A-113: Removal of Slave Cylinder check valve!!!
Old 12-10-2009, 06:08 PM
  #361
rockstar143's Avatar
Received 19,915 Likes on 14,457 Posts
Originally Posted by Liquidflex81
i will give it a try then, hopefully that is the fix, is it hard to access the slave cylinder, just get the car up on some ramps and look by the transmission for it? is ALOT of fluid going to leak out when i take this part off to access the check valve? thanks
I have an 04 and you most certainly DO have the checkvalve. The problem you are describing will be fixed by this. It's pretty clear by some of the things you've written that you haven't read the entire thread. I would recommend it because when you're done you'll know how to do this, work arounds and what works best and fastest. This mod is a must in my humble opinion.
Old 12-12-2009, 12:57 PM
  #362
LiQuiDFleX81
Liquidflex81's Avatar
gonna do the mod now,, i see where it is now looking down by th radiator, i see the black bracket, gonna take it off,, pop the cap, ring out, valve out, ring in, cap on, reinstall, have my dad help me bleed the line,, will let you know if this fixes it!
Old 12-12-2009, 01:02 PM
  #363
347hp/300tq @ 4psi
04accordcpe's Avatar
finally did this mod and LOVE IT!!! i drilled a small hole on the side and the clip was a snap to get out. i didnt have bleed the line at all afterwards too.
Old 12-12-2009, 02:20 PM
  #364
LiQuiDFleX81
really no bleeding at all??? hmm
Old 12-12-2009, 04:21 PM
  #365
KN_TL's Avatar
I filled up the slave prior to putting it in and there was minimal air. But I still went through a 1/2 can of fluid just to be safe....it's flushed now.
Old 12-12-2009, 04:34 PM
  #366
6-SPEED LOVER
ABP_04TL's Avatar
iono if i have air in mine... but now i have this sound (pedal pressed) *Weee (Released) *Weeee. and u could hear it from comin from down there while seatin inside the car or standin in front of it...
any1 had dis b4?
Old 12-15-2009, 02:40 PM
  #367
AM MT Navi
shotcaller88's Avatar
Just received a new sc. I cannot get this stupid ring out for my life. Very frustrating!
Old 12-16-2009, 10:31 AM
  #368
cut the channel with the dremel...
I'm at 6K miles since i've done this and I have no issues...just turn the ring to and cut the slot in the SC where there's no ring and then use a pick to pull it out.
Old 12-16-2009, 10:46 AM
  #369
AM MT Navi
the previous posters scared me with the dremel idea. i'm going to bring the sc to a friend that's pretty handy. I'll check Advance or Autozone for a small pick set.
One question, when you pry the ring...do you secure one end with a pick and then pry the other end or do you pry in the middle somewhere?
Also, is it better to put the pick over the ring and to the back and pull towards the center or from beneath the ring and pull towards the center?
Old 12-16-2009, 12:39 PM
  #370
KN_TL's Avatar
You have to start at one end and sort of peel it out.
Old 12-16-2009, 03:43 PM
  #371
AM MT Navi
I picked up a pick set and had the ring out in 5 minutes. It took 4 stores to finally find one. I went to Advance, Autozone, Napa and finally found one at Pep Boys. Once I got the end of the ring out a slight bit, it came right out.
I'm not going to install this thing myself. Going to have a friend do it & change the clutch fluid at the same time. I'll report back next week on the results.
Thanks guys!
Old 03-24-2010, 05:47 PM
  #372
All motor
Sonnick's Avatar
I tried this today, and EPIC FAIL!!!!!!!!!
I got everything out, but it took awhile because the socket wrench was too big
I didn't disconnect the fluid line, and ended up not being able to get the lock ring out. I tried for over 2 hours I'd say, and nothing. I tried everything in my house including a pick set, no dice. So I wasted a whole day, and extremely frustrated
Old 03-24-2010, 06:25 PM
  #373
04Tl
Yonkers914's Avatar
that sucks bro if u lived closer i would of helped u get it out. I did it with a pocket knife.
Old 03-24-2010, 07:16 PM
  #374
I have put 10K miles on since I did this originally and it stills drives great. Much better response.
With no problems with that little channel I ground out with my Dremel. Took me literally 2 minutes and I was able to pul the ring out in seconds.
