2008 TL type S 6spd project, where to start
Old 06-24-2018, 10:41 PM
Chris Jordan's Avatar
Hey all , new to this site . Looking for some help/ advice
So I'm currently in the market for a 2008 TL type S 6spd , and once I've found one . I would like to start my build . Want to make sure I do all my research be for diving head first into It .
Can any one here lead me in the right direction and or offer some solid advice.
I am currently living in Vancouver BC area .
​​​​​​Cheers 🍻
Old 06-24-2018, 11:12 PM
_
AZuser's Avatar
Received 3,097 Likes on 1,867 Posts
AcuraZine - Acura Enthusiast Community > AcuraZine TL/TLX Community > Third Generation TL (2004-2008)
Old 06-24-2018, 11:45 PM
​​​​​​Cheers 🍻
Old 06-25-2018, 06:16 AM
Received 16,260 Likes on 11,971 Posts
read the forums...over the last 14 years we've talked about, answered, modified, pretty much all there is to do...all it takes from you is a little simple reading....BECAUSE there is no way 14 years of info will be spoon fed to you.
Old 06-25-2018, 06:17 AM
read the forums, bro! it's all in the link AZuser provided
Old 06-25-2018, 08:20 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Moved to proper forum.
Old 06-25-2018, 09:37 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
not trying to be a jerk but first you gotta to make sure that you buy a clean TL-S MT 1st before making mod list lol.
Old 06-25-2018, 10:49 AM
Slot Machine Lubricator
1black_seven's Avatar
https://acurazine.com/forums/3g-tl-p...owners-701772/
Old 06-25-2018, 10:54 AM
absolutely couldn't agree more with you on that .
Any suggestions u can pass on , when looking for one besides the obvious , low kms , one over, no DEC's, no smoker / pets ects
Old 06-25-2018, 10:55 AM
fair enough, will do cheers
Old 06-25-2018, 11:30 AM
juskimdh's Avatar
Hi Chris! I sent you a PM!
Old 06-25-2018, 01:47 PM
MyGuti's Avatar
Hey Chris, good tonseea local member on here. I'm also from Vancity and recently picked up my 6mt type s. There's a few on our local craigslist right now that seem to be decent. It'll be a task to find a mint one, but you never know what might pop up. I have a check list I made for the type s, from everything mechanical to lights. Hit me up and I'll forward it to.you. good luck on your search!
Old 06-25-2018, 02:11 PM
truonghthe's Avatar
To me the milage doesn't make the "must" or "bust", when I in the market for a TL-S MT it pretty much the mechanical condition reflect on mileage and price. I prefer the one that previous owner has all records of maint/repair bills or some sort of logs through out his/her ownership.
I willing to pay high price for "my criteria" but nothing come up except for a bunch of "junk" TL, I guess that what happened when I only wanted MRP or KBP MT lol.
Old 06-25-2018, 02:21 PM
how's it going good to hear from someone local , yes if u can send that list it would be much appreciated.
Also I am to looking on all of our top three search engines and I can't find anything 6spd type s alot of autos . Let me know if you have seen any .
Chat soon
Cheers
My email is hondatuning2@shaw.ca
Old 07-04-2018, 04:12 PM
Ossman14's Avatar
I looked at the build threads for we when I first got my car to see what was done and how it would look. Go back farther than the first page though. And I looked specifically at those threads that had multiple pages. Then from there you decide what you want and how to do it. If you do it yourself there are a ton of links floating around to help. Or hit up the vendors here to see what they offer. I’ve only dealt with endless, but heeltoe and excelerate are both well known on here.
Old 07-06-2018, 12:16 AM
thanks for the advice : )
Old 08-21-2018, 11:02 PM
Just picked mine up yesterday : )
So after alot of patients I've managed to find my very first type S 6spd and I'm jacket . Dam these things are quick , stock .
I have one thing that I wanted to ask you all , my guess is need new spark plugs or a bad coil pack
so at idle if u put ur foot on the pedle and raise it up to just under 1500 rpm the idle is very rough , after 1500 rpm all is great as is the idle . Any ideas
Cheers
Old 08-22-2018, 12:28 AM
MyGuti's Avatar
sounds like a bad motor mount
Old 08-22-2018, 01:48 AM
theCoffeeFiend's Avatar
Just like any older used car, it's going to need some work whether you like it or not. You should work out the maintenance and repairs first before sinking money into mods. You will feel better about the car knowing its not a rolling sh!tbox. With that being said, depending if its an auto or manual, your starting mods will be different. Take care of that trans first either way. then build
Old 08-22-2018, 02:52 AM
Ossman14's Avatar
When I first got mine I took it to Acura for a pre purchase inspection. Cost $150 but you can apply that $150 towards anything you have them complete, I used mine on the timing belt
Old 08-22-2018, 02:23 PM
BreezyTL's Avatar
Info and
Old 08-22-2018, 03:32 PM
Couldn't agree more , that's what I'm doing get it running tip top and then , start the build . Is I've mentioned only real thing that I have noticed is that rough throttle response from idle up to 1400rpm them smother out fine
Old 08-22-2018, 03:39 PM
Latent car nut
horseshoez's Avatar
Received 2,005 Likes on 1,407 Posts
What kind of plans do you have for the build and how deep are your pockets? This car is a huge black hole for money when it comes to performance mods, lots-and-LOTS of dollars for each additional pound-foot of torque and/or horsepower. Unless you're prepared to dump an easy five thousand, you might just save your money and enjoy the car as it is.
