ROTORA Big Brake Kits: CL, TL, TSX
#81
1 Post
Do you have the new bbk rotors with the special coating on them? it was from this thread https://acurazine.com/forums/showthread.php?t=156263
#82
#85
1 Post
Originally Posted by Excelerate
When you say BBK do you mean the TL w/ Brembo calipers? If so yes.
#86
What I ment to say was will the rotors in the BBK come with that special coating you were talking about in that thread?
#87
I'm Cool
hey josh, i got the 1 piece rotor for the front bbk, i was wondering if it is possible to switch to a 2 piece rotor using the same caliper from the 1 piece bbk? and do you guys carry the the brakepads for this bbk? if so, could i get a price quote. thanks
#88
#89
Inspired
hey, do you sell any bbk for 00 tl, only the front ones, 1 piece, and if you do i would like to know the price with the shipping. I live in Canada, Montreal. thank you
#90
#91
Time to Climb
josh, i've been seriously contemplating taking my tsx in a new direction. just wanted to know if rotora plans on building a rear bbk for my ride. if so, i'm gonna have to scoop up both front and rear kits real soon
#92
#94
is it possible to just buy parts from rotora from you such as the capiler later on? My friend wants to know this before he invests in a set? He wants to know this because he had some problems with a different company on his other car and it was a damaged capler. They did not have parts anymore and told him he needed to buy the entire kit again and doesn't want to have the same problem again. Also he wanted to know if he could use a Rotora rear kit and a stoptech front kit as stoptech does not have a rear one.
#95
#96
Yes ROTORA does sell "Service parts", which are replacement pieces for every single part of their BBK's. You may use a ROTORA and Stoptech kit together but I don't see why he wouldn't just do ROTORA F&R. ROTORA has a tendency to have a forward brake bias like the stock setup, whereas Stoptech has a rearward bias. So yes they can work together but they develop their systems based on different theories. If you need either kit let me know. I sell both.
1. I have heard that rotora BBk's can cause the master cylinder to break or fail. Is this true?
2. Will any BBK cause premature wear onto the master cylinder?
3. Are there any spec sheets/data that shows the improvement of braking with a BBK?
4. I have factory brakes on my 04 and they are pretty "touchy" that if i tap them, the can bring the car to a halt. will this still occur with the BBK?
5. Does the installation of a BBK require a fluid change? I am due for one soon so it is well worth knowing now.
6. Does stopetech also have replacement parts?
7. What do you mean by forwards and rearwards bias? I get a little confused.
8. can stoptech/Rotora kits be painted by the manufacturer to a specific design (such as acura written instead of Rotora/Stoptech)?
#97
I am thinking about a BBK since i have money saved up and need new brakes soon.Just a few questions I have:
2. These kits are designed to work with the stock master cylinder.
3. You may email ROTORA for data on this but I don't have any sheets on this. I don't see how sheets could prove anything but I can give you real life experience and tell you that the ROTORA kits have plenty of leverage and will decrease stopping distances.
4. Yes.
5. Yes it requires you bleed the brakes. It may not be a full fluid change but I would recommend one while there.
6. I will have to ask Stoptech tomorrow about service parts but I would assume they would. It wouldn't make sense not to.
7. When you brake with a ROTORA BBK you will feel a front brake bias like you do with the OEM setup. When you brake with a Stoptech kit the car leans rearward and kind of squats.
8. You can get custom caliper colors but I assume we can just have nothing put on there and you could put on an Acura sticker. I will have to talk to both tomorrow to ask.
#98
^ Thank you Excelerate
#99
Columbia Univ. c/o 2004
Can you go a bit lower on this BBK for 3g TL (5AT)? I have some extra cash and can borrow some more, but not enough for $1300. Is the price absolutely fixed? Please PM me if you can help. Thank you sir.
ROTORA 1 Piece Front 330MM Disc w/ 4 Piston Caliper BBK - $1300 shipped
#100
#105
Originally Posted by rodneyc77
Does Rotora make the 4 piston Rear BBK for the '04-'06 3G TL???
#108
Retired!!! ON TOP!!!
Yes they do. It is $1750 shipped, like the front 4 piston 2pc disc kit. I actually have a 2 piston kit rear BBK in stock w/ red caliper and slotted/drilled rotors that I am clearing out for $1275 shipped. It's usually $1475 shipped.
#113
Originally Posted by DURAN007
Do you have those BBK at $1275 for clp fronts?
#117
How much for the 2 piston rears shipped to FL for the 2000 tl with 2 piece rotor and can I get it in black? Can you get crossdrilled by itself or only slotted alone?
Whats the lead time on that?
#118
#120
Originally Posted by Dtls
I am in the market to improve the shimmy in Acura's brake system. If I upgrade to a bb kit front and back, will it eliminate the shimmy in the brake system.
