2004 6 speed 165k slow oil leak from the top..
Old 07-28-2018, 12:09 AM
zexi's Avatar
I have oil leak coming from above, do not see any obvious leaks.
Please Help
Old 07-28-2018, 05:15 AM
frankjnjr's Avatar
Please Help
Little clarification, and or pics., on your leak issue may help. Engine oil leak, transmission oil leak, coming from above WHAT, etc.? If the leak appears to be coming from the upper portion of the engine, it's most likely the rocker arm cover gaskets. If it's near the oil filter area, it could be the oil pump seal. Have you determined, if it's engine oil, or could it be power steering fluid?
Old 07-28-2018, 10:24 AM
zexi's Avatar
I will dig deep under the hood to get some pics
frankjnjr (07-28-2018)
Old 07-29-2018, 12:49 AM
zexi's Avatar
Question
It is leaking power steering fluid, I do not see any wet areas from full inspection from top.. can I inspect the lower hoses without taking the bottom cover off ??
Old 07-30-2018, 05:36 AM
frankjnjr's Avatar
IMO: Kind of difficult, to pinpoint the source of a fluid leak, without being able to see, as much of the underside area of the engine bay, as possible. It may be beneficial, to remove the bottom side engine cover first, and look around. If, your CERTAIN, the leak is P/S fluid, you MAY NOT, have to remove the cover, to spot it's source. P/S hoses, normally leak, at, or near the couplings, so if you check the areas, where the hoses attach, you may spot the problem.
LynnFL
1G CL Problems & Fixes
11-12-2013 10:22 PM
5ABI VT
10-26-2013 06:01 PM
mYrls
06-15-2013 10:47 PM
NSXNEXT
07-22-2010 01:35 AM
ASuddenSilence
18
05-11-2005 03:42 PM
Quick Reply: 2004 6 speed 165k slow oil leak from the top..
