Avatar
Yes I believe so.
Old 11-02-2009, 09:50 PM
Okay and that link you posted help alot so when i go to take the intake out should i take everything that is in this picture or should i just take the intake manifold? How many hours of work should this be? And does anyone no the power i should gain.
Old 11-02-2009, 09:53 PM
'13 Hyundai Sonata
TLin401's Avatar
Yes I would get everything that was mentioned in the thread.
The Legend had the same engine as the 3.2 but the Type-II had ~50 HP than the normal Legend.
You should see/feel a gain in HP with it.
Just don't do anymore burn outs.
Old 11-02-2009, 10:00 PM
lol i wont do anymore of those stupid burn out that i was doing.
/forums/f40/diy-egr-intake-manifold-cleaning-68465/ I found this im not sure if it has anything to do with our cars but it is very informative so im reading it. Will the type II give me 50 more hp? or how much if you no?
Old 11-02-2009, 10:04 PM
'13 Hyundai Sonata
TLin401's Avatar
I don't think that it will give you ~50 more but I think it will give you ~10+ but I don't have a 3.2 so I could be wrong.
Old 11-02-2009, 10:13 PM
Okay well anything would be better then what i have now.
Old 11-02-2009, 10:17 PM
'13 Hyundai Sonata
TLin401's Avatar
Exactly.
GL with everything.
Let us know how everything goes.
Old 11-02-2009, 10:19 PM
Yeah i will let you all no how it goes i wont be doing it for a while i want to make sure i got all the parts and gaskets before i take everything apart.
Old 11-03-2009, 11:21 AM
Khmer Pride
KrayzieDxC's Avatar
i think you have to port that type ii intake...its not a drop in and drive.. you have to ported ..search through these thread first before anything..cost more money to port
Old 11-03-2009, 01:27 PM
What is ported mean? I found the whole intake manifold everything not just the top part for $130. And found one at a pick and pull for 45 just the top and it was a type 1.
I also need brake pads and rotors can i get those from the legend also. One guy my father knows goes to the junk yard all the time for his bmw service shop get rotors and pads all the time from the pick and pulls he was saying that just cuz the car was in a wreck doesnt mean that the brake and pads are bad i guess he finds almost brand new ones out there not all shinny but good condition. sorry about mubbling on just thought i would tell someone about it.
Old 11-03-2009, 02:32 PM
KaMLuNg's Avatar
Received 1,090 Likes on 767 Posts
the Type II legend was 230hp vs our 200hp that came with the Type I and our 1G TL... the difference of 30hp came from the intake mani and the Type II heads... the intake mani should give you a substantial amount of power but you won't gain the extra 30hp without the heads... (you do not need to port the intake mani to fit on our engines, it is a direct drop in)...
you won't be able to run the T2 heads on our cars since our ECUs are OBD-II versus OBD-I on the legends, unless your repin and rewire your whole harness like Ken1997TL did...
Type II brakes are dual piston calipers versus our single piston... i have a DIY that shows the upgrade... they are direct bolt on... pads and rotors are interchangable with the rotors...
Old 11-03-2009, 02:37 PM
Ken1997TL's Avatar
Received 2,328 Likes on 1,308 Posts
Take it from me, just get the intake manifold and the brakes.
Old 11-03-2009, 03:25 PM
desired_speeds's Avatar
don't confuse him, no you don't have to port the intake, it is 100% bolt on. There are no modifications needed for it to be swapped onto a C32a6 block.
I agree.^
Old 11-03-2009, 11:11 PM
Okay thanks for clearing that up for me
Old 11-04-2009, 04:14 PM
And what year rotors and pads does it have to come off a specific year and model of the legend?
Old 11-04-2009, 04:18 PM
'13 Hyundai Sonata
TLin401's Avatar
Get the Type-II calipers.
The calipers fit the rotors that you have now. When you put the caliper on, you put the bracket and pad for the TL on the Legend caliper and that is it. It is an upgrade to any brake system.
Old 11-04-2009, 08:01 PM
96TL_X's Avatar
The type II manifold took my friend and me 1h30 to get. Actually, he did the job mostly himself while I took out other part like the cluster, backseat and other stuff. If u have the right tool u may finish it shorter.
Old 11-04-2009, 08:10 PM
'13 Hyundai Sonata
TLin401's Avatar
It all depends on how good you are with tools.
Old 11-04-2009, 09:35 PM
Khmer Pride
KrayzieDxC's Avatar
my bad then..might read it somewhere else then
Old 11-04-2009, 09:59 PM
TL and legend pads are the same. You can use anything from a Legend, type I or type II (same shit), TL, odyssey, integra type R, prelude, i forgot what else.
in his case, it would be most beneficial to use the legend caliper bracket and use Legend type II calipers which are about 3-4mm thicker than the standard rotor.
it takes me about 20 mins give or take to remove a type II intake manifold at the junkyard. no special tools are needed: a ratchet, an extension, 12mm socket, 10mm socket, 10mm wrench, 8mm socket to remove coil packs, and cutters.
Old 11-04-2009, 10:10 PM
what I meant to say was:
in his case, it would be most beneficial to use the legend caliper bracket and use Legend type II ROTORS which are about 3-4mm thicker than the standard rotor
Old 11-05-2009, 10:25 AM
Now would that be for all four tires?
Old 11-05-2009, 10:48 AM
'13 Hyundai Sonata
TLin401's Avatar
Yes.
Old 11-05-2009, 02:59 PM
what would be for all four tires.
Old 11-05-2009, 05:15 PM
Khmer Pride
KrayzieDxC's Avatar
i think he meant wheel wells
Old 11-05-2009, 07:40 PM
the front rotors are bigger if thats what you meant.... keep the rears stock.
Old 11-06-2009, 01:31 AM
Okay now why can you use them in the rear?
Old 11-06-2009, 02:32 AM
1. Legends use brake shoes for the parking brake. There would be no place for the TL's parking brake cable to hook onto.
2. The rotors are the same thickness and the pads are the same
3. They're both 1 piston of the same size
4. The rear barely contributes to the stopping power so even if you upgraded it, you would not see a difference in braking.
Old 11-06-2009, 11:22 AM
Old 11-06-2009, 11:40 AM
what tools will be need to remove to rotors and calipers?
Old 11-06-2009, 12:24 PM
'13 Hyundai Sonata
TLin401's Avatar
You cannot remove the front rotors yourself.
If they are the same as the 1G TL you need a press to take the rotor off.
So if that is the case, you will need the whole driveshaft.
I believe for the calipers you need a 10mm and 12mm
Quick Reply: What parts from 91-95 legend bolt on or directly replace our tl?