Old 03-24-2010, 08:17 PM
  #375
TL = True Love
mcmguti's Avatar
im going to try this out tommorow. thanks guys
Old 03-24-2010, 08:52 PM
  #376
I got the Shifts
phee's Avatar
where did opel go? i hope he is alright
Old 03-25-2010, 09:56 AM
  #377
HQTL6SPD's Avatar
opel is doing alright, spoke to him, he's just not on the forums much anymore...
Old 03-25-2010, 12:11 PM
  #378
I got the Shifts
phee's Avatar
alriht cool.
Old 04-14-2010, 08:45 AM
  #379
'06 NBP : 6MT : NAVI
met152's Avatar
Completed this mod last night. What a huge difference! I think this should have been done from the factory. Thank you to everyone who posted their experiences here. It helped me complete the mod without much trouble.
I didn't have a pick set, so I ground down a small screwdriver to try and make one. I didn't try for too long, but I didn't see this way working out for me so I grabbed the dremel. I cut a small notch only the thickness of the metal cut-off wheel perpendicular to the "C" ring. This allowed me to get the ring out of the retaining groove with ease. I don't see much of a long-term structural problem with how small the notch is.
The bleeding process was pretty straightforward. I used a piece of wood to prevent the "fork" from moving while I was bleeding the system. I took a couple pictures showing the fork, for those of you who don't know what to look for.
I turned my wheels completely to the left and used a wooden stake approximately 27" long between the fork and the inside of my tire.
I think this mod, coupled with Excelerate's engine torque damper (buying later this month), will have a very positive impact on the feel of the car.
Thanks again Opel, rockstar, kennedy, etc!
A-113: Removal of Slave Cylinder check valve!!!-b2xd7h.jpg
A-113: Removal of Slave Cylinder check valve!!!-tchfgh.jpg
A-113: Removal of Slave Cylinder check valve!!!-vixakh.jpg
A-113: Removal of Slave Cylinder check valve!!!-vgrzlh.jpg
Curious3GTL (06-25-2020)
Old 04-15-2010, 12:35 PM
  #380
^^Great pics.
Glad you were successful man. Yes, someone else finally agreed with my thought to cut the channel. No brainer...once you do it you kinda want that hour of your life back you wasted trying to use a pick!
About the bleeding...for sure...that's the way to go. I think I used a broken broom handle I had. It fit perfectly between the back of the rotor and the clutch fork.
Good work!
Old 04-15-2010, 01:58 PM
  #381
Under construction
alexSU's Avatar
Hey guys so I did the slave cylinder mod about 3 weeks ago, well actually my mechanic did it for me (free of charge ) At first the clutch felt great for the first week but then it started going back to the old feeling...where the clutch had a slight delay. During fast shifts from say 2nd to 3rd the clutch wouldn't release as quick as it did before.
Clutch slipping?? I don't think so because I've tried giving it gas in high gears and the slowly starts to pick up speed, the RPMs don't jump up. In 1st gear the car starts rolling without any gas at all!
Would getting a new slave cylinder help (and removing the checkvalve)? I removed the checkvalve on my old slave cylinder which had about 70K miles on it.
Any help would be greatly appreciated
Old 04-15-2010, 02:51 PM
  #382
I got the Shifts
phee's Avatar
check for leaks. i had to use jb weld putty on the end of my SC because it had a small leak that would only squirt during hard shifts
Old 04-15-2010, 02:52 PM
  #383
Under construction
alexSU's Avatar
thanks bro, ill check that out
Old 04-21-2010, 12:05 AM
  #384
7th Gear
sherker55's Avatar
Just read through all 10 pages! I can't wait to do this MOD, I complain to my wife (and apologize) every time she is in the car because of the way it shifts...It really makes me feel like less of a man! Now I know it isn't me...for the love of God, I learned how to drive on a MT!
Old 04-21-2010, 03:00 AM
  #385
bzyrice's Avatar
wow.. today was the first day that the check valve really annoyed me.. dangit I need to do this mod soon!
Old 04-21-2010, 06:30 AM
  #386
yay...finally RJ.
Wanna know something funny...I forgot how bad it was with it. When I test drove that 07 type 6 MT a few months ago...OMG...I was jerking all over the place and I was thinking wtf is wrong with this thing.
Checkvalve removal is a must.
