Quarter Mile Time Compilation
Old 12-02-2014, 06:59 AM
  #721
Grand_hustle17's Avatar
14.8@97 on varrstoen ES1 30lb wheels and full interior. Also bent valves
Old 12-04-2014, 09:21 PM
  #722
7th Gear
yogitls's Avatar
I went 15.920 at 93 stock 07 tls auto leaving off idle
Old 12-12-2014, 09:26 AM
  #723
Slot Machine Lubricator
1black_seven's Avatar
^ouch!
Old 12-13-2014, 04:35 PM
  #724
All motor
Sonnick's Avatar
Was able to go to Atco today Full bolt ons/3.84 Final Drive/Dom street tuned
The following 5 users liked this post by Sonnick:
anx1300c (12-14-2014), EvilVirus (08-26-2016), F23A4 (12-17-2014), SatinSilverAV6 (12-16-2014), TylerT (12-14-2014)
Old 12-13-2014, 05:41 PM
  #725
I've seen new stingrays put down that 1/4 time. 13.1 to be exact. Pretty quick for a Accord I'd be happy if my TL did that, and pissed if my Corevette did that.
Sonnick (12-13-2014)
Old 12-13-2014, 05:49 PM
  #726
All motor
Sonnick's Avatar
That is a poor, poor time for the new Stingray.
Car feels great, it's the fastest its ever been If only I could've gone on DRs!
F23A4 (12-17-2014)
Old 12-14-2014, 09:06 PM
  #727
anx1300c's Avatar
Sonnick, you're picking up 23-24 mph on the second half. That's insane. Screw drag radials; get slicks for spring.
Sonnick (12-14-2014)
Old 01-18-2016, 09:47 AM
  #728
mr600r's Avatar
Latest 1/4 run
Latest and quickest run even in the 07 tls 5at.
Car is making some power. On thing I hate about the TL is heat soak. When we 1st got there hot off the street went 14.7 14.8 95mph and 99mph. After a 30 min cool down and ice the intake it went 14.1 twice. One at 101 and the 2nd 103! I was shocked! Previous best was 14.3 in warmer weather very pleased with the car. Nearly fully bolted (PC,j pipe, custom cat back TB spacer AEM) the auto weak point is the 60ft. Pretty close to 13s 69 foot in a 2.1 would get it there. What other mods should I do??? I was thinking about getting lower intake ported, posts I've read give good feedback. Suggestions??
Old 01-20-2016, 02:14 PM
  #729
All motor
Sonnick's Avatar
3.7 intake manifold and throttle body.
Old 01-20-2016, 08:59 PM
  #730
anx1300c's Avatar
That, plus 4" intake, ported runners and Flashpro.
Sonnick (01-21-2016)
Old 01-21-2016, 12:30 PM
  #731
anx1300c's Avatar
You get a new car yet Sonnick?
Old 04-24-2016, 05:39 PM
  #732
eastsideride's Avatar
So ladies and gents, just racked in a new time for a BONE STOCK (except Tein Basis coils) automatic 2004 Base TL.
1/4 Mile: 14.765
60': 2.238
MPH: 94.93
Numidia Raceway
68 degrees out
24% Humidity
Old 05-11-2016, 08:50 PM
  #733
2003 Accord Coupe V6
SatinSilverAV6's Avatar
1/4 Mile: 14.765
60': 2.238
MPH: 94.93
Numidia Raceway
68 degrees out
24% Humidity
great time! I think that is the fastest stock time for a 3rd gen auto TL!
Old 07-17-2016, 06:51 PM
  #734
TheTLProject's Avatar
I broke into the 13's with my base 06 auto with 160k. All motor, full bolt ons, gutted. If my memory serves me right I am the first to do this without a supercharger/turbocharger/nitrous. Time and mod list is below. Going for mid 13's in the fall.
