1996 Acura 2.5 TL Manual Trans Swap
Old 11-06-2011, 08:05 PM
4th Gear
CCxDemi923's Avatar
Hello everyone. Please don't criticize me on this question, but the transmission in my '96 TL is going, and I was wondering if there was a manual trans that I could use to swap into it. If anyone could give me information on what I could use, and what I would need for the swap, it would be really appreciated. Also, I heard that the trans from the Acura Vigor worked, any ideas?
Thanks.
Old 11-06-2011, 08:29 PM
main70072's Avatar
If you search on here Vigor swap, you will find quite a bit of information that some have compiled although I don't think it has ever been done before (at least I haven't seen one).
Old 12-27-2011, 09:19 AM
7th Gear
Nytelighter's Avatar
Any luck?
Any luck finding out if there is a way to put a manual tranny in a 1st Gen 2.5 TL? I'm a complete Noob but I know the Acura CL (2.2. 3.0, 3.2 etc..etc..) came with a manual tranny. Anyone know if there is a way to drop one of these bad boys in a 1stGen TL?
Old 12-27-2011, 10:22 AM
大日本帝国
Go90go's Avatar
No. You're looking in the wrong direction.
~Cheers~
Old 12-27-2011, 11:01 AM
7th Gear
Old 11-06-2014, 05:18 PM
3rd Gear
Fredrick Houston's Avatar
Which direction should we be looking in???
Old 11-17-2014, 11:04 AM
4th Gear
JonnyAndeola's Avatar
Complete engine and tranny swap. Nothing is impossible! There should be a Honda motor with a manual transmission that will work in the TL. But you have to think your going to have to customize to fit and upgrade almost everything else and its going to be a highly expensive and time consuming project. But if you do it you will have the best TL out there! But your better off just buying an NSX haha
Old 11-18-2014, 05:57 PM
大日本帝国
Go90go's Avatar
Three years since I posted that, haha. Damn.
Look for another Honda that has the same motor = Vigor.
~Cheers~
Old 12-16-2014, 03:03 PM
5th Gear
G25aTL's Avatar
The 5 speed with the vigor with bolt up to the 2.5 in the tl. Since they are are essentially the same car. But the vigor had a manual option.
Old 12-16-2014, 03:05 PM
5th Gear
G25aTL's Avatar
Matter fact is a video link with one that has the vigor speed and its turbo'd
lland
10-04-2015 04:47 PM
Skirmich
09-15-2015 06:41 PM
Allen_442
09-08-2015 06:01 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: 1996 Acura 2.5 TL Manual Trans Swap
