Killed a Volvo S60 R Automatic
Old 04-17-2007, 07:00 PM
  #41
amer's Avatar
I work for volvo and own a 07TL type s
The S60R volvo manual will eat a TL stock for stock .
S60R auto it got the pick up till about 80 -90then later takes time to get there
S60R is a fast car i would not sleep on them
Old 04-17-2007, 08:09 PM
  #42
You'll Never Walk Alone
iforyou's Avatar
Afterall, the volvo does have more hp and a lot more torque, I wouldn't be surprised if the S60R can beat a TL-S in a straight line based on numbers.
Old 04-18-2007, 11:53 AM
  #43
lurker
SoCal_S60R's Avatar
OT: Black on Black looks sweet! Nice job!
Old 04-18-2007, 03:36 PM
  #44
SuperStar's Avatar
Let's presume that a 6 speed Type-S is faster than the 14.2@98 that the magazines got for the base TL 6 spd. In that case let's GUESS that the Type-S is a high 13 second car somewhere around 100-101.
Tell me how the fastest model 'stock' s60r, running the same time, EATS a TL-S?
Old 06-10-2007, 02:01 PM
  #45
guestS60's Avatar
Cool
You have all the data you need. Numbers of 60R are much better then TL-S.
TL is lighter then s60R, is it really? … could you do a test:
Set TL and s60R to neutral and push it – how many HPs you really need to move it from static position? Bring your data please.
Go and get Dyno for 60R and TL ... do not forget about torque… Find out what torque does and why it is important.
If you will accelerate and your speed is more then 30mph you should compare Drag Coefficient.
TL = 0.29
s60R=0.28 - much better at high speeds and at that point you have to forget about weight difference at high speeds your TL will get lost behind s60
Talking about weather: wet & Icy conditions … which would be a better car?
I do recommend you perform in 120 degrees … who cares about your engine that it will misfire a little. (I am sure that it is very not expensive to replace your engine and be proud that TL is less smart… by the way, there is a simple tune for hot conditions “cold” spark plugs? and octane)
And some ford explorers will kill Acura TL s … you would not perform against them on the bumpy street from the start it will kill you a little…
Drag Coefficient for ford explorer would be: cd = 38-0.41 ...though
http://www.dragtimes.com/Ford-Explor...lip-10963.html
S60R!!! TL???
Old 06-11-2007, 01:22 AM
  #46
iforyou's Avatar
Honestly, both TL-S and S60R weigh about the same, both are around 1600kg, any difference is just negligible.
TL-S 6MT: 1620kg (3563lbs) http://autos.yahoo.com/acura_tl_type...s-specs/?p=ext
S60R manual: 1604kg (minimum curb weight, in other words, no options added)
http://www.volvocars.co.uk/NR/rdonly...7Pricelist.pdf
I suspect the weight of the S60R would increase once you add in the options (quite a long list too)
torque is important for city driving, but in racing, the car with more hp, assuming others factors are the same, will win. An extreme example would be a F1 race car, 300lb/ft of torque, yet capable of doing 0-60 in 2.3s. The bottom line is, if the engine can make that amount of torque from low rpm to very high rpm, like 18000rpm, then you will get a lot of hp, just remember the formula/relationship between torque, hp, and rpm.
Drag, according to the Volvo UK site, s60r also has a drag coefficient of 0.29, in other words, the same as the TL.
For sure, AWD traction would be an advantage to the S60R in wet and icy conditions.
What about track performance? Keep in mind that the TL-S has beaten both 07 IS350 and 07 G35 6MT sport on willow springs track in California by 2 seconds.
Oh yea, many cars will kill TL-S. In fact, any car can kill any other car, so..what's the point? There are civics out there that make over 500hp and can eat both TL-S and S60R any day.
In the end, I think the S60R has the advantage from a dig, but from a roll, I say they will be pretty close.
Old 06-11-2007, 07:18 AM
  #47
Glock20C's Avatar
after reading all these interesting posts....at the end of the day @ the Track it looks like a drivers race between both these vehicles @ stock trim....( Type-S 6MT vs. auto S60R)....My wife has a Type-S and my Bosses wife has S60R...i've driven them both ..on a cold day that S60R rocks..I also like the active suspension on the S60R and the stock 18in rims not to mention the brembo on both front and rear wheels...