13.9 @ 103mph
116 feet elevation
90 degrees outside
1800rpm brake torque launch
34 front/37 rear tire pressure
AEM 3.25 inch Cold Air Intake
Throttle Body Coolant Bypass
EGR Valve Bypass
J37 Throttle Body
J37 Intake Manifold
P2R J37 Throttle Body Spacer
P2R J37 Intake Manifold Spacer
P2R J37 TB Thermal Gasket x2
P2R J37 IM Thermal Gasket x1
RV6 Hi-Flow PreCats
ATLP V2 J-Pipe
JE Test Pipe
Vibrant 2.5 inch Inlet/Outlet Ultra Quiet Resonator
XLR8 Y-Pipe
Rear Mufflers Delete w/ XLR8 Single Tips
UR Lightweight Underdrive Crank Pulley
AEM Fuel/Ignition Controller
BoomSlang Adapter Harness
BrakeLogic Drilled/Slotted Front & Rear Rotors
Hawk HPS Brake Pads
BFGoodrich GForce Comp2 A/S 235/45/17 Rear
Bridgestone Potenza RE71R 235/45/17 Front
Lightweight Wheels
Stock Suspension
Pro-Tuned By JE Import Performance
Weight Saved:
Hood Insulation (2lbs)
Stock Airbox Replaced w/ CAI (8lbs)
Weather Strip (above hood) (2lbs)
Engine Bay Covers (6lbs)
Spare Tire (36lbs)
Rear Floor Mats (6lbs)
Rear Seat (46lbs)
Interior Carpeting + Insulation (25lbs)
Door and Center Console Trim (10lbs)
Front Floor Mats (5lbs)
Glove Box (9lbs)
Trunk Insulation (23lbs)
Lighter Exhaust Parts (30lbs)
Lighter Intake Manifold (8lbs)
Side Air Bags (10lbs)
Air Bag Trim Pieces (4lbs)
UR Lightweight Underdrive Crank Pulley (7lbs)
Headliner and Plastic Bracket (6lbs)
Rear Door Panels (14lbs)
Center Console (13lbs)
Rear Speaker + Rear Sub (8lbs)
Rear Seat Belts (6lbs)
Rear Speaker Cover (5lbs)
Foot Rest Plate (1.2lbs)
Partial Firewall Insulation (6lbs)
Radio Delete (6.5lbs)
Metal Front/Rear Door Accent Trim (2lbs)
Front Door Panels and Front Speakers (22.5lbs)
DVD Drive + Touch Sensor + Buttons (5.5lbs)
Rear Wheel Well Insulation (3lbs)
Sun Visors (2.5lbs)
XM Antenna (.5lb)
Front bumper/vibration damper and support (26lbs)
Motegi TrakLite V2 Wheels (55lbs static, 220lbs dynamic)
Official scale weight: 3113lbs static, 2948lbs dynamic/rolling weight due to lighter wheels
My YouTube channel with every video for the car so far:
https://www.youtube.com/channel/UCXu...6gteAqtawIGq5g
Old 07-17-2016, 06:58 PM
  #735
And my time slip for those who don't believe me
Old 08-24-2016, 06:51 PM
  #736
ReDevil
r3devi7's Avatar
Need to hit up Lebanon Valley again. Went last week and ran slower than my personal best, but I also went from stocks with 245s to TE37 with 235 width. Spun anytime I went wot, but still pulled my friends 07 Legacy 2.5gt mutiple times lol
Old 08-30-2016, 06:51 PM
  #737
Im guessing that Type S of yours is a 6MT with those kind of times. I'm still using 235 width tires and haven't needed anything wider
Old 09-01-2016, 05:02 AM
  #738
F23A4's Avatar
Received 1,659 Likes on 926 Posts
'16 TLX 3.5 FWD (stock) - car 610
SatinSilverAV6 (09-08-2016)
Old 09-07-2016, 04:21 PM
  #739
ReDevil
r3devi7's Avatar
Yes 6mt. I'm on 245/40 old conti dw now. Won't be hitting the track tonight, maybe next week. Really want to beat my 13.9 before season is done, debating doing 3.7 intake and tb next lol Worst part is my best time was with just cat back. I'm Pcd, xlr8 j, atlp exhaust, and mild flashpro tune now. New plugs too, had the front center launch last fall, and time-sert fixed, it's been going strong ~2k miles since.
Old 12-07-2016, 10:58 AM
  #740
Originally Posted by ILLustriousUA6
These are some times that I have gathered from the forums. I put it all together so it's easier for you guys with the 3rd Gen's. Sorry 2nd/1st Gens. Don't have your times on here but feel free to list them up. I think this is a
good sticky for the track peeps.
When it says CONFIRMED, it is proof that the person showed their time slip.
Enjoy, I took hours to gather this info. If some of these "???" beling to you guys, let me know or a mod to change it.
07-08 3rd Gen Acura TL Type-S - N/A
=M/T=
--??? - 14.24 @ 97.9 - (AEM and Comptech S/S catback)
--SleeperPnoy04 - 14.14 @ 98.56 - (Short ram intake//stock resonator delete) - CONFIRMED
60' - 2.298
=A/T=
--??? - 16.205 @ 86.283 mph
--??? - 14.85
04+ 3rd Gen Acura TL S/C
=M/T=
--OMP Prelude - 13.1 @ 105.48 - (s/C, thermo spacers, pro-cats,custom 3in exhuast, cold air in take, running bridgestone re030 17in ,and comptech ss,mugen thermostat and rad cap)
--Ryan97812 - 13.50 @ 103.47 3690 LBS (Comptech S/C // Comptech Cat Back // Cor Sport shifter bushings) - CONFIRMED
=A/T=
--ACCURATEin - 14.479 @ 99.16 - (s/c, took out the sub and box, spare tire, back seat, floor mats, sparcos) - CONFIRMED
60' - 2.352
60 deg. weather
50% humidity
04+ 3rd Gen Acura TL - N/A
=M/T=
--OMP Prelude - 13.70@101.63 - (thermo spacers, pro-cats,custom 3in exhuast, cold air in take, running bridgestone re030 17in ,and comptech ss,mugen thermostat and rad cap) - CONFIRMED with video
--type-s09 - 13.968 @ 99.14 - (Intake//P2R spacer w/ 17' street tires) - CONFIRMED with timeslip + video
60'- 2.166
--The MainEvEnt - 14.24 @ 103 - (Comptech Exhaust w/o resonator, AEM CAI, Comptech sports Spring, Comptech Rear Sway Bar)
--PIERCE@ACURA-O.P. - 14.258 @ 97.91 - (Injen CAI, Comptech exhaust) - CONFIRMED
60' - 2.204
--??? - 14.3 @ 99mph - (19 inch rims)
14.1 @ 101mph - (stock rims)
--??? - 14.01 @ 99.3 mph (stock wheels, AVS ES100 tires, intake & custom exhaust)
--mrbrett - 14.66 @ 97.73 - (???)
