XLR8 Engine Torque Damper: '04-'08 TL Manual
#281
another thing is that the oem cats, are VERY robust and can probably support the engine on their own...and most people swapping motor mounts are probably so modified that they have some form of high flow/pcd cat that isn't built as obese (weight savings) so we end up creating the issue with that perfect scenario...more power, less support, then hard mounts.
I think the ETD with firm mounts will be a good set up to save the exhaust.
treal512 (04-16-2017)
#284
I read over the thread again and I guess they go inside somehow to adjust the stiffness, I installed it and drove around no problems but I didn't know I needed to use the 2 washers on the oem bolts to the bracket.
#287
The shock and the damper are the same thing. You're replacing the stock black engine "shock," or damper, with the new silver NRG damper (aka shock).
#288
Thread - https://goo.gl/tiBxVs
#289
^^^ I assume the second (black) bushing is just an extra in case this one wears out? Or maybe it can be used inside the damper for a softer setting? I am unclear, but I like how the car drives now so I'm not worried about it.
#291
Nevermind, I got it. for some reason I thought I had to work from the top. Went underneath the car and It's easy to access, you just need an 18" long ratchet.To adjust the damper, do I tighten the fisheye bolt or the bigger bolt in the body of the part?
#292
Ideally you want them both adjusted somewhat equally. You don't want one screwed in all the way while the other is hanging on by a couple of threads. Like in this picture -
#293
orkoTL
4G TL Problems & Fixes
107
09-28-2017 09:12 AM
jamestheunderdog
07-19-2016 07:58 PM
ExcelerateRep
12-11-2015 12:58 PM
sockr1
10-01-2015 01:31 AM