Old 06-11-2007, 04:41 PM
  #48
lurker
SoCal_S60R's Avatar
I haven't been on here in a while, but I'll throw this out there:
Cali Speedway (FONTANA) - JUNE 30
Rules/Regs
http://www.socal3g.com/forums/showthread.php?t=7650
JUNE 30TH
GATES OPEN 7AM
LANES OPEN 9AM
$20race/$10cheer
Lessons learned :
bring insurance card, wear pants, bring DMV registration
be prepared for a real tech inspection unlike LACR
I'll be there....if anyone wants to go head to head...my RT's sucked at Palmdale, so we'll see what I can do here. Elevation is definitely better, but will be worse on the turbo temp-wise. I'll be running Toyo T1R's and 100 oct. Come out and play...I won't hang my head if I get beat by an Acura!
Old 06-11-2007, 05:27 PM
  #49
JDM Laser Fogs!
lifetimeofwar's Avatar
Damn it!!! June 30th is our all cali meet. If I dont go to that, ill deff take you up on that offer.
Old 06-11-2007, 05:32 PM
  #50
lurker
SoCal_S60R's Avatar
What time though? Our group is getting to the gate at 7 a.m. and going to try to get 2-3 runs in before 10 a.m. Then I'm out, once the temps start hitting 80+.
Old 06-11-2007, 05:44 PM
  #51
JDM Laser Fogs!
Well, it starts at 12pm, but the location is bout a 3 hour drive for me so I wouldn't be able to make both events.
Im sure you'll do another event some other time, and if you can remember, shoot me a pm or invite.
Old 06-11-2007, 05:53 PM
  #52
lurker
SoCal_S60R's Avatar
Or if you guys put together a 1/4 mi. day, let me know and I'll crash it.
Old 06-11-2007, 05:58 PM
  #53
JDM Laser Fogs!
lol. Well it seems like you have the upper hand when it comes to planning these things, but ill try
Old 06-11-2007, 09:34 PM
  #54
drcookie's Avatar
Man ! The thread started in 2005. I can't believe it is still alive.
Old 06-11-2007, 11:33 PM
  #55
iforyou's Avatar
I didn't notice that until now lol!
Old 06-12-2007, 03:17 PM
  #56
lurker
SoCal_S60R's Avatar
Bah...I'm not racing after all on the 30th now. Going camping with the fam. Brownie...pm me your e-mail or MSN Messenger and we'll set something up. Bring someone to hold the camcorder. I've got a card for the VP 100 pump in Temecula, if you want to boost your oct before we go.
Old 07-16-2007, 12:43 AM
  #57
lurker
SoCal_S60R's Avatar
I got lined up next to a black TL at a light on a 3 lane 55mph today...did all I could to provoke a little competition...he wasn't havin' it. Young guy too...maybe some owners don't know how much they got with their TL and are easily intimidated? LOL
Someday....
Old 07-16-2007, 04:21 AM
  #58
JDM Laser Fogs!
Some Sat. morning when we finally meet at the track. lol
Old 07-16-2007, 11:24 AM
  #59
lurker
SoCal_S60R's Avatar
I know...I've been keepin' a lookout for any other clubs hosting a track day....nothing coming up soon. Summer is bad for 1/4 miles...everyone wants the cool air.
I'm actually getting really anxious. You guys post so many kill stories against cars I wouldn't think the Volvo would beat. Then again...lots of those cars are faster on paper than the Volvo...but there's a ton of shitty drivers out there. My RT's sucked big time at my first visit to the track.
Old 10-13-2007, 02:56 AM
  #60
clttr2002's Avatar
100 in Temecula? Where ? I what to test some pinging out and need that level to do g=so...
Old 04-21-2016, 05:37 AM
  #61
BenS60R's Avatar
Hey man i jst bought an 05 auto S60R i jst want 2 know more about it like easy ways on making it fast and what are the best routs 2 go.Ived always wanted an R always loved them but had never owned 1 till now..i use 2 have the 2.4t and i loved it.
Old 04-21-2016, 09:30 AM
  #62
3.5 psi
gnuts's Avatar
why did you join Acurazine if you want advice on your new Volvo? Also, the last post in this thread is from 2007.
EvilVirus (04-28-2016)
Old 04-28-2016, 09:50 AM
  #63
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
y u tak lik dat
Houston
10-08-2015 01:27 AM
Joe Avesyan
09-29-2015 03:57 PM
Quick Reply: Killed a Volvo S60 R Automatic