Old 08-24-2018, 07:46 AM
for the most part get it in full operating order I have a few small things to do
- the fought throttle response from idle up too 1500 rpm
-Clutch
-oil pan seal
-timing belt
That's about it , it's a screemer .
What are your thoughts on the throttle issue , and what Clutch would u recommend , a step above stock .
After get these small items done , my goal would be 450-500 hp and yes I've got a few bucks to invest into it .
Old 08-24-2018, 07:07 PM
Acura TL Builder's Avatar
Instead of dicking around with stickers, just buy a Gerzy Bear Performance procharger kit and call it a day.
Chris Jordan (02-03-2020)
Old 08-24-2018, 08:40 PM
Stickers ??
Whats this kit all about ?
Old 09-04-2018, 11:47 PM
Qrious's Avatar
Exhaust
I'd advise start with the exhaust big fella, let's u know exactly how u want your car to sound so it can look the part next, but most of all fix anything that's MAJORLY wrong, like brakes if grinding, or dash codes cause theres nothing worse than putting 2k worth in parts to a car that has a fucked up tranny u could a fixed a year ago
Old 09-07-2018, 10:02 AM
great advice 👍, that's what I'm currently working on getting here 100 % sounds , if u have read my other threads . I'm still dealing with this . Did u have any thoughts , thinking I'm going to call the dealer and have them go threw it .
As far as exhaust goes , great idea . But wow there's far to many out there . I would want mine to sound exotic, powerful, no ricer sounds ( no offence) .
Have u gone threw the hole circle jerk wight he Bluetooth phone thingy up by the sunroof bottoms?
Old 09-07-2018, 11:25 AM
Qrious's Avatar
Hands free Calling ?
u referring to the hands free speaker/connection thing by the sunroof button ? Lmao man I unplugged mines but left it up there for 2 reasons
1. I hear it drains the life outta ya batter when it's bad cause it's always attempting to connect
2. Its 2018 and I have a type s with aux cord and google maps I don't need an obsolete system to drain my battery
in reference to the exhaust tho I'm doing a custom one for my type s
Old 09-07-2018, 11:36 AM
ya the previous owner did the same thing , but it would be nice to have the phone working with the phone so I can make calls .
whats the details on your exhaust build . A shop is doing the build from scratch or using parts to build it
Old 09-07-2018, 11:52 AM
Qrious's Avatar
Its pricey
Well in reference to u getting that hands free I'm all to support shit ppl want for their car, however I must warn u buy it new cause these go bad after maybe 3 years if your lucky it's not quite reliable so never get a used one unless free or dirt cheap, but the drawback is a new one is mad overpriced/expensive for such an unreliable system
now in reference to the exhaust I was gonna do custom piping but since I'm gonna put a push bar/tow bar at the front I decided to go the other route, right now my exhaust is stage 3 with an intake reso delete but I currently have 2 magnaflow rear mufflers and a y-pipe sitting in my trunk waiting to be put on follow this thread to get full details on a similar set up https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/piecing-together-magnaflow-quad-exhaust-767913/
Old 09-07-2018, 11:56 AM
Sweet I'd like to check that out , do the link u added I couldn't open up , it wasn't highlighted
Ya I'm guessing aftermarket is the best waste go , thing is if I go that way , can the new system work with all the factory bottons I really like the out lay of the button lay out
Old 09-07-2018, 12:23 PM
Qrious's Avatar
Search
"​Piecing Together Magnaflow Quad Exhaust​​​​​​"
just search that on Google and you'll find the page my guy, and the button layout you'd have to find a good custom person you trust to either reroute the buttons which is expensive or make a new circuit board to put in there so the right signals r being sent if u wanna add shit in which is a whole other level, but I haven't seen it done before so u got uniqueness if u can find someone, the level of difficulty is crazy that's y most ppl just leave the buttons and add new ones to di what they want like a button by the steering wheel for undrglow and shit
Old 09-07-2018, 11:09 PM
Aussum's Avatar
as for your Bluetooth needs,
this thing this thing
is great! I've had mine for over a year and it sounds perfect and is a breeze to install.
Old 09-16-2018, 09:06 PM
GhostTL09's Avatar
No pics?
Old 09-16-2018, 09:52 PM
Originally Posted by Aussum
as for your Bluetooth needs, this thing is great! I've had mine for over a year and it sounds perfect and is a breeze to install.
Temporary out of stock ,
Old 09-17-2018, 04:03 AM
Latent car nut
horseshoez's Avatar
Do not order any USASpec products from Amazon. Why? Per USASpec's web site, they have no authorized Amazon dealers, and if you buy through that source, they will not honor any warranty issues. If I recall correctly, Crutchfield is the only authorized online vendor; I bought my BT45-HON from them.
Old 09-17-2018, 04:57 PM
Joecop67's Avatar
I bought mine from amazon.
Old 09-17-2018, 09:35 PM
MyGuti's Avatar
@Chris Jordan, if you don't care about having your track information show up on the navigation screen and having control to switch tracks via your car's built in buttons, I recommend purchasing the Harmon Kardon Bluetooth adapter! I have it in my Type-S and I swear it makes your stock sound much much better. Deeper clarity and much better sounding bass (no rattling).
Old 09-18-2018, 11:37 AM
BreezyTL's Avatar
Originally Posted by GhostTL09
No pics?
no car?
Chris Jordan
07-06-2018 12:16 AM
JDNighthawk
New Member Introductions
05-21-2018 10:35 AM
00TL-P3.2
05-16-2018 01:11 PM
Mokos23
11-30-2012 01:35 PM
Quick Reply: 2008 TL type S 6spd project, where to start