Old 04-21-2010, 09:08 AM
  #387
HQTL6SPD's Avatar
Sounds to me like XLR8's ETD would be the perfect mod for you as well
Old 04-21-2010, 01:01 PM
  #388
bzyrice's Avatar
yay...finally RJ.
Yah I know, this has been on the backburner for me for a LOOONG time! If I have time this weekend I am doing it.
I noticed it really bad yesterday when it was pouring outside and at a light I tried to go and it took that little second for it to finally grab and go. When it finally grabbed my car just jerked because of the water and it felt like I was going to hydroplane.. (I had just gotten out of an old manual civic and guess I had gotten used to that shifter in those brief moments)
Old 04-21-2010, 01:58 PM
  #389
n3o
n3o's Avatar
Well you and your 2 minutes can go die in a fire. It took me like 30 minutes to get that freaking thing out . I used a dremel though like you're saying to cut a channel. Mine has roughly 10k on it as well since, I was losing clutch fluid for a while but I only refilled it once and it hasn't lost any since so I'm assuming it still had some air in it...even though I went through a almost 16oz bottle of brake fluid...
Old 04-21-2010, 02:08 PM
  #390
I'm back...badly burned but back. Put the fire out with the leftovers of your brake fluid.
Dude...I said 2 minutes to cut the channel and use a pick to pull it out. I wasted an hour trying to get it without cutting. Yeah right...it was no use. Dremel is the way to go.
J.
Old 05-07-2010, 09:08 PM
  #391
OCD
Roger555's Avatar
I really want to try this soon this is my second month with my 6speed and also first manual in general, I have driven a manual before but years ago and I really don't know what a car without a check valve drives like. I can shift smoothly through all the gears but it takes a lot of concentration to get the 1-2nd shift smooth. The thing that really annoys me is accelerating from a dead stop smoothly. I feel like I have to give it way to much gas to get it going or else it will start to shutter or feels rough. I am hoping by the sound of it the car will almost start to coast on its own from a stop after you release the clutch in 1st or at least with very little gas?
Old 05-08-2010, 12:16 AM
  #392
oh yeah. for sure...i can let go in first and the car will not stall...slowly of course.
BUT I don't think that's the checkvalve removal that fixed that. BUT the having a hard time shifting 1st and 2nd, for sure...that will go away.
Old 05-08-2010, 12:59 AM
  #393
OCD
Roger555's Avatar
I think i'm missing something here, what fixed this for you besides the check valve?
Old 06-08-2010, 09:07 PM
  #394
StreetKA's Avatar
guys this is great ! after reading couple pages i want this so bad... i drive my car very hard already done one clutch and 2nd one doesnt seem to be happy with my driving i was always pissed by how the clutch engage i thought it was just the way dual mass flywheel works...
and also i think it might be the reason why some of your guys including me are having hard clutch issue... when you shifting fast at the redline without this mod i think there is alot slippage that is cousing to overheat clutch parts bearings...
i cant wait to get this done idk why i m so late with this mod...
Old 06-08-2010, 09:11 PM
  #395
2nd clutch already!?!?
Dang, you don't wanna spring for some rwd american muscle, you can beat the shit outta them without much issue.
Just kidding, you'll love this mod. Get on it.
Old 06-08-2010, 11:23 PM
  #396
hondazex's Avatar
its done !!nice and pretty nice mods !!!!! recommended !!! pretty easy shift better and faster !! thanks alot
Old 06-10-2010, 08:44 PM
  #397
Westy6's Avatar
Thanks to Opel and all others who have contributed to this thread.
Completed the mod, noticed the difference immediately! Such a big difference from such a small piece...
Old 06-10-2010, 09:01 PM
  #398
OCD
Roger555's Avatar
oh i'm excited to do this do you like it a lot better? What do you notice the most?
Old 06-10-2010, 09:04 PM
  #399
hondazex's Avatar
fast shift 1-2 and 2-3 with no grind !!!! NO SLIPPING CLUTCH !!!!
Old 06-10-2010, 09:07 PM
  #400
OCD
Roger555's Avatar
Is there any difference starting out from a stop in first? I feel like sometimes I have to baby it to much with gas to avoid a shutter before it gets going. I'm still learning a stick too but still annoys me
Quick Reply: A-113: Removal of Slave Cylinder check valve!!!
