Vacuum lines on engine mounts?
I do my own work.
The front mount has a vacuum line running to the bottom of it. I've replaced my engine mounts with the XLR8 mounts, but have no idea what to do with the vacuum lines... I can't just leave them open, can I? Those of you that have replace your mounts, what have you done with the vacuum lines?
18psi
If so, zip tie the ends of lines closed. You dont want any vacuum leaks.
If not, remove all the lines and remove the module on the rear of the intake manifold. Use a rubber cap on the nipple so you dont have any leaks.
If you dont want to pull the lines, then you can put that rubber cap over the nipple on the manifold to prevent leaks.
Cap or plug. I would cap also to avoid having a vacuum line just laying there.
I do my own work.
Thanks for the help.
I pulled the lines out and capped off the manifold. I noticed there's a small module to the left of where that vacuum line hooked up. The module is on the vacuum line between the manifold and the engine mounts. I noticed that in libert69's pic above, the module is not present and the harness is just sitting there. I suppose I'll do the same. Anybody know what the module is?
I was thinking maybe I could just put the module back and plug in the harness, but I have no idea what it is...
I do my own work.
As well, just for purposes of documentation, the two top bolts for the side XLR8 mount were 1 1/4" too long, and would not tighten down. That's too much slack to take up with washers Excelerate hasn't heard of anyone having problems, so it may be something specific to my situation. (2004 6mt) I ran out to Auto Zone and got two M10-1.25 x 30mm flanged bolts. Maybe this will help someone searching for the same...
I'm thinking replacing my front and rear mount but I noticed the front tubing is missing..
maybe that cause some vibration during red signs with D4... when put in neutral the car feel smothh and runs great.
any advise?
Yeah, I used the port the controller was connected to for my added goodies. I did keep the controller connected but as you see, Libert69 and Inaccurate both removed theirs with no issues. You should probably at the very least put a plug on the vacuum port on the IM just in case the solenoid stays open unconnected or definitely if you remove it altogether.
Inaccurate (04-30-2012)
Just a heads up if you remove the control module... If you leave that electrical connector unplugged and decide sometime later down the road that you want to go back to stock, the connector will most likely have corrosion inside from the bare metal terminals contacting moisture in the air. It needs to have the weather pack type of seal to keep it out, that is the rubber seal inside one end of the connector that slides directly over an exact fit plastic piece on the module side, which keeps all the moisture out.
So I would either just leave the module plugged in with lines fully installed but PLUGGED, or if you really want to pull the module at least pack the connector full of dielectric grease and find some way of trying to cover the end of that connector.
Brad
Brad
94Auto (07-08-2021)
Right side of engine/ pass. Use the oil pan, but use a piece of 2x4 on the jack to distribute the weight on the pan a bit and you should be fine.
okay. I just wanted to make sure is wasn't going to bork anything ECU related. thx.
I ended up going a different route though. I used the top part of the factory side mount, the piece that has the grounding wire attached to it, in addition to the XLR8 bracket. I placed this piece on top of the XLR8 bracket but now need longer instead of shorter bolts.
IMO when buying mounts you should get all of the necessary parts. I'll pay 10 extra dollars for bolts if that is what it takes
Mike shirley (08-04-2018)
The vacuum line is for vibration dampening when the vehicle is in gear and stopped, like when you're at a red light. You'll notice they aren't on the cars with manual transmissions because anyone at a red light will be separating the engine from the drivetrain using the clutch pedal anyway.
The following 2 users liked this post by JMiles_T:
EvilVirus (08-06-2018),
Motor mounts
so we install new motor mounts but the car vibrates alot now when car is at idle in gear. So we try and took off vaccumn hose from silenold valve and it does vibrate as much. We did buy the new mounts from Rockauto. I was wondering if the mounts that we buy are working opposite then the OEM's?
sockr1
10-01-2015 01:31 AM