60' - 2.4
=A/T=
--againstallodds1 - 14.30 @ 99.3 - (a-spec, AEM CAI, comptech catback, UR pulley) - CONFIRMED
60' - 2.20
0-60 - 5.68
--email_33 - 14.6 @ 97 - (Bone stock)
60' @ 2.332
--Norse396 - 14.912 @ 96.19mph - (???) - CONFIRMED
60ft 2.276
62deg.
47% humidity
--AcuraTLboi - 15.060 @ 95.635 - (Intake w/ 17' stock street tires) - CONFIRMED with timeslip
60' - 2.413 (90+deg Temp)
--2005tl - 15.12 @ 93.25 mph - (bone stock) - CONFIRMED
60' - 2.44
--skullman - 15.377 @ 92.59 - (???)
60' - 2.352
--??? - 15.3 @ 91 - (???) - ???
--???- 15.665 @ 91.59 - (???) - ???
--WDP-Acura TL - 15.75 @ 91.4 - (???)
60 deg weather
--??? - 15.829 @ 90.119 - (???) - ???
--TetraLudious05 - 17.2 - (Bone Stock)
I put a lot of time into this so please respect. i'm doing this for you guys.
I think it's time to update the automatic records....I have those handy for you. These times are all motor, time slips are in the videos but I can give you pictures later too. Gutted/Full Bolt Ons. 2006 Base Auto. Car weighed 3100lbs for the videos, car now weighs 2998lbs.
13.8 @ 102.45mph
14.0 @ 103.08mph
Old 12-07-2016, 11:01 AM
  #741
Moderator needed
Can a MOD please update?
Old 12-11-2016, 10:44 AM
  #742
Yes that would be nice
Old 04-06-2017, 03:10 PM
  #743
To be clear, my times that I posted were with NO launch. Just simply mashing the gas pedal. No launch as in launching from idle as foot braking is slower for the autos.
Old 06-03-2018, 12:15 AM
  #744
Anyone still here? I'll be racing the 6MT tomorrow at IFO. We'll see how an 11 year old Acura can hold up.
Old 06-04-2018, 11:13 AM
  #745
Ran 14.9 consistently with the occasional 15.3 sec time. Traction was awful and the temperature was a bit high, but I ran against an auto Type-S and we consecutively timed about .6 seconds apart.
I'm a litle disappointed considering my auto ran 14.5 on it's first run.
Old 08-06-2019, 10:04 AM
  #746
90foxnotch's Avatar
A little late to the party but Im sure you just need some good tires, that's the main problems-Your car dyno'd about 300whp right?
Old 08-06-2019, 01:19 PM
  #747
The inconvenient truth
dopeboy1's Avatar
I was watching some 4g youtube videos. Was a little surprised to see a sh-awd 6MT do a 13.4 with just j-pipe, takeda intake and spare tire removed.
Old 01-16-2020, 03:24 PM
  #748
90foxnotch's Avatar
Pretty happy I got in the 13s. 07 type s 6mt pcds, jpipe,cai, im spacer, stock catback, street tires
Old 01-20-2020, 11:08 AM
  #749
Troncoso51's Avatar
First pass, tires at 35 psi
Second pass, tires at 32 psi
Last pass, tires at 28 psi
I'm #46
This was my first time at the drag strip located in Las Vegas, ran all three passes with my dad in passenger seat.
Vehicle: 2017 TLX V6 Tech
Modifications: Takeda cold air intake, Sprintbooster on race mode 9 (highest setting), resonator and muffler delete with wider Y pipe.
Ran all passes in Sport+ traction control off
F23A4 (02-12-2020)
Old 11-22-2020, 09:40 PM
  #750
F23A4's Avatar
I took mine (19 TLX 3.5 PAWS) to the track for the first time. (9694) Nice to see that it’s quicker than my old 16 TLX. If I can just not bog down at launch, then I may be able to shave a tenth or two off this time.
https://www.dragtimes.com/Acura-TL-Timeslip-31646.html
jmoney2175
01-10-2021 09:35 AM
aragrev7
1G TSX Photograph Gallery
08-08-2014 01:48 PM
TylerT
09-06-2009 03:04 AM
lightning20
03-08-2006 08:13 PM
Quick Reply: Quarter Mile Time Compilation
