ROTORA Big Brake Kits: CL, TL, TSX
#121
Those with BBK's please advise
Originally Posted by Excelerate
Well if you have warped rotors you don't need a BBK to eliminate the shimmying however a BBK will eliminate it. All you need is an OE replacement rotor like a ROTORA slotted or drilled/slotted rotor.
Those with bbk's please share your experiences.
#122
Originally Posted by Dtls
I bought some Rotora's and Hawk Hps pads from you awhile back but it didn't stop that shimmy when braking at speeds of 50+.
A BBK disc is pretty difficult to warp if you chose to go that route. However I would oversee your current setup to see if something else is amiss.
#123
im looking just to upgrade my 2008 Type S's rear, will it be a problem running 2 brand's BBK brembo factory up front? also will stock type S will clear the BBK for the rear? or does the 04+ application fit the 08 at all?
#126
#127
Originally Posted by The Dougler
Are the rear rotora BBK for the 6mt TL rotors the same thickness as OE? Also what's the lead time for Black?
#129
USDM UA5 A-Spec
Hey Excelerate,
Do you have the part numbers for the 2pc and 1pc BBK kits for a 99-03 TL... I may need to purchase rotors from you soon and wanted to know which one I will need. Thanks
#130
USDM UA5 A-Spec
ROTORA will eventually set up their caliper so that those who buy 1 pc rotor BBK's can also upgrade to the 2 pc disc but that isn't possible yet. You would have to see your setup and buy a 2 pc setup or you could just replace the rotors with another 1 pc disc. PM me with your vehicle info, BBK info, and zip code and what you need and I'll get you a quote.
#132
Originally Posted by BiggyMcWang
Hey Excelerate,
#133
USDM UA5 A-Spec
So you are looking for the part #'s for the BBK or for the replacement discs for the BBK?
#136
Originally Posted by bent09
Anyway to post pics of the custom caliper color or know where to look. Their website is not very helpful.
#138
horny =
Email me at sales@excelerateperformance.com and I'll try to get you pics. What color are you looking for?
#139
USDM UA5 A-Spec
Hey Excelerate, can you PM me a quote for new Rotora BBK pads? I got a BBK on my 2002 TL-S. Also, any word on the 2 pc rotors fitting the 1pc BBK yet? Thanks
#141
#144
Adventurist.
How much are the replacement rotors for an 03 CL-S BBK? How long are they good for? Deciding if I should replace my rotors while doing the pads. I have 30k on my 1st-time rotors and pads.
#146
#148
Many of these kits are good in stock. You can also purchase these on the webstore at:
http://store.excelerateperformance.com
#154
Meaning the kit is set up properly for your vehicle. If you buy a no name kit it can offset the brake balance. That isn't the case with ROTORA and STOPTECH; both those companies sell balanced brake kits.
So yes the BBK will work just fine on your car. The 1 pc 13" 4 piston kit is a great bang for the buck; if you have the funds upgrade to the 2 pc setup.
#155
ridin slow'n'low
Since you carry both the wilwood and the rotora BBKs for CLs, I'm just curious to see how you think they compare? Seems intriguing that the wilwood bbk comes with a 2-piece rotor for the same price as rotora's 1-piece. Does that mean quality-wise, rotora makes a better product? (I know that the rotora has had an application for our cars for a lot longer)
#156
#157
The Wilwood kit is really not a Wilwood kit; it just uses Wilwood calipers. IMO the ROTORA kit is a better kit b/c it uses higher quality components and it is actually designed for the vehicle. The Wilwood kit really is based off another vehicle. It's a great kit for the price but I like the ROTORA product better and it has much better wheel clearance.
